Old Dec 08, 2010, 10:27 AM
Italy
Joined Jan 2003
New application devFus Foam released
Many modellers asked me how the could cut foam fuselages using their CNC foam cutting machine.
This is a non trivial task, due to many problems in carriages synchronization and more...
Today has been finally released devFus Foam, the new application to draw and cut foam fuselages.
The drawing part is similar to devFus, and can exchange projects with it, but you can here:
- create cutting file for a 4 axis CNC hot wire machine, using GCode, DAT, DXF, Hpgl/PLT files
- preview and simulate the cutting job with a 3D simulator
- draw and cut by a 3 axis CNC milling machine the formers, that can be also used as templates for a manual hot wire bow
See http://www.devcad.com/eng/devfusfoam_frame.htm for more info about
best regards
Stefano
durone is offline Find More Posts by durone
Old Dec 08, 2010, 12:44 PM
Build it again, Sam!
Harpye's Avatar
Germany
NOt the first to work from 3d but possibly the first commercial
Harpye is offline Find More Posts by Harpye
Old Dec 09, 2010, 12:30 PM
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
devfuz foam
Hi Stefano
i have had a play and,
will we beable to edit the inside shape for ducted fans.
if the fuz section are set at different size foam blocks.
can you setup a menu or system for us to cut the foam block sizes first.
and a way to cut top decking's for fuselages would be great
at the moment i use profili to cut my top decking's
thanks Dpot
dpot is offline Find More Posts by dpot
Old Dec 09, 2010, 12:34 PM
Italy
Joined Jan 2003
Originally Posted by dpot View Post
Hi Stefano
thanks Dpot
The feature to prepare the blocks is already included in the 4th panel of the Wizard.
I don't know what do you mean by cutting top decking's
Old Dec 10, 2010, 04:18 AM
dpot's Avatar
Joined Dec 2005
thanks found the block cutting menu
top decking's front or rear are just the top part of a fuselage cut in foam.
if i just draw the out line of the fuselage top decking that i need it works OK
can we set the shape of the inside cut of the lighting holes ,square/oval/ rounded top and bottom/
and edit them.
Old Dec 10, 2010, 04:48 AM
Italy
Joined Jan 2003
and edit them.
you can think the decking as an alone fuselage and draw/cut it
Old Mar 02, 2011, 04:27 AM
Joined Jan 2006
hi stefano
I wish that it can do , side spars for baseline.
paxjohn is offline Find More Posts by paxjohn
Old Mar 02, 2011, 04:52 AM
Italy
Joined Jan 2003
Originally Posted by paxjohn View Post
hi stefano
I just added upper and lower shaped (keel) spars, they can help a lot to assemble the fuselage.
Now I'm working on the creation of lofted parts of the sheetings.
You will set a max tolerance and the parts will be created.
The sheetings will be 'unrolled' on the 2D plane and spliced in more parts according to the tolerance value, or also some inner cut will be added where possible
For very low tolerance for example you can get an upper and lower part for each formers couple. I hope I can release that feature in some weeks.
For higher tolerance or low curved external lines (the deek for example) you can have also only one part for the upper (or lower) sheetings
devFus, devFus Cam and devFus Foam will include this new feature
Old Mar 02, 2011, 05:21 AM
Sleedo's Avatar
USA, CT, Fairfield
Joined Jul 2004
Any upgrade path for owners of DevFus? I just bought DevFus to cut foam and now this is what I really needed
EB
Sleedo is offline Find More Posts by Sleedo
Old Mar 02, 2011, 05:31 AM
Italy
Joined Jan 2003
EB
The only upgrade available is from devFus to devFus Cam.
devFus Foam is a different application and does different things
But all the updates are for free, this is rather uncommon in the software world!
Old Mar 03, 2011, 12:24 PM
dpot's Avatar
Joined Dec 2005
can i add it to my usb with all my other dev software
Old Mar 03, 2011, 12:27 PM
Italy
Joined Jan 2003
If you already own my Usb key you can buy the license of devFus Foam and I'll tell you how to store it inside the Usb key
Discussion RCSpeedo: Doppler speedometer for PC/Android/iPhone neonbjb Electric Ducted Fan Jet Talk 700 May 02, 2013 08:24 PM
Discussion New doppler speedometer application for windows and android! neonbjb Foamy EDFs 51 Jun 10, 2012 04:27 AM
Discussion The NEW FHSS-3 Airtronics 6 channel RX has released cody303 Multi Task F3X 11 Dec 29, 2010 03:53 PM
Help! New member application Gupllc Gilbert Quiet Flyers (Arizona) 16 Oct 16, 2010 02:02 AM
Discussion devFus, the new application to draw fuselages durone CAD/CAM 101 Apr 18, 2010 04:33 AM
