This thread is privately moderated by skunkworks2006, who may elect to delete unwanted replies.
Old Dec 22, 2010, 08:14 AM
define("BEASTMODE", "1");
KeithLuneau's Avatar
United States, LA, Moreauville
Joined Jan 2002
Well, knowing that the wind will be blowing everyday for the rest of the week (at least according to the weather forecast) I decided to test fly PAM this morning. It's overcast and foggy, but dead calm. I wanted to see how the GoPro would handle the conditions anyway, so it was a win/win... With the pan/tilt mounted on the CG, I can fly with or without the camera mounted, so I left it off for the first flight.
I took off, gave it about 4 clicks of left trim, and it was good! A few clicks above half throttle seems to be the sweet spot for cruising. Man it sure is a smooth plane! I cut the rates back to low and just cruised around for a little while. I then started playing around with high rates, and slow speeds, etc. High rates made it quicker to respond, but the roll rate is by no means enough for me to attempt an aileron roll and be comfortable doing it... I expected that though. It doesn't glide as good as I'd hoped though. Cut the throttle and it comes down pretty quick. I guess all that draggy gear has a lot to do with it! This wing on the glider fuse would glide forever! Landing was a piece of cake, came in real nice and smooth, flared to a soft touch down and short roll out. Perfect!
So, I strapped on the GoPro and a fresh battery, and took off again. This time I hand launched it so no water sprayed onto the lens while taking off. (The grass was wet with dew.) I flew it around for about 10 minutes then landed. It's really a nice plane to fly! Nice and smooth, just sit back and enjoy the view.
The angles are not just right though, there's a bit of change in the pitch trim with power on and off. No change in roll, so that's good. Trim it for cruising and all is well. Power up some more and it climbs, but not too fast, kinda what you'd expect. Cut power back though, and the nose starts dropping quick. This is with the elevator flat, so I don't want to just trim it with the elevator then put some down thrust on the motor. I'd rather see if I can take it out with the wing incidence. It's not real hurry though, it flys great as is, just not quite perfect.
Video will have to wait though, I'm dead tired. Pulled an all nighter, now it's time for a nap...
KeithLuneau is offline Find More Posts by KeithLuneau
Old Dec 22, 2010, 10:34 AM
skunkworks2006's Avatar
Michigan
Joined Nov 2006
Glad to hear it went well, Keith! I like "PAM" aka Non-Stick.
It's a real pleasure when one of your own ideas or creations comes to life... and actually works!
skunkworks2006 is offline Find More Posts by skunkworks2006
Old Dec 23, 2010, 12:27 AM
Joined Jan 2002
Here's the video as promised!
FPV Slow Stick with a new wing... (10 min 2 sec)
Old Dec 23, 2010, 07:33 PM
Flying FPV from the lab.
aaron_gx's Avatar
Canada, AB, Lethbridge
Joined Jun 2008
pam flies great!
aaron_gx is offline Find More Posts by aaron_gx
Old Dec 23, 2010, 09:23 PM
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
http://www.youtube.com/watch?v=8wOlCgjUWS4
Looks great Keith!
Seems very stable.
Is that a wood prop! Cool
What's the little blue blinky light? Low batt?
Enjoyed the fly-bys.
Man I *wish* I had a farm or acerage to fly at.
Looks like a great place to do some range tests.
galaxiex is offline Find More Posts by galaxiex
Old Dec 23, 2010, 09:37 PM
Joined Jan 2002
Yep, wood prop, a Turnigy beechwood prop. Not the best, but it took a little load off the motor which I needed, and is balanced great, so it stayed. I am thinking about swapping motors with my Easy Star though. It's got a nice outrunner from Grayson Hobby on it, and it's overkill for the EZ*. That one cruises at about 1/4 throttle and goes ballistic at full! I think it might work better on this one, so the motor doesn't come down so hot! Not in a big hurry though, I'd have to redo the motor mount and all that.
The blue LED is on the low battery warning thing. Solid blue is full charge, blinking blue is mid range, solid red is low, flashing red and beeping means land NOW! They're about $2-$3 at Hobbyking, or a couple dollars more at US retailers.
Old Dec 23, 2010, 10:08 PM
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Smooth Keith, would love to be able to just wake up and fly in my own backyard, i'm jealous haha.
Do you have Links to the build?, also, did you fly the Willi "B" that's in your blog?.
Cheers, Kev.
Edit: Whoops, that blog was from 08.
Kev.au is offline Find More Posts by Kev.au
Old Dec 23, 2010, 10:16 PM
Joined Jan 2002
Yeah, that was back in '08 when I was working on the Willi B. I've flown it a number of times now, it's a great little sport plane! I've got some videos up on Youtube... Here's the last one:
http://www.rcflighttest.com/home/201...biplane-video/
(linked to my blog page so it doesn't embed here, getting off topic... lol)
Old Dec 23, 2010, 10:31 PM
What? Not a T-Rex!!!
dolbydarma's Avatar
USA, CO, Colorado Springs
Joined Mar 2008
PAM Camera?
What camera are you using... I noticed the prop isn't showing up on the vid. Nice touch!
dolbydarma is offline Find More Posts by dolbydarma
Old Dec 23, 2010, 10:35 PM
Joined Jan 2002
It's a GoPro Hero HD. I'm guessing the prop isn't showing up because of the slow shutter speed in the less than favorable lighting. It was kinda early and foggy that morning.
Old Dec 24, 2010, 07:58 AM
shredding the skies
boardman's Avatar
Wet Coast Canada
Joined May 2005
Great setup. Very smooth. Looks like you can go forever in your area. Nice cheap way of seeing your battery level without needing OSD too. Thanks.
boardman is online now Find More Posts by boardman
Old Dec 24, 2010, 10:23 AM
dolbydarma's Avatar
Joined Mar 2008
What setting are you using on your GoPro? I have one as well, but I get the prop squiggles in the video.
Old Dec 24, 2010, 12:04 PM
Joined Jan 2002
Mine is whatever the defaults are with the updated firmware, using R3 (720 60fps). The prop does show up and do the "mini blind" thing in bright light though.
Old Dec 25, 2010, 06:57 AM
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
teflon...errr....Pam flies nice! I like it!
Derek_S is offline Find More Posts by Derek_S
Old Dec 25, 2010, 10:37 PM
Michigan
Joined Nov 2006
where are the moderators to make this thread a stick????
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 54 Apr 18, 2011 09:31 AM
Gallery Show us your plane! (Part 2) skunkworks2006 Video Piloting (FPV/RPV) 2585 Dec 09, 2010 11:04 AM
Discussion Show us your fleet. lovegroove Video Piloting (FPV/RPV) 3 Sep 28, 2010 01:42 PM
Gallery Show us your workshop or man cave! TopSecretBoats Racing Boats - Internal Combustion 10 Sep 25, 2010 12:08 PM
Discussion Show Us Your Clumpy Grass Chophop Electric Plane Talk 11 Sep 24, 2010 10:15 PM
