This thread is privately moderated by skunkworks2006, who may elect to delete unwanted replies.
Old Dec 13, 2010, 07:02 AM
C GBEN is offline
Find More Posts by C GBEN
Flying is freedom
C GBEN's Avatar
Quebec,Canada
Joined Nov 2010
Tanks Funjet !!
C GBEN is offline Find More Posts by C GBEN
Old Dec 13, 2010, 03:30 PM
Blue Chip is offline
Find More Posts by Blue Chip
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
I never posted in the other... so here are my 2... well - 1-1/4 really.
The EasyStar is really starting to show its age. The wing has been broken, the nose crushed and split, the tail broken, managed to cut most of the way through the tail spar... it takes a beating! I figure I have over 200 hours of FPV stick time with it. It's coming in for a complete overhaul soon.
Multiplex EasyStar
Stock Tiny S servos for control surfaces
Thunderbird (CC) 54a ESC
CC 10a BEC
E-Flite 6 Series motor with a 6X4APC
Futaba 168DP rx with the antenna doubled
EZOSD
Enlarged rudder
A few cooling cutouts
CF stips on each axis (and used to reinforce where I broke the wing)
Cutout on the bottom with hatch
ReadyMade pod for the video gear
DPC480 camera
3300mah 3s
Sander LC Filter
900/500 mhz
HS65 servos
2dbi antenna
I will be upgrading the servos to HS65's as well for the control surfaces. The overhaul will also include a 1.5w 900mhz Vtx, an inverted V antenna, EZUHF 433 control.
The FunJet is a work in progress. I don't have all the parts yet - but the basic setup will be:
5.5 x 4.5APC prop
2700kv inrunner
10a CC BEC
CC 36a ESC
3300mah battery
HS65 servos for the control and pan (no tilt)
RMRC 520 camera
EZOSD
EZUHF
900/500 vtx - antenna undecided
I have a CF wing spar and a cf strip running along the belly
I may end up moving to 1.2g video - but I want to see the limits of the 900 gear.
Both in the hangar
Finally the work in progress ground station. Basically a Pellican case with the tracking module up top - I will be using the Immersion tracker as well. It will either have a Yagi or a Bi-Quad. I may put the yagi on a tracker and fix the bi-quad on the case - both running through an Oracle diversity.
Blue Chip is offline Find More Posts by Blue Chip
Old Dec 14, 2010, 09:07 AM
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
By the way....can we make this one a sticky any unstick the locked one?
Old Dec 14, 2010, 09:35 AM
Voguna is offline
Find More Posts by Voguna
Norway, Oslo
Joined Jun 2010
LOL! Your phone number on the wings, smart! I will do the same right away!
Voguna is offline Find More Posts by Voguna
Old Dec 14, 2010, 11:27 AM
AdamChicago is offline
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
Does anyone know of a system that allows all of this...or an example of how all of this has been integrated from multiple systems:
- Stabilization using gyro/accelerometer (no thermopile crap) ...good example: FY20
- OSD & autopilot (GPS, power sensor etc) ...good example RangeVideo
- Downlink telemetry (Antenna Tracker/Google Earth) ...good example: EZOSD
- Barometric altitude and airspeed ...good example: EagleTree
AdamChicago is offline Find More Posts by AdamChicago
Old Dec 14, 2010, 11:49 AM
skunkworks2006 is offline
Find More Posts by skunkworks2006
skunkworks2006's Avatar
Michigan
Joined Nov 2006
I've sent 2 requests to the moderators to do just that.
I haven't received any response.
skunkworks2006 is offline Find More Posts by skunkworks2006
Old Dec 15, 2010, 12:31 AM
dolbydarma is offline
Find More Posts by dolbydarma
What? Not a T-Rex!!!
dolbydarma's Avatar
USA, CO, Colorado Springs
Joined Mar 2008
First FPV
Here's my first FPV plane. 900mhz on Parkzone Radian using Spectrum DX6i. Camera set up with pan using the rudder input on the Rx... Actual rudder set up on Aileron channel. Video feed into splitter for 19" LCD and Digital Camcorder.
Here's the actual package I got:
http://hobbywireless.com/cart/index....products_id=22
Plus this camera:
http://hobbywireless.com/cart/index....products_id=12
Been working great, really happy with it. Now I am trying to improve my reception. Most of the time I get to see a crystal clear video, than once in a while I get lots of drops... Any ideas? Just looking for tweaks at this point... not a whole new system
Here's a short video of a really bad section:
http://www.youtube.com/watch?v=04M6RqRNrtY
Here's a nicer video showing how clear the reception can be from the same flight:
FPV Radian 12.10 (3 min 49 sec)
dolbydarma is offline Find More Posts by dolbydarma
Old Dec 15, 2010, 12:45 AM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Get a better antenna on the VTX. Those wips are junk. (not tuned well)
What are you using for the Rx antenna the same wip?
And hide your wires, any flapping will cause noise.
Martin Y is offline Find More Posts by Martin Y
Old Dec 15, 2010, 01:59 AM
ommadawn is online now
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Thats a GREAT picture.
ommadawn is online now Find More Posts by ommadawn
Old Dec 15, 2010, 02:09 AM
KeithLuneau is offline
Find More Posts by KeithLuneau
define("BEASTMODE", "1");
KeithLuneau's Avatar
United States, LA, Moreauville
Joined Jan 2002
Just thought I'd throw in a picture of my tried and true Slow Stick. I haven't flown it with the GoPro yet, but it's ready to go! This is the same one in my videos, that had the Sony board cameras on it in the past.
KeithLuneau is offline Find More Posts by KeithLuneau
Old Dec 15, 2010, 07:37 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I can already tell you what your problem is: antenna polarization. Your antenna needs to be straight up or your signal strength will be much less.
You can also upgrade to a much better antenna that will greatly improve performance. I fly an inverted Vee antenna as do many here on the FPV forum. It's easy to make, but I can make it for you if you need: http://www.rcgroups.com/forums/showt...php?t=1159968\
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Dec 15, 2010, 09:11 AM
dolbydarma's Avatar
Joined Mar 2008
V antenna!
I would love to take you up on your offer!!! Let me know what I need to send you. Thanks!
Old Dec 15, 2010, 03:42 PM
Chicago, IL USA
Joined May 2010
My bad, I meant to post this to Alex's antenna build string...
Alex, I need to bolt the biquad to an antenna tracker but I'm worried that putting 4 bolts (metal or plastic) through the middle of antenna is going to hurt performance...is that true or will this be ok?
Old Dec 15, 2010, 04:10 PM
C GBEN is offline
Flying is freedom
C GBEN's Avatar
Quebec,Canada
Joined Nov 2010
Bad thread sorry... :S
Old Dec 15, 2010, 05:14 PM
FPVJOCKEY is offline
Find More Posts by FPVJOCKEY
To Infinity and Beyond
FPVJOCKEY's Avatar
United States, CT, New Fairfield
Joined Dec 2010
Originally Posted by IL76MD View Post
HI guys,
here is my very slow flying SkyWalker with modified Solution wing (from mwcores.com). It's flying very stable and abs. good for air video and any slow flying actions (training and ....):
And watch a video clip, please. Sorry, it is a little long, but enjoy anyway.
http://www.vimeo.com/17649442
Hi IL76MD, Are you able to see your current draw? if so did it decrease with the larger wing?
My Skywalker draws about 9 amps at cruise I am trying to get it down in the 5-6 amp range. I think using a bigger wing will help.
FPVJOCKEY is offline Find More Posts by FPVJOCKEY
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 89 Dec 29, 2015 02:33 AM
Gallery Show us your plane! (Part 2) skunkworks2006 FPV Aircraft 2585 Dec 09, 2010 12:04 PM
Discussion Show us your fleet. lovegroove FPV Talk 3 Sep 28, 2010 02:42 PM
Gallery Show us your workshop or man cave! TopSecretBoats Racing Boats - Internal Combustion 10 Sep 25, 2010 01:08 PM
Discussion Show Us Your Clumpy Grass Chophop Electric Plane Talk 11 Sep 24, 2010 11:15 PM
