Old Feb 26, 2013, 08:03 PM
francoishaha is offline
Find More Posts by francoishaha
radian 4700
francoishaha's Avatar
Canada, QC, Saint-Hyacinthe
Joined May 2011
Still under construction, maiden planned for this week end.
I set the CG 1/2" behind the leading edge of the wing for the maiden... i hope this will be right. I need to make some air intake for the motor and it's ready to go!
francoishaha is offline Find More Posts by francoishaha
Old Feb 26, 2013, 08:48 PM
crazy1pilot is offline
Find More Posts by crazy1pilot
What goes up, must come down
crazy1pilot's Avatar
United States, MI, Midland
Joined Sep 2009
Should add a canard!I hope it flys as good as it looks
Crazy1
crazy1pilot is offline Find More Posts by crazy1pilot
Old Feb 26, 2013, 09:12 PM
ggtronic is offline
Find More Posts by ggtronic
AP-stick
ggtronic's Avatar
Montreal
Joined Nov 2005
video
ggtronic is offline Find More Posts by ggtronic
Old Feb 26, 2013, 10:59 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
damn that is a purdy plane!
CrashAffinity is offline Find More Posts by CrashAffinity
Old Feb 26, 2013, 11:37 PM
baconflyer is offline
Find More Posts by baconflyer
cheapskate extroardinairé
United States, CA, Marin
Joined Jul 2011
oooooh, seeeeeexy! looks like it will be nose heavy tho, maybe some canards are in order? either that or chop the nose down a bit. 1/2" seems pretty nose heavy to me.
baconflyer is offline Find More Posts by baconflyer
Old Feb 27, 2013, 07:38 AM
radian 4700
Joined May 2011
I made a .25 scale of the plane and made gliding test. Yes my plane is nose heavy, but experience tell me that i prefere a nose heavy trimmed up rather than a tail heavy for the maiden. And i go with the flow, i will put a canard.
Old Feb 27, 2013, 08:12 AM
TigerPilot is offline
Find More Posts by TigerPilot
Joined Jan 2005
The CG is not 'dependent' on the nose length. The CG depends on the wing design. I've never heard of a main wing with a CG of less than ~25% - 33%. At 1/2" from leading edge CG I think you'll need an elevator the size of mount Everest!
TigerPilot is offline Find More Posts by TigerPilot
Old Feb 27, 2013, 09:03 AM
radian 4700
Joined May 2011
I check the funjet cg and it look realy close to the leading edge...
Old Feb 27, 2013, 11:10 AM
signflyer is offline
Find More Posts by signflyer
2^p - 1
signflyer's Avatar
United States, MO, Springfield
Joined Feb 2003
Unless your wing is rectangular, it's incomplete to describe 'cg at 25%' or worse 'CG at 2in from LE'.
CG should be described at a percentage of MAC. For typical planes, 25% of MAC is a good estimate. For deltas, flying wings and others, it may not be.
signflyer is offline Find More Posts by signflyer
Old Feb 27, 2013, 11:21 AM
Joined Jul 2011
can you give us the dimensions of the wing? then we can help you with the cg. it looks to me like you have about an 8" chord, which means 1" from the leading edge would be a 12.5% cg, meaning you will be using constant up elevator. this will increase drag (reducing both top speed and efficiency) and also you will have to land very, very fast so as not to run out of elevator for the flare. I would recommend 2" back as a good starting place, then move it rearwards from there until it is a little too tail heavy for your liking, then move it forward a little bit. at this point, it should fly level at neutral elevator. good luck!
Old Feb 27, 2013, 11:36 AM
radian 4700
Joined May 2011
The wing have 43in wing span 12in root chord and 6.5in tip chord, zero sweep.
Old Feb 27, 2013, 11:42 AM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Ggtronic, awsome video btw.
I remember the nose ripping of ur polaris, in fact i was watching it from my fatshark google hehe, suddently a bunch of tree apear and then we heard a crack in the wood :-)
We were watching from the side. I remember how dark it was when he crashed.
Shadrack is offline Find More Posts by Shadrack
Old Feb 27, 2013, 12:02 PM
TNug is online now
Find More Posts by TNug
Waypoint Collector
TNug's Avatar
United States, NC, Raleigh
Joined Feb 2012
This is just one of many CG calculators I found Googling.
http://www.friendlyflyers.org/cg-calc.html
Here's the output from your wing dimensions and a 25% MAC:
I believe 25%MAC is still on the nose heavy end of the typical range. Hope it helps.
Cool looking plane by the way. Any details on construction technique, payload, components?
TNug is online now Find More Posts by TNug
Old Feb 27, 2013, 01:08 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
25% MAC as nose heavy??? for such a short wingbase that would be light... And create a more sensitive flight characteristic. I personally would start around 20% and work back as desired.
chanyote66 is offline Find More Posts by chanyote66
Old Feb 28, 2013, 06:42 PM
HawkHunter is offline
Find More Posts by HawkHunter
Psalm 37:4
HawkHunter's Avatar
Litchfield Park, AZ.
Joined Jun 2006
Crazy1
+1..........A canard would be a good thing!
HawkHunter is offline Find More Posts by HawkHunter
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 92 Jul 16, 2016 04:49 PM
Gallery Show us your plane! (Part 2) skunkworks2006 FPV Aircraft 2585 Dec 09, 2010 11:04 AM
Discussion Show us your fleet. lovegroove FPV Talk 3 Sep 28, 2010 01:42 PM
Gallery Show us your workshop or man cave! TopSecretBoats Racing Boats - Internal Combustion 10 Sep 25, 2010 12:08 PM
Discussion Show Us Your Clumpy Grass Chophop Electric Plane Talk 11 Sep 24, 2010 10:15 PM
