Old Jan 21, 2013, 10:09 PM
benderfly is online now
Find More Posts by benderfly
benderfly's Avatar
Joined Sep 2007
Skywalker #1
My first Skywalker has been converted to nightflight duty. She has many, many daylight miles... now ready for the spring and most likely the cause of some UFO reports out here in the boonies.
benderfly is online now Find More Posts by benderfly
Old Jan 21, 2013, 11:06 PM
ls1elite is offline
Find More Posts by ls1elite
ls1elite's Avatar
United States, FL, Miami
Joined Oct 2012
my skywalker
decided to take a pic of it today after installing the gopro and the vee antenna.
ls1elite is offline Find More Posts by ls1elite
Old Jan 22, 2013, 05:04 AM
Vintabilly_NS is offline
Find More Posts by Vintabilly_NS
..in a Johnny Cash voice.
Vintabilly_NS's Avatar
Canada, NS, Beaver Bank
Joined Aug 2010
It's a lot easier to find a downed plane in the snow.
Don't delay your happy until spring, get some hours on her, she looks great.
It's -14C this morning but the winds are down and the snow is fresh..fly-on.
Vintabilly_NS is offline Find More Posts by Vintabilly_NS
Old Jan 22, 2013, 06:29 AM
angry is offline
Find More Posts by angry
Work less, fly more!
Australia, WA, Broome
Joined Aug 2012
Hello Is 1 elite, if you can get the inverted vee and tx as far away from all other equipment as you can, it will work where you have it but it will work much better away from the gopro and other camera. good luck at the weekend. the inverted vee rocks!
angry is offline Find More Posts by angry
Old Jan 22, 2013, 09:47 AM
houstonderk is offline
Find More Posts by houstonderk
United States, MD, Clinton
Joined Oct 2010
Just finished up my Twinstar II after getting the rest of my parts.
Running on 3-4S 5000mah main battery along with a 3s 1200 accessory battery on board, 1.3ghz video, 2.4 for the FY ground station, 12ch dragonlink for plane.
Got the ground station on 3s 8000mah battery running the myflydream AAT with dual diversity.
I flew this plane with 2.4 video for a couple weeks to get the FY autopilot working right but decided to try 1.3 for the video since the FY ground station was running on 2.4. After doing final testing and it's good to go I will try some paint or stickers to cover the wires and what not.
Sorta boring video of it before changing to 1.3. I wanted to see how the actual airframe flew before putting more things on it.
fpv twinstar II 3 (12 min 7 sec)
houstonderk is offline Find More Posts by houstonderk
Old Jan 22, 2013, 10:27 AM
baconflyer is offline
Find More Posts by baconflyer
cheapskate extroardinairé
United States, CA, Marin
Joined Jul 2011
what's a weeend?
baconflyer is offline Find More Posts by baconflyer
Old Jan 22, 2013, 04:31 PM
signflyer is offline
Find More Posts by signflyer
2^p - 1
signflyer's Avatar
United States, MO, Springfield
Joined Feb 2003
Here's my latest iteration of the Lemma series - this one is 53" WS with a KF airfoil. The KF didn't meet my expectations, so I'm currently rebuilding a traditional flat bottom, airfoiled wing.
Currently flying 1.2 vid gear, a 600TVL cam, Remzibi OSD, and DragonLink.
signflyer is offline Find More Posts by signflyer
Old Jan 22, 2013, 10:38 PM
ls1elite is offline
ls1elite's Avatar
Joined Oct 2012
angry thanks for the info. im planning to put the video tx in the back by the propeller on my skywalker. the reason why i did no want to mount it there is because is near my dragonlink antenna wich is mounted on the tail.. any inputs ?
Old Jan 22, 2013, 10:41 PM
ls1elite is offline
ls1elite's Avatar
Joined Oct 2012
skywalker with 1880 wings : )
Old Jan 24, 2013, 08:22 AM
angry is offline
Joined Aug 2012
My bixler has the tx as you do behind the propeller and the inverted vee on the side of the fin but I have the DL antenna mounted to a small bamboo skewer at the wing root. I did start with the skewer in fuselage at the leading edge, try to keep both antennas away from everything electronic and each other. Sometimes difficult but well worth the time.
Regards angry.
Old Jan 24, 2013, 10:42 PM
ww1ep is offline
Find More Posts by ww1ep
ww1ep's Avatar
Joined Feb 2010
video piloting fpv
Originally Posted by chanyote66 View Post
9" is the largest on the stock motor position. If you install a 12mm longer motor you can go to 10"
Im using an APC8x6 and can easily fly 1 hour on 5300mah 4S
Heres its 45min flight using 4100mah.
http://www.youtube.com/watch?v=KRF-HS9LU9E
Chris
nice video...im enjoy with it...
ww1ep is offline Find More Posts by ww1ep
Old Jan 25, 2013, 08:00 AM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
Well... Heres my Second Super Sky Surfer... Almost complete but the first flew so well (till it met its fate) that I am taking more time on this one... Full night flight setup getting two FPV cameras (One 3.8mm and a 25mm lens)
Description: Name: IMG_0127[1].jpg
Description: Name: IMG_0129[1].jpg
Description:
And my most reliable wing... Its been through just about everything... Trees, Walls, Powerlines, Street lights, Street signs, and a river... Still going like the day I built it
For only 900g it carries a Sony AS10 and only uses a 130w motor
Description:
Chris
chanyote66 is offline Find More Posts by chanyote66
Old Jan 25, 2013, 11:48 AM
Michael_73 is offline
Find More Posts by Michael_73
United States, AL, Madison
Joined Aug 2011
Radjet 420 FPV
I built two FPV versions of this plane with an interchangeable 1 gr Foxtech camera that is powered by a separate 150mAh 1 S Lipo.
The first plane is basically the stock plane, I just added a 200mW 5.8Ghz module from fpvhobby.com. The wire antenna works fine within the range I need ( < 300m). On the first flight the picture was perfect all the time.
The second plane was some kind of an experiment. Since I am not a very experienced pilot, I thought I should try building a Radjet 420 with a safety back-up. I built it from spare parts and adding some extras:
Eagletree 2D/3D stabilizer
200 mW 5.8 Ghz from fpvhobby
10 g motor for more thrust
homemade cloverleaf
V8R7-II receiver from Fr-Sky (range 1500+ m)
The Eagletree Guardian works well in this small plane. Flying is very easy. And with the mode switch (self stabilization in 2D mode) the Guardian saved the plane twice when I lost orientation on my maiden (no FPV though).
Disadvantage: Due to the weight ( ~100 g) and the power consumption the 240mAh 2S battery from Hyperion only lasts about 3 minutes.
Michael_73 is offline Find More Posts by Michael_73
Old Jan 28, 2013, 01:33 PM
TNug is online now
Find More Posts by TNug
Waypoint Collector
TNug's Avatar
United States, NC, Raleigh
Joined Feb 2012
Originally Posted by Drinkes View Post
Great flying!
I posted my plane already.
Attachment 5353847
New plane for new 2013 season.
It very similar to the Skywalker, slightly larger. More sound aerodynamics, I think.
Attachment 5353853
Attachment 5353852
Attachment 5353854
Attachment 5353855
Attachment 5353856
Drinkes,
Your post is relatively old by now, but I just came across it. That is a great looking plane. Very nice efficient looking Skywalker-type plane. Any details? Build log? Flight updates?
TNug is online now Find More Posts by TNug
Old Jan 28, 2013, 06:36 PM
1fullbird is offline
Find More Posts by 1fullbird
1fullbird's Avatar
United States, NE, La Vista
Joined Nov 2011
Originally Posted by TNug View Post
Drinkes,
I went to his YouTube posts--I think he's the Ukraine. It does look like a sleek aircraft though. Comes apart for transporting?
1fullbird is offline Find More Posts by 1fullbird
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 92 Jul 16, 2016 04:49 PM
Gallery Show us your plane! (Part 2) skunkworks2006 FPV Aircraft 2585 Dec 09, 2010 11:04 AM
Discussion Show us your fleet. lovegroove FPV Talk 3 Sep 28, 2010 01:42 PM
Gallery Show us your workshop or man cave! TopSecretBoats Racing Boats - Internal Combustion 10 Sep 25, 2010 12:08 PM
Discussion Show Us Your Clumpy Grass Chophop Electric Plane Talk 11 Sep 24, 2010 10:15 PM
