Old Dec 27, 2012, 09:45 AM
zanek is offline
Find More Posts by zanek
Agressive driver
United States, CA, Santa Barbara
Joined Jun 2011
IR blocking does tend to make the colors more vivid, because in IR light everything looks black and white.
Originally Posted by DJO View Post
Ummm.... interesting? You can always change the settings with the PZ0420's OSD thingamabob to get a different picture you know
Dan
zanek is offline Find More Posts by zanek
Old Dec 27, 2012, 10:56 AM
aaronredbaron is offline
Find More Posts by aaronredbaron
Spektrum Dev Team
aaronredbaron's Avatar
United States, IL, Champaign
Joined Apr 2002
Originally Posted by turbodriven View Post
This holiday season our family is experiencing what we'll call a "financial setback". So instead of a buying a few new planes to put under the Christmas tree I decided to dust off some old LOS planes I had in my garage and convert them to FPV instead.
First one is an old Stryker I've had for years. I gutted it and then lobbed off the nose and put a "Zephyr like" pod on the front to hold the Gopro and PZ0420 camera. All up with the 3000mah 3s battery, Gopro2, and a Cyclops OSD onboard it weighs in just under a kilogram (or a shade over 2lbs.). Launching is precarious (always has been with this plane) and it's a bitch to keep trimmed at different speeds, but once she gets on step it flies great. Climbs steady at 15-20 fps on 11-12 amps using an RCTimer BC-2826/6 2200kv motor/APC 6x4 prop combo. Acts just like a typical wing does in flight too. The only thing I still want to do is cut some depron triangles to put just aft of the "pod" and make it a bit more aerodynamic.
I built a similar wide-body Stryker for FPV, and I might have a solution for you to help with handling... I found that with the added surface area to the center the wing became very pitch sensitive, especially at speed. My solution was to add a horizontal stab between two vertical stabs similar to the stock ones. I used a standard elevator too and switched the elevons to conventional ailerons... this smoothed out the flight performance considerably, and the only reason I'm not flying it much now is its kinda slow and boring, but its far more stable and fun to fly than when I first widened it and flew it with elevons...
aaronredbaron is offline Find More Posts by aaronredbaron
Old Dec 27, 2012, 08:38 PM
trexpilot is offline
Find More Posts by trexpilot
trexpilot's Avatar
Australia, WA, Perth
Joined Feb 2006
Thanks for the video Turbodriven
looks like lots of fun mate
trexpilot is offline Find More Posts by trexpilot
Old Dec 27, 2012, 08:41 PM
trexpilot's Avatar
Joined Feb 2006
Hi aaronredbaron,
your suggestions to add horizontal stabs, would that be just beetwen the original verstical stabs in original location or did you use twin boom to extend the vert stab then fit the horizontal stab/elevator
i always wonder how the stryker would behave with extended boom n elevator unit, bit like dh vampire style
hmmm wonder if the hk vampire stabs/elev would fit stryker easy
Rex
Old Dec 28, 2012, 12:19 AM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
Just finished my Bullet proof EPS wing. Entire wing is wrapped in Fiber tape, Carbon Fiber Spar, and all Gorilla glued.
Starting with this little 2000kv motor on a 3s 1000mah lipo.
If i get too much interference from the Aluminum tape it will be replaced with 3m laminate.
Description:
Description:
Chris
chanyote66 is offline Find More Posts by chanyote66
Old Dec 28, 2012, 12:29 AM
rancidsquirrel is offline
Find More Posts by rancidsquirrel
rancidsquirrel's Avatar
Joined Aug 2010
Wow- that propeller! I can only imagine the sound that thing makes
Attachment 5401025
Attachment 5401026
Chris
rancidsquirrel is offline Find More Posts by rancidsquirrel
Old Dec 28, 2012, 12:38 AM
chanyote66's Avatar
Joined Dec 2011
lol... ya its not a quiet one... I cut and balanced a 9x5x3 down to 4x5x3
Chris
Old Dec 28, 2012, 07:45 AM
turbodriven is offline
Find More Posts by turbodriven
100mph club member
turbodriven's Avatar
NW O-town
Joined Jun 2005
Chris
It almost looks like an impeller taken out of an EDF.
LOL.
turbodriven is offline Find More Posts by turbodriven
Old Dec 28, 2012, 01:11 PM
TexasAggie is offline
Find More Posts by TexasAggie
Gig 'Em!
TexasAggie's Avatar
United States, TX, College Station
Joined Nov 2010
Here are some photos of my newly-complete Skywalker. Flies like a champion.
Motor is a 920 kv swinging a 10x6 on 4S.
Plenty of mods including slotted flaps, carbon strips for extra rigidity, Dubro hardware all around, and upgraded motor mount.
I haven't flown FPV with it yet, but will very soon (would be out right now if the wind weren't 20+ knots).
TexasAggie is offline Find More Posts by TexasAggie
Old Dec 28, 2012, 05:08 PM
chanyote66's Avatar
Joined Dec 2011
LOL.
just about...
Got a maiden today... had to drop the throws to 20% with 40% expo just to keep it calm.
with a half used 3S battery it got to 45mph which this small was scary... going to try it Full FPV tomorrow.
Chris
Old Dec 28, 2012, 06:20 PM
Vintabilly_NS is offline
Find More Posts by Vintabilly_NS
..in a Johnny Cash voice.
Vintabilly_NS's Avatar
Canada, NS, Beaver Bank
Joined Aug 2010
Originally Posted by rizzaair View Post
Video tx is hobbyking 200mw, im getting well over a mile range!!
bonus pics of the wife all glamed up for her 30th tonight
Nice set of heels.
Vintabilly_NS is offline Find More Posts by Vintabilly_NS
Old Dec 28, 2012, 06:26 PM
Joined Aug 2010
Thanks! And yup, the PZ0420 is what I use. Best FPV cam I've ever used
Dan
ok hot shot. Your videos looks freakin' sweet. What are you using for a ground recorder and what settings on the pz0420? If we're using the same kit I'm doing something wrong.
Old Dec 28, 2012, 08:37 PM
KillerCut is offline
Find More Posts by KillerCut
USA, NY, Brooklyn
Joined Jan 2002
I'd like to know too DJO / Dan... Settings and also what ground recorder...?
KillerCut is offline Find More Posts by KillerCut
Old Dec 29, 2012, 02:03 AM
kstmark is offline
Find More Posts by kstmark
Kostas
kstmark's Avatar
Greece
Joined Sep 2008
just about...
Chris
It ll be great for fpv. I had a similar one. Very low flying behind cars was the best feeling
Use the inner hole of your servo horn. If you use only 20% of throws you loose sensitivity
kstmark is offline Find More Posts by kstmark
Old Dec 29, 2012, 03:52 AM
Hasi is offline
Find More Posts by Hasi
Hasi's Avatar
Austria, Stmk., Graz
Joined Sep 2011
Here is my small drone:
I get 40 minutes of flight time on a single 2200mah 3S lipo (maybe more if I don't push it that hard).
Hasi is offline Find More Posts by Hasi
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 89 Dec 29, 2015 01:33 AM
Gallery Show us your plane! (Part 2) skunkworks2006 FPV Aircraft 2585 Dec 09, 2010 11:04 AM
Discussion Show us your fleet. lovegroove FPV Talk 3 Sep 28, 2010 01:42 PM
Gallery Show us your workshop or man cave! TopSecretBoats Racing Boats - Internal Combustion 10 Sep 25, 2010 12:08 PM
Discussion Show Us Your Clumpy Grass Chophop Electric Plane Talk 11 Sep 24, 2010 10:15 PM
