Old Dec 03, 2012, 09:53 AM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
DFloth,
thats a sweet Penguin setup you got there:-)
p.s.
is a 3s Lipo too much for that Motor?
That Prop maybe too much?
rclab1 is offline Find More Posts by rclab1
Old Dec 03, 2012, 10:18 AM
xxD-Manxx is offline
Find More Posts by xxD-Manxx
Go Fly Yourself...!!
xxD-Manxx's Avatar
United States, WA, Bonney Lake
Originally Posted by rclab1 View Post
DFloth,
p.s.
Thanks RCLab...
Watt meter shows it's running under motor limits and this is the third FPV plane I've used this motor/prop combo on without issue. Works like a champ!
D-Man
xxD-Manxx is offline Find More Posts by xxD-Manxx
Old Dec 03, 2012, 11:40 AM
rclab1 is offline
USA
Joined May 2010
DFloth,
that is sweet setup!
I've heard and read that the stock 2218 (bigger motor) with 9x6 prop and 4s Lipo
goes almost vertical
I will most likely opt for that.....
p.s.
cant wait for your vids....
I wanna' see how that power setup gets going;-)
Can you show images of the interior? I want to see how you placed
your gear inside:-)
Thank You much much!!!!
Old Dec 04, 2012, 10:35 AM
Twiggs is offline
Find More Posts by Twiggs
Lifeguard
The Netherlands
Joined Jun 2012
Hey guys,
Haven't been very active on the forums lately. But here is my new Bixler equipped with a LRS from IRC. Using a div 5.8ghz rx/tx from Foxtech.
I maidened it with my GoPro two days ago, flying LOS at that moment. I'm prepairing for a long range flight pretty soon.
I don't know if it's appropriate to include the YouTube video here, but you can view it here.
Cya!
Just noticed that it's my first post! What a shame! I was lurking al the time haha.
I'll be introducing myself now in another part of the forum.
Twiggs is offline Find More Posts by Twiggs
Old Dec 05, 2012, 09:46 AM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Raptor FPV.
blueprint is offline Find More Posts by blueprint
Old Dec 05, 2012, 11:15 AM
rclab1 is offline
USA
Joined May 2010
blueprint.
Is that the version 2 Raptor?
(I believe the motor mount has more thrust angle....the motor shaft is pointed to the sky more)....the v.1 had pitching issues when different throttle % was applied....
Just askin' :-)
Old Dec 05, 2012, 07:24 PM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
blueprint.
Just askin' :-)
V2. Just got it a week ago from hobbyking.
Old Dec 05, 2012, 08:20 PM
swartzracing is offline
Find More Posts by swartzracing
Aerial Operator
United States, CA, Sacramento
Joined Feb 2012
Almost Finished with my Penguin!
Took my time on this build to help save time troubleshooting in the long run!
Still need to setup and mount my FY31AP with Hornet OSD.
All the servo, video, and GPS cables are shielded and grounded! I'm running a bevrc 1.3 800mw system with bluebeam antennas. I will be running 72mhz corona rp8d1 for control until I upgrade to UHF. I will also be adding a GPS tracker in case all else fails.
Hope you guys like the color scheme!
swartzracing is offline Find More Posts by swartzracing
Old Dec 05, 2012, 10:02 PM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Nice color scheme!
Old Dec 06, 2012, 12:12 AM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
Finally got a pic of my Super Skysurfer... Iv been too busy flying to get pics
yup thats a Cal-King bed
Description:
chanyote66 is offline Find More Posts by chanyote66
Old Dec 06, 2012, 05:02 AM
rclab1 is offline
USA
Joined May 2010
chanyote66
Nice SSS, what is the biggest prop that can fit on that plane?
8", 9"?....thanks
Old Dec 06, 2012, 05:15 AM
loopFPV is offline
Find More Posts by loopFPV
censored
Joined Oct 2011
ASW 17 2100mm - custom by loopFPV
Before:
After:
Some spec:
Fy20 stab.
2x 1400kv turnigy 8" apc prop
2x 35-40A HK ESC
2x 2200 mAh 3S turnigy
1x 1000 mAh 3S turnigy for AV
OSD Remzibi with GPS
Power sensor PitLab 50A
FrSky
Short video:
ASW17 2100mm custom by loopFPV (2 min 2 sec)
Long video
ASW-17 FPV (14 min 17 sec)
So... like You see it was very hard to pack a lot of stuff in very small space, but now this is very very fast glider with two engines 1400kv, and I can fly very fast, or very slow. 2 x 2200 mAh can give long distance in short time.
loopFPV is offline Find More Posts by loopFPV
Old Dec 06, 2012, 10:50 AM
Drinkes is offline
Find More Posts by Drinkes
Ukraine, Crimea, Ordzhonikidze
Joined Jul 2012
Great flying!
I posted my plane already.
Description:
SkyMaster (1 min 19 sec)
Now for ending my first FPV summer season, video from it.
2012 FPV 1 season (3 min 51 sec)
Sorry for music.
New plane for new 2013 season.
It very similar to the Skywalker, slightly larger. More sound aerodynamics, I think.
Description:
Description:
Description:
Description:
SkyM_vs_Sky
Drinkes is offline Find More Posts by Drinkes
Old Dec 06, 2012, 11:24 AM
chanyote66's Avatar
Joined Dec 2011
chanyote66
8", 9"?....thanks
9" is the largest on the stock motor position. If you install a 12mm longer motor you can go to 10"
Im using an APC8x6 and can easily fly 1 hour on 5300mah 4S
Heres its 45min flight using 4100mah.
SSS FPV - Sunset over Oak ridge (9 min 15 sec)
Chris
Old Dec 07, 2012, 05:55 AM
goodkebo is offline
Find More Posts by goodkebo
goodkebo's Avatar
United States, ME, Bar Harbor
Joined Jun 2011
Originally Posted by loopFPV View Post
Before:
After:
Some spec:
Fy20 stab.
2x 35-40A HK ESC
FrSky
Short video:
http://www.youtube.com/watch?v=dwd1uycVe_4
Long video
http://www.youtube.com/watch?v=VOWlvzFCtXM
Awsome! I was thinking of converting a glider like that. How did you do your motor mounts? What kind of flying time do you get? What is the wing span of plane? Thx
goodkebo is offline Find More Posts by goodkebo
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 89 Dec 29, 2015 01:33 AM
Gallery Show us your plane! (Part 2) skunkworks2006 FPV Aircraft 2585 Dec 09, 2010 11:04 AM
Discussion Show us your fleet. lovegroove FPV Talk 3 Sep 28, 2010 01:42 PM
Gallery Show us your workshop or man cave! TopSecretBoats Racing Boats - Internal Combustion 10 Sep 25, 2010 12:08 PM
Discussion Show Us Your Clumpy Grass Chophop Electric Plane Talk 11 Sep 24, 2010 10:15 PM
