Old Oct 08, 2012, 12:26 AM
ecworks is offline
Find More Posts by ecworks
Marshall Islands, Enewetak Atoll
Joined Sep 2011
Twin motor Raptor FPV mod
Working on my 2nd Raptor and decided to ditch the single motor mounted on the tower (got tired of the downward pitch on launch) and installed 2 x 1100 kv outrunners. What an improvement!
ecworks is offline Find More Posts by ecworks
Old Oct 08, 2012, 12:27 AM
ecworks is offline
Joined Sep 2011
Twin Motor Raptor 3 blade prop test 2 (0 min 20 sec)
Old Oct 08, 2012, 12:30 AM
ecworks is offline
Joined Sep 2011
2 x Turnigy 1100 kv 300w outrunners w/2 x Master Airscrew 8" counter rotating 3 blade props (8x6) W/3 cell battery the combination draws less than 350w and a total of 34 amps while producing 4 lbs 12 ounces thrust. All up weight with battery is 3 lbs 6 oz.
Using 2 x 20amp ESC's.
Old Oct 08, 2012, 12:47 AM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
I liked my Last plane so much I decided to make a few spares...
These all include a slight change to give a little more stability and slow the wing down for longer more relaxing flight.
Root Chord: 14"
Tip Chord: 7.5"
Wingspan: 52"
Sweep Distance 12.5"
Thickness: 1.8"
8'x4'x2" sheet at lowes = $25
Cut into 5 18" sections (With a little extra) Thats $5 a wing! plus a $3 carbon spar and Gorilla Glue.
Just a little sanding, finish work, and electronics... they will be ready to go!
Each is getting a different motor for testing, 1 is getting a 3536 AeroDrive 1350kv 10x4.7 and 10x6 folding prop, 1 is getting a Generic 200W 1100kv 8x3.7 and 8x6 prop, 1 is getting a 1200kv Dynam 8x3.7 and 8x4 prop. We will see how it goes! Oh and the last gets a 2200kv 350 watt Turnigy with a 6x4 prop (Same as the prototype setup...)
FPV over Oak Ridge TN pt.3 - Flown with DragonLink (6 min 41 sec)
chanyote66 is offline Find More Posts by chanyote66
Old Oct 08, 2012, 01:15 PM
baconflyer is offline
Find More Posts by baconflyer
cheapskate extroardinairé
United States, CA, Marin
Joined Jul 2011
i dug out my old easystar, gave it ailerons (and a bigger horizontal and vertical stabiliser) and made the motor mount higher so i can use a bigger (9x5) prop on a 650 watt motor. works well, just trying to get the thrust angle right (atm, at WOT it will not turn left, full left is barely enough to keep it straight at WOT. gonna try a tx mix, more throttle=more left. anyone got any ideas?
baconflyer is offline Find More Posts by baconflyer
Old Oct 08, 2012, 01:36 PM
chanyote66's Avatar
Joined Dec 2011
I have a wing that needed counter weight due to torque. I added a few grams to the wingtip, then mixed my control surfaces to compensate when the motor was off. Worked good, but took quite a bit of work.
Old Oct 08, 2012, 01:43 PM
Joined Jul 2011
thanks, i'll try that. so, weight on the left wingtip, then a mix to have it go right at no throttle? only problem i can see is that it would make inverted flight impossible.
Old Oct 08, 2012, 03:11 PM
chanyote66's Avatar
Joined Dec 2011
Yes, weighting the wing will make inverted a nightmare. you could manually trim the control surface with added trim to roll counter of the throttle...
Old Oct 08, 2012, 09:05 PM
Ace4 is offline
Find More Posts by Ace4
Stick banger
Ace4's Avatar
USA, AZ, Chandler
Updates to the dollar tree foamboard plane that I posted a few weeks back:
- Upgraded from 150W motor to 450W motor
- Using 2x 3s2200mAh packs for power now
Obviously it's a lot heavier but still handles the weight well. With the improved power (close to 1:1 thrust/weight) I can hand launch it easily, no more needing someone else to do a running launch. Flight times have varied, the first few flights were 17 minutes, the one in the video below was only 11 minutes since I was at full throttle a lot. It cruises at 20mph at around 5A, so I could probably get close to a 30 minute flight if I went for duration. Wide open is 45A and 55mph.
I need to find somewhere more interesting to fly, flat desert isn't very exciting. It was windy, so not the smoothest video, but I posted it anyway:
FPV in the desert (11 min 11 sec)
Ace4 is offline Find More Posts by Ace4
Old Oct 08, 2012, 09:12 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
Flyzone Claypso glider, Done the LOS maiden this morning. Going for FPV maiden tomorrow morning
gundamnitpete is offline Find More Posts by gundamnitpete
Old Oct 09, 2012, 01:22 AM
Joined Jul 2011
i did that, but the ailerons aren't enough to make it able to turn left.
Old Oct 09, 2012, 02:52 PM
chanyote66's Avatar
Joined Dec 2011
hmmm... the only other option is finding a better motor pitch, or going to a higher KV with smaller prop...
Old Oct 09, 2012, 04:01 PM
Joined Jul 2011
i think i will just try a combination of weighting and aileron trim, i can't really afford a new motor right now.
Old Oct 09, 2012, 04:18 PM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
What is your amp use at level flight? Say safely above stall speed.
Shadrack is offline Find More Posts by Shadrack
Old Oct 10, 2012, 12:42 AM
ecworks is offline
Joined Sep 2011
Twin motor Raptor w/8" Master Airscrew 3 blade props
Raptor 2 flight with twin 3 blade props & GoPro (5 min 52 sec)
Discussion Show Us your US Navy Ship ! Chophop Life, The Universe, and Politics 89 Dec 29, 2015 01:33 AM
Gallery Show us your plane! (Part 2) skunkworks2006 FPV Aircraft 2585 Dec 09, 2010 11:04 AM
Discussion Show us your fleet. lovegroove FPV Talk 3 Sep 28, 2010 01:42 PM
Gallery Show us your workshop or man cave! TopSecretBoats Racing Boats - Internal Combustion 10 Sep 25, 2010 12:08 PM
Discussion Show Us Your Clumpy Grass Chophop Electric Plane Talk 11 Sep 24, 2010 10:15 PM
