Romania, Dolj, Craiova
Joined Sep 2007
![]() Please, recess camera as much as you can, and enforce the nose / leading edge under the camera with some balsa or, better, if you have some 1-2mm ABS, heat it with a gun until it's soaked and mold it on the wing nose. |
Latest blog entry: JRSky - birth of a dream radio
Multiplex FunJet FPV
This is my latest addition to the FPV fleet. I have three lightweight EasyStars (l and IIs), but with the windy autumn coming up, I felt that I needed something that would penetrate the wind better:
![]() AUW is 520gr with a 2826mm 1900kv outrunner, a 1800mAh 3S LiPo and 200mW, 1040MHz VTx and cam. Flies very nicely, but she's a bitch to launch despite the low-power motor. Too much throttle, and she'll torque roll and lawn dart before you can compensate. I launch her at 30-40%, and then everything is (almost) fine. Why Multiplex prescribes 100% throttle on launch is beyond me...Video below is not that interesting, but note the torque roll on launch. I used about 50-60% throttle on that occasion:
I know the Bixler has been done to death but here is a quick pic of mine.
The camera pan mount is just a quick rough test one until my better camera from SC2000 turns up. Its an ARF model with a thicker wing spar and a 6x4E prop. 200mw 5.8ghz video and corona 2.4ghz RC gear. It should serve me well for the casual FPV flying I have planned for it.
I am building some Z2 style skids for it, but so far its done great. Even if i recessed it into the EPS it would hit on impact because of the planes speed and softness of the foam. I would have to take it back about an inch into the foam and then the wide angle will see more plane than view...
I have run those motors up to 1400watts at 100amps in EDF's. That version is the 2 turn version and should easily handle +50 amps at really great efficiencies(like, edging 90%). It should pull about the same as your current motor (30-40amps), but be more efficient overall. |
USA, NY, Brooklyn
Joined Jan 2002
I run a himax 2025-5300 at close to the 60,000rpm limit. I had 1 failure 2 days ago after like 3 years of using those motors, but I think it was a manufactering defect, the magnet cracked in half... They do run hotter, but they kick BUTT for insane speeds!!!
| Thread Tools | |
| Discussion Show Us your US Navy Ship ! | Chophop | Life, The Universe, and Politics | 54 | Apr 18, 2011 09:31 AM |
| Gallery Show us your plane! (Part 2) | skunkworks2006 | Video Piloting (FPV/RPV) | 2585 | Dec 09, 2010 11:04 AM |
| Discussion Show us your fleet. | lovegroove | Video Piloting (FPV/RPV) | 3 | Sep 28, 2010 01:42 PM |
| Gallery Show us your workshop or man cave! | TopSecretBoats | Racing Boats - Internal Combustion | 10 | Sep 25, 2010 12:08 PM |
| Discussion Show Us Your Clumpy Grass | Chophop | Electric Plane Talk | 11 | Sep 24, 2010 10:15 PM |
