Old Dec 08, 2010, 12:06 AM
flyzwell's Avatar
So Cal
Joined May 2008
Magnetic Induction Servos
I got this in my email today from Hobby King.
Mi Servos finally hit the market!
Until now servos have always relied on a potentiometer, however 'Pots'
have always been the root cause of many issues in servos,
from poor accuracy to eventual failure from wear.
Now there is a new type of servo that uses a Magnetic Rotary Encoder
instead of the old-school potentiometer to control servo arm position.
Link- http://hobbycity.com/hobbyking/store...dProduct=14828
flyzwell is offline Find More Posts by flyzwell
Old Dec 08, 2010, 10:18 AM
Burgeoning Metropolis of Tustin, MI!
Joined Feb 2010
Hmm... I wonder how they work... Is the servo case shielded or something? Magnetic induction... makes me think that magnetic hatches or other sources might mess with them.... anyone have any definitive info on these things??
Brandon
brandotoao is offline Find More Posts by brandotoao
Old Dec 08, 2010, 10:20 AM
Joined Sep 2009
It sounds like a system that makes a digital servo out of an analog radio signal, kinda like having some sort of module on a brushless motor that would allow a brushed motor controller to control it. That's what I think, but it's pretty much a guess.
sheik480 is offline Find More Posts by sheik480
Old Dec 08, 2010, 11:14 AM
Joined Feb 2010
Well, I don't think that that is the case.... from what I've read it seems most-likely that we're talking about a magnet on an output shaft that senses the rotational movement of the motor or the servo arm (motor more than likely). This sensing of the servo position was/is in typical servos done with a variable resistor/potentiometer... like a volume knob on a stereo... it senses when you twist, and what way you twist, and how far you twisted... and adjusts the volume accordingly....
The magnetic sensor would be much like the crankshaft position sensor, or crank angle sensor, in an automobile engine... The flywheel, or camshaft, or crank (all = motor output) has a toothed gear on it and a little magnetic (hall effect) sensor on it that tells how fast the motor is spinning by the magnetic pulses (caused by the metal in the gear being closer then farther as the gear teeth spin around.. this makes a pulse wave) that are transfered into the coil inside the sensor... these pulses are amplified and interpreted by an IC to read the motors RPM, position, acceleration, etc....
All fine and dandy, assuming that the little magnetic sensor inside these servos is magnetically shielded so that magnetic interferece doesn't screw up the signals.... I would think that they'd've thought of this at the factory, but who knows....
I would like to see a review on these servos, maybe some centering/travel tests with common potential interference scenarios... (i.e. - magnet near the servo, a running motor near the servo, spark plug/ignition running near the servo.... anything RFI or magnetic...)
I'll keep reading on these little guys maybe someone will make a review...
Tx
Brandon
Old Dec 08, 2010, 11:41 AM
GeorgeC525's Avatar
Coventry, UK
Joined Aug 2008
Just got the email too, and was thinking about them. Unless they offer a noticable improvement over standard servos, I don't see much point in rushing out and buying them now, Although I did say the same about 2.4ghz when that came out, and now THAT's pretty much mandatory!
GeorgeC525 is offline Find More Posts by GeorgeC525
Old Dec 08, 2010, 04:38 PM
Leicestershire
Joined Sep 2006
Interesting... Does this introduce "steps" into the movement which a regular servo digital or otherwise does not have?
Z
Zimodile is offline Find More Posts by Zimodile
Old Dec 08, 2010, 05:14 PM
gouch's Avatar
Lake Macquarie, Aust.
Joined Dec 2002
all this is is a non contact version of a pot.
Industrial servo motors use them, From what I understand they are technically called resolvers.
advantages are no contact, so no dirty pot issues or worn sliders.
Are these servos any good? who knows, time will tell. The system can be made to be extremely accurate, but like anything there are expensive versions, and cheap versions but I am guessing as this kind of feedback system has no wearing parts whatsoever, so it should be as accurate when it is old as it was when it was new, mechanical tolerances and wear on the rest of the servo notwithstanding.
note, as I know not much about this kind of thing, I asked my brother in law who is a motion control guru (industrial robotics etc)
gouch is offline Find More Posts by gouch
Sold 3 Magnetic Mayhem Rev, 1 EndoPlasma, CC ESC, etc… DougC Aircraft - Electric - Power Systems (FS/W) 1 Nov 30, 2010 11:10 PM
Discussion Magnetic Wheelpant Attachment E-Challenged Scale Electric Planes 5 Oct 08, 2010 09:39 AM
Sold Top Flite Power Point Magnetic Balancer M3Aviator Aircraft - General - Miscellaneous (FS/W) 2 Oct 04, 2010 01:11 PM
Discussion Magnetic Building Boards kdahlhaus North Coast Electric Flyers 0 Sep 03, 2010 09:26 AM
Sold 4 HXT 900 Servos + Top-Flight Magnetic Prop Balancer = $24 shipped shawn595 Aircraft - General - Miscellaneous (FS/W) 3 Aug 22, 2010 05:31 PM
