After a few days and several hours of experimenting, I have this plane setup and flying GREAT! I've named it the Tough Cat, because it is one tough bird! It has already survived enough crashes to ruin a dozen Depron planes. It's still windy here, and my backyard is lined with trees, I've clipped them a bunch and crashed hard with little to no damage except for a handful of busted props (it's 19 degrees). This is the best windy weather plane I've flown to date.
I should have some video soon. The plane is capable of knife edge, KE loops, snap rolls, torque rolls, slow high A (but not hovering, there is no air over the control surfaces at ultra low speed), inverted flight, and high speed flying. It's a blast, and the three layer EPP fuse is built to take abuse, while being really light and stiff.
I stiffened the tail with a piece of Kevlar thread. The leading edges of the wings were rounded, Kevlar thread inserted and saturated with thin CA glue, then covered with strapping tape to further stiffen the wing. I chopped off the tip of the twin booms. The plane is now really stiff, light, responsive, stable and fast.
Kevlar thread in a triangle to the fuse. CF on horizontal stab completes the triangle.
Kevlar thread attached to outside of vert. stabs.
Underside of finished plane;
Battery is mounted nicely inside fuse, stays warm and protected, also keeps CG perfectly centered side to side;
Leading edge rounded, Kevlar inserted and thin CA glue applied to stiffen wing and LE;
Video to be posted asap.
