Old Dec 05, 2010, 12:33 AM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
Self designed SFG`s for my TT Katana - want YOUR help please !!
After flying my Thunder Tiger Katana G2 for a few month I`m loving it. I wanted to use it as a testbed for a few mods and I would like to start with some SFGs built from CF. So, looking for help from people who have done this - Here are a few picture we took of the Katana.... Its a 45` Span.
Have a few questions please:
1) What shape should they be ?
2) Is CF the best way to go ?
3) How should they be mounted ?
4) Would " mini SFG on the stabiliser add an benifit to this mod ?
Thanks guys. Will keep updating the project.
OzparkPilot is offline Find More Posts by OzparkPilot
Old Dec 05, 2010, 01:23 AM
grubby is offline
Find More Posts by grubby
grubby's Avatar
Denver Colorado
Joined Jan 2010
Take a look at the Precision Aerobatics "vortex generators".
grubby is offline Find More Posts by grubby
Old Dec 05, 2010, 01:44 AM
Watts up ?
Joined Nov 2006
Sure..PA are next door to me in Sydney. Want to see some other mssurements to help me before I cut the CF.
Old Dec 05, 2010, 01:56 AM
IMK is offline
IMK
Find More Posts by IMK
IMK
Australia, VIC, Melbourne
Joined Aug 2005
Perhaps have a look at post 6337 in the PA Katana MD thread for some inspiration.
http://www.rcgroups.com/forums/showt...g#post14396772
IMK is offline Find More Posts by IMK
Old Dec 05, 2010, 02:02 AM
str8wing is offline
Find More Posts by str8wing
Las Vegas, NV
Joined Nov 2009
If you ask me, cutting carbon fiber SFGs will be a royal pain in the A**. I'd recommend 1/16 - 3/32 in (1.5 -2 mm?) plywood. Reinforce the edges or tips of the tip plates with CF if you want. A recent issue of Model Airplane News has a picture of a guy's plane with clear plastic tip plates. He drew simulated angles on them so it looked kind of scale. However you do it, I hope they give you what you're looking for.
str8wing is offline Find More Posts by str8wing
groovejet is offline
Find More Posts by groovejet
How many planes is too many?
groovejet's Avatar
Joined Aug 2007
Go for something like the 3DHS Velox SFGs. I've seen them fitted to a PA Extra 260 and it totally transformed the flight characteristics.
groovejet is offline Find More Posts by groovejet
Old Dec 05, 2010, 08:51 AM
MalaysianFlyer is offline
Find More Posts by MalaysianFlyer
Joined Apr 2007
Whoa, didn't think my little home made SFGs would be held up as an example.
When making SFGs, you need to consider what you want out of them. Making the go all the way to the trailing edge of the aileron means they also act as fences and help stabilise the wing rock in high alpha. Good examples of this are the FuntanaX, the 30cc QQ Yak, Extreme Flight Extra. Also, for the Katana MD, leblanc did some other interesting VGs in 2007, you can search for his on that same thread, and there is another of mine there also.
If you want to make VGs like the PA ones, you can easily make them from 0.5mm carbon sheets and cut them out using lexan body scissors (the ones the car guys use to cut their bodyshells, and no carbon dust to worrk about). Thats what I did to make the silver VGs on the VG Mania MX here: http://www.rcgroups.com/forums/showp...postcount=3787
My SFGs on the KMD were all basically just based on guesswork and looking at others designs. But thats half the fun, experimenting. Good luck with yours.
MalaysianFlyer is offline Find More Posts by MalaysianFlyer
Old Dec 05, 2010, 09:37 AM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I used a set of spare SFGs from a 3DHS Velox on my Yak. They were too long, so I lined up the back to fit flush with the rear of the ailerons and whacked off the front of the SFG flush with the leading edge of the wing. For the SFGs on the tail I simply resized the big ones on my computer.
I'm sure in the end that extensive use of wind tunnel data and cad cam computer analysis would give you the perfect SFG, but eyeballing it will probably get you close enough. The only part you have to be careful of is to make sure they are identical to each other.
Doc Austin is online now Find More Posts by Doc Austin
Old Dec 06, 2010, 01:25 AM
Watts up ?
Joined Nov 2006
Thanks guys - Doc, I had not seen anyone use them on the Stab before so I`m glad that you have had success here. How have they helped Harrier and KE flight ? and do the stab SFGs change things one more ? Many Thanks. This is going to be fun !!
Old Dec 06, 2010, 09:53 AM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
If you have access to 3mm Depron foam, it's fantastic for experimenting. We keep a supply of it and use it to try different shapes during testing. On SFG's, I highly recommend trying at least a couple of different sizes in depron before spending the time to build balsa or carbon.
blucor basher is offline Find More Posts by blucor basher
Old Dec 07, 2010, 01:02 AM
Watts up ?
Joined Nov 2006
Yes ok thats the plan now.. Thanks. What I really want to find out are how differant shapes make the plane behave. Also I wonder if the CG will be affected not taking into account the actually weight ? For example. will the additional drag produce a nose high attitude ?
Old Dec 07, 2010, 08:33 AM
Cuba is offline
Find More Posts by Cuba
Joined Mar 2010
Care to elaborate a bit on how it changed the flight characteristics?
Jakub
Cuba is offline Find More Posts by Cuba
Old Dec 07, 2010, 12:29 PM
bill clark is offline
Find More Posts by bill clark
Half way there
bill clark's Avatar
USA, FL, Ocoee
Joined Sep 2008
To improve high alpha stabilty I follow the design of spill plates on race car wings. Basically signifigant area at the leading edge and possibly a little a ahead to capture flow, pressue or whatever.
bill clark is offline Find More Posts by bill clark
Discussion Can't help my self, here is a new video frank40 Scratchbuilt EDFs 139 Oct 30, 2015 06:12 PM
Question Want to convert my JR 9XII to 2.4ghz, please help talkthetorque Radios 8 Nov 14, 2010 02:10 PM
I want to design my 3D model! Please Help! FlyingSparks 3D Flying 10 Nov 30, 2003 11:40 PM
