Old Dec 04, 2010, 11:52 AM
wgregww is offline
Find More Posts by wgregww
Go Packers!
Lambertville, Mi
Joined Apr 2010
Which battery charger?
Im looking at new chargers and have always liked and trusted my FMA CellPro. Im thinking of sticking with this manufacturer. What chargers would you suggest? I would love to be able to charge at least 2 at a time.
wgregww is offline Find More Posts by wgregww
Old Dec 04, 2010, 11:59 AM
Dave H. is offline
Find More Posts by Dave H.
Joined Feb 2008
Well there aren't that many models in the FMA CellPro line so it really just comes down to how many watts and cells you series you want/need. Small -> Multi 4/4S, Medium -> 10S, Large -> PowerLab 8.
They all work very well.
Dave H. is offline Find More Posts by Dave H.
Old Dec 04, 2010, 12:20 PM
wgregww is offline
Go Packers!
Lambertville, Mi
Joined Apr 2010
What other brands do you guys suggest. I really want to do 2 at a time and I never go over 2650 3C
Old Dec 04, 2010, 12:32 PM
wgregww is offline
Go Packers!
Lambertville, Mi
Joined Apr 2010
Ok forget the FMA chargers. I went to order a power supply for my 4S and they wanted almost $30 shipping. Thats some new business model. Please give me other charger options.
Old Dec 04, 2010, 12:39 PM
panther3001 is offline
Find More Posts by panther3001
Joined Dec 2010
I prefer chargers that can charge AC/DC (ie: they have a built-in power supply--since I charge so much in my house) and which are under $200. After doing a lot of research then, here is my recommendation:
Hyperion EOS 0720i NET3-AD. $160 at www.allerc.com
see my thread at http://www.rcdiscuss.com/index.php/topic,31735.0.html
panther3001 is offline Find More Posts by panther3001
Old Dec 04, 2010, 12:50 PM
Kuba is offline
Find More Posts by Kuba
USA, IL, Chicago
Joined Aug 2004
Four at once: http://hobbyking.com/hobbyking/store...dProduct=10327
Kuba is offline Find More Posts by Kuba
Old Dec 04, 2010, 01:19 PM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
I really like my Hitec X4. Charges and balances 4 packs at a time. All chemistries, Rx and Tx packs.
Chuck is offline Find More Posts by Chuck
Old Dec 04, 2010, 01:22 PM
Dave H. is offline
Joined Feb 2008
You might want to read the parallel charging thread. Any charger can charge as many as you like. I charge between 2 and 6 batteries on each of my chargers.
Check out the iCharger line.
Old Dec 04, 2010, 01:35 PM
wgregww is offline
Go Packers!
Lambertville, Mi
Joined Apr 2010
I really like the X4 but I want a AC power capability
Old Dec 04, 2010, 02:16 PM
KYlawyer is offline
Find More Posts by KYlawyer
Bustin' foamies is my hobby
KYlawyer's Avatar
Oldham County KY
Joined Sep 2010
Check out the Thunder Power 610C-ac/dc, I just ordered one. It's only 60 watts output on the ac, but can do 80 watts if you plug into a 12vdc car battery. If you aren't charging anything bigger than 3s or 4s 2650mah, it should do what you are looking for.
KYlawyer is offline Find More Posts by KYlawyer
Old Dec 04, 2010, 05:19 PM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
If you are looking for an AC charger, have a look at this thread.
AC/DC chargers w/over 100 watt??
Then follow up with this thread.
200 watt Lipo Chargers? any good ones out there?
If after reading those two threads, you change your mind about the AC requirement, then have a look at the Bantam Charger series. The iChargers have more features, and are less expensive, but in my opinion, the Bantam charger's sturdier construction and ease of use are worth the extra cost. I particularly like the BC6HP model. 250 Watts, 10A charge rate. Parallel charging multiple lipos would not be a problem with this charger.
The separate power supply is pretty cheap if you know where to look. 12 volts 30 amps 350 watts for $21.
KC
KC is offline Find More Posts by KC
Old Dec 05, 2010, 04:35 AM
Dino2010 is offline
Find More Posts by Dino2010
Dino2010's Avatar
dhaka
Joined Dec 2010
NiHm batteries come in various amperages (If a AA battery 1.4 volts)and the higher the amperage the more power to drive flash and other functions in the camera. Length of usage will vary depending on use and recharge times will also vary.
Be forwarned that batteries should be charged in pairs and should match in voltage and strength in charge. A good battery charged with a defective battery will soon falter due to uneven charge by the circuits. With that said it might be smart to charge similar batteries(of same amperage and brand)
Buying in bulk (say a dozen ) will allow you to rotate the various batteries in and out of the charger. Try to keep spare batteries away from metal objects that may short circuit them and away from moisture.
Various areas will see rayo-vac, duracell and others being sold. Buy according to the most amperage per buck, if no clear cut good buy there is always eine meany miny moe method..
______________
Wholesale Android Phones
Dino2010 is offline Find More Posts by Dino2010
Old Dec 05, 2010, 08:49 AM
Ben-Rod is offline
Find More Posts by Ben-Rod
HOW HIGH DOES IT GO???
Ben-Rod's Avatar
Jacksonville, Florida
Joined Nov 2004
Yea what he said. www.progressiverc.com
206b + P350 power supply = great combo...
Ben
Ben-Rod is offline Find More Posts by Ben-Rod
Old Dec 05, 2010, 09:03 AM
Jack Doherty is offline
Find More Posts by Jack Doherty
CPII HD & PL8 beta tester
Jack Doherty's Avatar
Aubrey, Texas
Joined May 2009
Hi Guys,
In case you are not aware,there are several retailers in the US that sell the REVOLECTRIX/FMA Direct chargers. In those cases you pay for local/US shipping charges.
Progressive RC - http://www.progressiverc.com/index.p..._id=1&Itemid=1
and
Quantum Hobbies - http://www.quantumhobby.com/category_s/418.htm
Just to mention a couple of US dealers. There are many others as well.
Jack
Jack Doherty is offline Find More Posts by Jack Doherty
Old Dec 05, 2010, 11:26 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
AA NiMH batteries as used in consumer electronics are not raed in amps. They are rated capacity as in mAh in the rabnge from 1500 or so up to 2700 mAh or so. Higher mAh ones have more capacity but may not deliver as many volts under load or even as much capacity as ones rated lower capacity (mAh).
There are also low self discharge ones such as Sanyo Eneloops which while only rated 2000 mAh do not self discharge in a month or so like many others and have faily low internal resistence so in fact in many applications out perform the hugher capacity (2300-2700 mAh ) ones.
Charles
Discussion Lipo Battery to Battery Charger Connector hog2soar Batteries and Chargers 2 Nov 26, 2010 04:07 AM
Help! Which battery pack? wehries Batteries and Chargers 2 Nov 23, 2010 04:41 PM
Sold Sale Pendin 45.00 Futaba T4VF Skysport 4 W/2 RX good battery and charger + RX battery -S- Aircraft - General - Radio Equipment (FS/W) 0 Nov 19, 2010 05:59 PM
For Sale $45.00 Futaba T4VF Skysport 4 W/2 RX good battery and charger + RX battery -S- Aircraft - General - Radio Equipment (FS/W) 0 Nov 14, 2010 09:10 AM
Which Charger & Which Battery? Buzz_Man Batteries and Chargers 6 Feb 17, 2003 10:09 PM
