Old Aug 10, 2012, 11:50 PM
hate2crash is offline
Find More Posts by hate2crash
Joined May 2010
Originally Posted by Bajora View Post
VIdeo of the stock Katana:
https://vimeo.com/47072945
Planning on a full article on the stocker over at HDFlyer.com, to be followed up with a Part II covering the bare airframe stuffed full of Don's Wicked goodness!
I have some cool custom graphics for the bare airframe on the way from Callie
Very nice plane and video..
hate2crash is offline Find More Posts by hate2crash
Old Aug 11, 2012, 12:24 AM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Sweet flying little plane!! Can't wait to see how it does with Don's set up!!
gooniac33 is offline Find More Posts by gooniac33
Old Aug 11, 2012, 09:43 PM
essar is offline
Find More Posts by essar
essar's Avatar
Canada, ON, Ottawa
Joined Mar 2012
Can anyone confirm the c of g on the F9F Panther is indeed 25mm back from the leading edge? Seems pretty far forward.
Bajora that Katana sure looks like alot of fun!
essar is offline Find More Posts by essar
Old Aug 11, 2012, 10:05 PM
Joined May 2010
I would go to HK and read reviews..i am pretty sure CG is mentioned a couple of times
Old Aug 11, 2012, 10:58 PM
dav3uk is offline
Find More Posts by dav3uk
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Yes 25mm from leading edge will get you flying, it is quite lively and you may end up further forward if you like planes to be more stable. However it is a very small plane so changes should be made 1/16-1/8 inch at a time.
Any further back and it becomes ahandfull quite quick, I have flown it at way back as I like em twitchy but even with reduced throws and expo I found it uncomfortable so brought it forward again.
when I use 850mah lipos they need to be right in the nose to get it balanced, when using 1300mah I have the luxury of being able to adjust........
Dave
dav3uk is offline Find More Posts by dav3uk
Old Aug 12, 2012, 02:00 AM
Bajora is offline
Find More Posts by Bajora
KA6KHM
Bajora's Avatar
Joined Sep 2004
More Katana flights this afternoon. I hit LVC last outing and the Katana nosed over on final, impacting on green grass from about 75' up. The fuselage broke apart just forward of the intakes (appears to be a factory seam) and the wing also popped off. The paint on this model is a little odd in that it peels off in small sheets once it has been scuffed up a bit? I used some acrylic paints and touched up the airframe after gluing it all back together. Almost as good as new!
Don and I also maidened a Screamer with a Don's Wicked/Wemo combo on 3S in it. SUPER smooth flyer!
Bajora is offline Find More Posts by Bajora
Old Aug 12, 2012, 02:05 AM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
nice Jon ...you coming to vegas in oct for ace in the hole?
AIR SALLY is offline Find More Posts by AIR SALLY
Old Aug 12, 2012, 03:29 AM
Bajora is offline
KA6KHM
Bajora's Avatar
Joined Sep 2004
No plans made Rodger. Not spending nearly as much time with the RC stuff lately. You guys enjoy yourselves out there!
Old Aug 12, 2012, 10:49 AM
essar is offline
essar's Avatar
Canada, ON, Ottawa
Joined Mar 2012
Dave
Thanks Dave I appreciate the info. I am flying 1000mah and they do need to be way forward for cg too. thanks again,
Essar.
Old Aug 12, 2012, 01:37 PM View Post
Bajora
A moderator felt this post violated the following rule: Cross-posting. It is temporarily hidden while Bajora edits it. Show it to me anyway.
Old Aug 13, 2012, 07:57 AM
CXB2671 is offline
Find More Posts by CXB2671
Joined Jun 2012
Skyangel edf jets
RTF, PNF, Full range here in UK :
www.Directsource4u.co.uk
www.amazon.co.uk/shops/A2UWXBZY2BSCRY
CXB2671 is offline Find More Posts by CXB2671
Reply With Quote  (Disabled)
Old Aug 14, 2012, 05:56 PM
Joined May 2010
I finally received my skyangel f9f model today..Very nice looking paint scheme and foam and hardward seem as good as it gets... i fitted pieces all together and everything fits nicely...before i glue..i will check fan for rubbing and balance... Should i use 5min expoxy to glue this air frame together? or is there something better for these birds...thanks
Old Aug 14, 2012, 06:25 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Originally Posted by hate2crash View Post
Should i use 5min expoxy to glue this air frame together? thanks
That works just fine.
Joe 1320 is offline Find More Posts by Joe 1320
Old Aug 14, 2012, 06:26 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Started a review and build on the new screamer if anyone might be interested....
http://www.rcgroups.com/forums/showthread.php?t=1711737
Old Aug 14, 2012, 08:20 PM
gp125racer is offline
Find More Posts by gp125racer
Lipo abuser ... smoke on!
gp125racer's Avatar
Joined Feb 2005
I had a chance to fly the Katana this past weekend ..... what a cool little plane! Easy to hand launch, smooth in the air, easy to see, and you can fit about 15 of them in the car at a time! This thing is just screaming for an upgraded power system .......
Don
gp125racer is offline Find More Posts by gp125racer
Latest blog entry: D100
Discussion Adelaide & SA flying & chat #2 Zootster Australia 22529 May 01, 2016 02:13 AM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
