Old Dec 25, 2010, 11:13 AM
skylane42 is online now
Find More Posts by skylane42
skylane42's Avatar
USA, MI, Portage
Joined Sep 2003
forgot to ask, are the connectors on the Sky batteries the correct ones?
skylane42 is online now Find More Posts by skylane42
Old Dec 25, 2010, 11:22 AM
Matt Howard is offline
Find More Posts by Matt Howard
Dyess AFB
Joined Apr 2009
no, you'll have to change them. The kit esc uses small banana plugs, I changed all my connectors to the Deans "T" type.
Matt Howard is offline Find More Posts by Matt Howard
Old Dec 25, 2010, 11:33 AM
Bajora is offline
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
The stock power systems use wee bullet connectors ... the smallest I have seen!
Bajora is offline Find More Posts by Bajora
Old Dec 25, 2010, 01:26 PM
handyflyer is offline
Find More Posts by handyflyer
Round Lake, IL
Joined Oct 2007
Thanks Gooniac and The Don. I wish I had a little more funds available right now.I would get some if I did. I love ur motors Don!! Recommended to anyone using this thread!!!
handyflyer is offline Find More Posts by handyflyer
Old Dec 25, 2010, 03:31 PM
Bajora is offline
AA6JB
Bajora's Avatar
Joined Sep 2004
Originally Posted by The Don View Post
I have those in stock as well and at a lower price :-)
Don
As Don mentions, he is also a source for the stiffer fans (Link to the fan on DonsRC). I recently bought one off of him HERE, and it came with a 6000Kv brushless Inrunner attached to it. I decided to use it in my Sky Angel L39, as the more I fly it, the more I love it and I think it would benefit the most from a little more power. I had to up the ESC from the stock 20A to one that could handle around 30 amps. I also increased the size of the lipo from a Thunder Power G4 Pro Power 45C to a 3S 1250mAh G4 pack. I had to cut a little foam out of the battery area to get this bigger lipo in. The bigger lipo also blocks the tongue of the front of the hatch from sliding into the fuselage. I cut the tongue off and used a couple of magnets to
secure the front of the hatch. The AUW RTF went from 11.7 ounces to 14.3 ounces, the power went from around 175 watts to 325 watts and the watts per pound increased from 239 watts per pound to 365 watts per pound. The CG shifted a little forward but I think it should be flyable where it is, without adding any weight to the tail. Now if the rains will just abate!!
Old Dec 25, 2010, 03:56 PM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
NICE!! I have done a similar hatch mod on an airfield P-47 and it worked great! My L-39 has 418 watts with a 4s 30c 1000mah pack, Himax 50mm fan and it is so much fun!! This is a very light and clean airframe so yours could actually be a little faster since it is a little heavier. I can get it to climb pretty steep at less than half throttle so I rarely use full throttle so the battery last a long time! Can't wait to see how yours flies! Nice to have so many options! I may try the 6blade fan from Don in my A-4 when it comes.... 4s of course!!
Also make sure to shrink the exhaust down to 39mm and you will get even more speed! I used mine with the stock outlet for a while but it flew much better when I made it smaller. And I think a thrust tube would work just as well...
gooniac33 is offline Find More Posts by gooniac33
Old Dec 25, 2010, 03:57 PM
Bajora is offline
AA6JB
Bajora's Avatar
Joined Sep 2004
Yeah Ray, I need to get a 4S system going in one of mine too!
Old Dec 26, 2010, 09:23 AM
jfruge is offline
Find More Posts by jfruge
RC Nut!
jfruge's Avatar
Madera, California, United States
Joined Oct 2001
Don
Don, do you have a good Wicked Moror option for this 6 blade fan for 4S ? If so do you have an numbers on it and also do you offer your "mounting and balancing" option with it?
Just trying to check some options until the Wemo Micro Fans are back in stock!
John Fruge
Madera, CA
jfruge is offline Find More Posts by jfruge
Old Dec 26, 2010, 09:37 AM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
I have no way to mount a Wicked to a 6 blade fan unit. I did get an email from Wemotec today and will have a dozen or so fans sent in the next day or so, which means I will have some in about a week.
The Don is offline Find More Posts by The Don
Old Dec 26, 2010, 09:40 AM
Dyess AFB
Joined Apr 2009
John, just run the 6 blade fan on 4S using the kit motor and esc for now until Don get's more Wemo's back in stock. It pulls 20 amps and puts out 275 watts.
Old Dec 26, 2010, 09:58 AM
jfruge is offline
RC Nut!
jfruge's Avatar
Joined Oct 2001
Matt, thanks for the info I will give that a try.
Don, I would like to change my preorder from the Wemo 3S Wicked setups to the 4S setups. I will send a PM for your records!
John Fruge
Madera, CA
Old Dec 29, 2010, 09:45 AM
turbored21 is offline
Find More Posts by turbored21
USA, WV, Moundsville
Joined Oct 2006
i just got the F16 today from Venom just like the others with some slight exceptions
it comes with motor ESC servos and a 3s 850 20C battery everything is pre-installed
just glue on the wings and tail surfaces drop in RX and go
it doesn't come with a charger ect and it also doesn't come with landing gear which being a grass field is fine by me
im impressed with the quality of this thing truly i am and am looking forward to the first flights this Saturday "while freezing my butt off!"
anyone with one of these note any bad habits or tendencies i should know about?
Tim
turbored21 is offline Find More Posts by turbored21
Old Dec 29, 2010, 10:22 AM
Bajora is offline
AA6JB
Bajora's Avatar
Joined Sep 2004
So the Venom versions include a lipo?! That is the first I had noticed that. I guess I should have read the fine print a little closer. That makes their pricing more attractive for sure!
Popular opinion is that the F16 is one of the fastest of the lot, so hang on!!
Old Dec 29, 2010, 10:31 AM
Dyess AFB
Joined Apr 2009
one of my 4 came with that same lipo pack, I think it was the L-39 I got from Banana Hobby. My L-39 also came with landing gear.
Old Dec 29, 2010, 12:31 PM
homiefoamie is offline
Find More Posts by homiefoamie
Foam Is Where The Heart Is.
homiefoamie's Avatar
Austin, Tx
Joined Feb 2009
I snagged both of mine (F-86 and F-18) from Banana Hobby. They both included lipo and balance charger. The F-18 also came with landing gear which I opted no to install. Did I mention 59$ each? That was on black friday though. The F-18 is hella fast if you ask me.
Dustin
homiefoamie is offline Find More Posts by homiefoamie
Discussion Adelaide & SA flying & chat #2 Zootster Australia 23112 Yesterday 07:37 AM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
