Old Jun 13, 2012, 10:31 PM
tengarang is online now
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
United States, CA, San Jose
Joined Aug 2010
does anyone know if the HobbyKing 40A BlueSeries Brushless Speed Controller has a spec that meets 6-pole 70,000 rpm?
Don told me the 50mm fans with modified higher KV will be best with this configuration
tengarang is online now Find More Posts by tengarang
Old Jun 13, 2012, 11:53 PM
dahawk47 is offline
Find More Posts by dahawk47
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
Hey Skyangels fans,
Well, I went ahead and popped for the F-16 to run with my T-45. Could not restrain myself. I got the plane, an 14.8v 850mah 4S 65C a 11.1v1000mah 3S 55C and a Ubec I needed for my scratchbuild twin edf airliner for $110.00 USD including shipping.
Best Fathers Day present I ever bought myself ! LOL
-Hawk
dahawk47 is offline Find More Posts by dahawk47
Old Jun 25, 2012, 05:54 AM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Hi
I'm just putting together a HobbyKing T33 and was considering not fitting the tip tanks. Can anybody tell me if the T33 flight improves with or without the tip tanks? I know they are not a nessessity, but I was wondering whether they are cosmetic only?
Mick
Bravo47 is offline Find More Posts by Bravo47
Old Jun 25, 2012, 11:32 AM
stvinvegas is offline
Find More Posts by stvinvegas
stvinvegas's Avatar
United States, NV, Las Vegas
Joined Dec 2006
Originally Posted by Bravo47 View Post
Hi
Mick
Leave the tip tanks for sure, it looks super cool flying. Change it to 4S and you will love it.
stvinvegas is offline Find More Posts by stvinvegas
Old Jun 25, 2012, 11:46 AM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Hi
Mick
I had a T-33 and the first few flights were without the tip tanks. The plane flew great! Really fast and aerobatic! But it looks very weird! Put the tip tanks on and it actually flies even more stable than before and just a tad slower. But it looks really good in the air! It flies great on 3s but it happiest on 4s!
gooniac33 is offline Find More Posts by gooniac33
Old Jun 25, 2012, 04:08 PM
Bravo47 is offline
Australia
Joined Jun 2010
Ok thanks guys I'll leave them on. Did you guys glue them or tape them on, as I read one suggested taping them on rather than glue because he said they catch the ground on landing breaking the wing easily?
Mick
Old Jun 25, 2012, 05:24 PM
tengarang's Avatar
Joined Aug 2010
Dear Pilots,
For those of you who are familiar with Don's wicked 6000KV wemo setup requires 1800mah on the F-18.....can the same setup be applied to the F-16 mini? I guess what I am after is, if the f-16 can fit the 1800mah 3s without any modification like the f-18
Old Jun 25, 2012, 05:29 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Originally Posted by tengarang View Post
Dear Pilots,
You won't be able to fit an 1800 mAh lipo in the F-16..... the battery area is not big enough. the biggest I think you'll be able to fit is 1000 mAh.
Joe 1320 is offline Find More Posts by Joe 1320
Old Jun 25, 2012, 05:52 PM
tengarang's Avatar
Joined Aug 2010
Thanks Joe, your feedback is sincerely appreciated. I want to ask what your opinion is regarding dremmeling out the f-16 to accompany the 1800mah 3s...think this will cause CG issues or about right?
Old Jun 25, 2012, 06:39 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
If you are using a stock motor and fan, anything heavier than a 1000 mAh will make it extremely nose heavy. With a heavier motor and fan, you might be closer...... the problem is still going to be the available room. If you can relocate the receiver further back into the wiring tunnel, you "might" be able to get a 1300 mAh lipo in there, but it's going to depend on the shape of the cells. They will need to be longer rather than thicker. The old polyquest 1250 would have been the proper shape as those were long and slim. You could cut out the divider that seperates the battery area from the rear electronics tray, just realize that space is a premium on the F-16
Old Jun 25, 2012, 06:50 PM
tengarang's Avatar
Joined Aug 2010
thanks Joe, sounds like the battery compartment space is different between f-18 and f-16....F-18 being the bigger compliance
Old Jun 25, 2012, 06:59 PM
herk1 is offline
Find More Posts by herk1
Trash Hauler emeritus
herk1's Avatar
Maryland, USA
Joined Oct 2006
Dear Pilots,
I fly one of my Skyangel F-16 planes with Don's wicked 6000 kv Wemo, and use a Nanotech 1600 LiPo in it. The particular battery I found has a long, flat shape that is a perfect snug drop-in fit in the F-16 battery compartment, like it was made for it, and balances just right with no dead weight required (thanks to the heaviness of the Wicked/Wemo on the other end). Photos here: http://www.rcgroups.com/forums/showp...&postcount=150
herk1 is offline Find More Posts by herk1
Old Jun 25, 2012, 07:01 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Different shape too. The F-18 is narrow and more vertical, the F-16 is wider and more horizontal.
Old Jun 25, 2012, 07:03 PM
tengarang's Avatar
Joined Aug 2010
Joe...and all pilots
as I understand it there are two versions the 35mm and the 50mm...
which version is this
http://www.hobbyking.com/hobbyking/s...dProduct=16392
im of course looking for the 50mm
Old Jun 25, 2012, 07:11 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
That is the 50mm version.
Discussion Adelaide & SA flying & chat #2 Zootster Australia 22879 Today 12:08 AM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
