Old Jun 05, 2012, 11:09 AM
stvinvegas is offline
Find More Posts by stvinvegas
stvinvegas's Avatar
United States, NV, Las Vegas
Joined Dec 2006
I think its about principle, I never give any business to BH. If everyone would stop buying from him because he's $2 cheaper maybe he would learn that if you want to stay in business you have to provide customer service.
I would rather pay more to get service.
stvinvegas is offline Find More Posts by stvinvegas
Old Jun 05, 2012, 11:49 AM
fredmdbud is offline
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
The Toysonics website gives you the option of email notifications when items come back in stock.
fredmdbud is offline Find More Posts by fredmdbud
Old Jun 05, 2012, 11:37 PM
dude_109 is offline
Find More Posts by dude_109
dude_109's Avatar
Houston, TX
Originally Posted by giantkevmiester View Post
btw does toysonics have decent CS, or is it another banana hobby?
Don't know if I've ever heard a bad CS story from Toysonics. I've ordered from them before and all went well. However, I've ordered at least 1/2 dozen planes from BH and all has been fine. Unless you've had personal experience with BH's CS, I'd say give them a try. While there has been a few bad stories, I'm sure the good stories are a lot more abundant. In the end, your $ so what ever place gives you the most peace of mind, order from there.
dude_109 is offline Find More Posts by dude_109
Old Jun 09, 2012, 06:18 PM
fuzzyhead is offline
Find More Posts by fuzzyhead
Old F-4 Crewchief
fuzzyhead's Avatar
Schertz, Texas, United States
Joined May 2004
Is the cg on these jets checked from the bottom of the wing or upside down on the balancer?
fuzzyhead is offline Find More Posts by fuzzyhead
Old Jun 10, 2012, 07:03 PM
T-BONEZ is offline
Find More Posts by T-BONEZ
Joined Jun 2007
depends on plane
Hi fuzzy, it depends on the design and location of the wing... for high wing toes like the crusader, e-starter... The c.g is measured from the bottom (normal attitude)
if it's low wing + di-hedral, it is measured with the plane inverted.
low winG + anhedral, normal attitude
high wing+ anhedral, normal attitude,
mid-wings are a little more complicated, I'd suggest following the pictures on the manuals.. if there isn't..
mid wing + anhedral (normal att)
mid wing+ dihedral. (normal att)
If it makes you feel more secure, either way works for all, if you placed the plane in the wrong attitude on it's c.g, you will see that the plane can tip in either direction. (like a see-saw with 2 equal loads at each end).
if the c.g is not on the pivot, it will only want to tip in one direction.
T-BONEZ is offline Find More Posts by T-BONEZ
Old Jun 10, 2012, 07:17 PM
T-BONEZ is offline
Joined Jun 2007
depends on plane
Old Jun 10, 2012, 08:47 PM
Old F-4 Crewchief
fuzzyhead's Avatar
Joined May 2004
Thanks T-Bonez. Thought it was checked inverted.
Old Jun 12, 2012, 05:46 PM
tengarang is online now
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
United States, CA, San Jose
Joined Aug 2010
Dear Friends,
Subscribing, Bought the f-18 PNP from hobbyking just now...did alittle reading and what I gathered was having a wemotech fan paired with its motor would be the way to go....with 1300mah 4s. Second option would be just using a 40A esc with the stock motor fan setup using a 1300mah 4s....
Whats the most popular wemotech setup from DON? there is a 6000KV motor with 50mm fan...but I think that might eat up the flight time too much...the stock motor is 4300KV based on what I read here.
tengarang is online now Find More Posts by tengarang
Old Jun 12, 2012, 08:48 PM
dude_109 is offline
dude_109's Avatar
Houston, TX
Stock fan+motor on 4S only pulls 25amp or so if I recall so 30A is sufficient but 40A is safer and will stay cooler. All of my in this series are on 30A and I fly with 3S and 4S.
Old Jun 12, 2012, 09:33 PM
tengarang's Avatar
Joined Aug 2010
Thanks Dude_109.
You just saved me from buying a new ESC....i got a 40A i need for another ship in mind.....however i got several 30amp esc's. But Ill probably hook up a external BEC to be safe....though still be running a bit hot.
I seen these things at my local field "Baylands" some of the good men there look like they are having heaps of fun with these things...
Old Jun 12, 2012, 11:13 PM
tengarang's Avatar
Joined Aug 2010
So I noticed and never been exposed to this setup only 2 servos??? so how do I configure my radio? mix the elevator with ailerons? ELEVONS? I think there is a preset program select-able but I am now thoroughly confused on how to set up the F-18
Old Jun 13, 2012, 12:36 AM
www.hobbyb.com is offline
Find More Posts by www.hobbyb.com
www.hobbyb.com's Avatar
Canada, BC, Vancouver
Joined Feb 2012
Use the Delta function if there is one in your tx.
www.hobbyb.com is offline Find More Posts by www.hobbyb.com
Site Sponsor
Old Jun 13, 2012, 07:25 AM
dahawk47 is offline
Find More Posts by dahawk47
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
At least on Futaba , it's elevons. Include some expo if you don't want it to be twitchy.
dahawk47 is offline Find More Posts by dahawk47
Old Jun 13, 2012, 07:58 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
right servo goes to ailerons, the left servo goes to the elevator channel.... use delta mix for Spektrum, Elevon mix for Futaba.
Joe 1320 is offline Find More Posts by Joe 1320
Old Jun 13, 2012, 10:28 AM
tengarang's Avatar
Joined Aug 2010
Thanks All for the feedback on the radio elevon settings...i think i have it....will look at it tonight...
Discussion Adelaide & SA flying & chat #2 Zootster Australia 22529 May 01, 2016 02:13 AM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
