Old Mar 13, 2012, 09:10 AM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Thinking about selling the fan and ESC.......
gooniac33 is offline Find More Posts by gooniac33
Old Mar 14, 2012, 04:49 PM
Riot is offline
Find More Posts by Riot
Joined Oct 2011
Thinking of picking up the F-22. Can anyone share their experience with this 50 mm airframe? Thanks
Riot is offline Find More Posts by Riot
Old Mar 14, 2012, 05:54 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I like it, even in stock form. I upgraded to a hotter motor in a Wemo Micro, but flight times went down to 2 mins. I think I might change it back and get the extra 3 minutes of flight time.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Mar 14, 2012, 06:07 PM
fredmdbud is offline
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Stable flier, good gliding characteristics, pretty resilient. Just make sure your CG is set correctly.
fredmdbud is offline Find More Posts by fredmdbud
Old Mar 15, 2012, 08:30 AM
tnt1106 is offline
Find More Posts by tnt1106
tnt1106's Avatar
Joined Dec 2011
I found it liked to be a touch tail heavy. Someone stole my jet or I would have specs on my Cg sorry.
tnt1106 is offline Find More Posts by tnt1106
Old Mar 15, 2012, 08:56 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Use the stock fan, balanced and indexed. Stock motor, 4s 800 mAh (minimum 30C but prefer 40C) all the way to the rear of the battery compartment. It flys like a jewel. Very stable, a little hard to get a hold of when hand launching but haven't had any issues at all.
JPower F-22 50mm EDF (4 min 15 sec)
Joe 1320 is offline Find More Posts by Joe 1320
Old Mar 15, 2012, 10:58 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Originally Posted by Blasturbator View Post
nice i think ill just stick to 950mah if i get to find them
The main point is to make sure you get a LiPo that is higher than the 20C they recc'd. The motor will take all you can throw at it and a 25 ... 30C pack is amazing difference in performance to the stock 20C.
solentlife is online now Find More Posts by solentlife
Old Mar 15, 2012, 02:15 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
http://www.youtube.com/watch?v=z325RErvx2Q
Nice launch!! And your set up works flawless! Good job....
Old Mar 15, 2012, 05:07 PM
Riot is offline
Joined Oct 2011
Thanks for all the comments. One question do I need an upgraded ESC to go 4s?
Joe, video says you are using a 30amp?
Old Mar 15, 2012, 05:27 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
On that particular plane, I am using a 30A esc. The stock ones can be flown on 4s but they will be at the limit with no headroom left over. Some stock ESCs live, others fry. It seems like the majority of the stock escs live as long throttle management is used. That doesn't mean pin the throttle at wide open for the whole flight...... it means that some wide open mixed with 3/4 throttle cruising. If you like to run wide open for the majority of the time, then at the very least you should bypass the internal bec and run an external bec to take some of the load and heat away from the stock esc. They are rated for 20A and on 4s that combo pulls 20-21A wide open, so there isn't much of a tolerance there. A 30A esc offers less of a chance of hitting a thermal shutdown or worse, cooking the esc.
Old Mar 15, 2012, 05:48 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
The stock ESC's come packaged in clear heat-shrink. Maybe if you cut a window over the front plate/heatsink, that will expose it to direct airflow - might mitigate any heating.
Old Apr 02, 2012, 01:40 AM
Blasturbator is offline
Find More Posts by Blasturbator
Blasturbator's Avatar
United States, FL, Sarasota
Joined May 2011
do they have a mirage 2000 airframe? (ive been looking for a mirage 2000 edf for a while 50mm to 70mm)
Blasturbator is offline Find More Posts by Blasturbator
Old Apr 02, 2012, 09:16 AM
sihinch is online now
Find More Posts by sihinch
Canada, ON, Toronto
Joined Jun 2007
http://www.hobbyking.com/hobbyking/s..._EPO_PNF_.html
A Mirage......
sihinch is online now Find More Posts by sihinch
Old Apr 02, 2012, 10:41 AM
Joined May 2011
Originally Posted by sihinch View Post
YEAAAAAAAH!!!! thanks!
Old Apr 02, 2012, 12:44 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
That's only, were you looking for airframe only?
Discussion Adelaide & SA flying & chat #2 Zootster Australia 23098 Yesterday 10:53 PM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
