Old Jan 06, 2012, 04:17 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Originally Posted by lud View Post
cut the wing off n then make it removable..
Huge number of replacement motor options on the main thread...
still think the std motor on 4s/ 6 blade impellor is hard to beat price wise.. I've got a AEO 50 to put in another model as n when one omces out I like ..
a black mantis 4800KV seems to work ok on the Std shroud / fan
I've just ordered a Turnigy 5000KV to direct replace my factory 4200KV motor ... that and using high C rated LiPo - should give the T45 a real boost. I'm waiting my 4S LiPo's to really get her singing ... and hopefully start on development to break the 100mph barrier with her.... possibly higher.
Eagle Tree data logger will be used on-board for speed checks as the doppler programs are subject to various errors and I want as accurate as possible ...
I'm really impressed with these 50mm jobs ... very handy size and surprisngly good flyers ... Friend has a Stinger and he says he likes the 50mm better !
solentlife is offline Find More Posts by solentlife
Old Jan 06, 2012, 10:36 AM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
The stinger flies great! But for the money you can't go wrong with the little 50mm jets. Everyone is amazed at how well they fly!
gooniac33 is offline Find More Posts by gooniac33
Old Jan 10, 2012, 01:11 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Just FYI....I am selling my T-33
http://www.bayrc.com/boards/viewtopic.php?f=4&t=9301
Old Jan 27, 2012, 12:30 AM
dno264 is offline
Find More Posts by dno264
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
Horizontal Stab
Hi -- I just got the L-39 and notice that the elevator and stab have curve on its trailing edge. Is this supposed to be there or is it a defect? Both sides of the stab/elevator have the curve as if it were molded in on purpose. Thanks.
-David
dno264 is offline Find More Posts by dno264
Old Jan 27, 2012, 10:33 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
-David
I recognize that M3 in the background...LOL
As for the Stab...mine did the exact same thing. As long as they are both the same I wouldn't worry about it. Mine has been that way from day one and it flies pretty amazing! I was going to sell mine but quickly reconsidered... The L-39 is a great flying jet!
You can sorta see the curve here...
Old Jan 27, 2012, 11:17 AM
dno264 is offline
David
dno264's Avatar
San Francisco, CA
Joined Sep 2004
Yup, that's me. Thanks.!
Old Jan 29, 2012, 02:24 PM
Blasturbator is offline
Find More Posts by Blasturbator
Blasturbator's Avatar
United States, FL, Sarasota
Joined May 2011
i want the F-22 but i cant seem to find any
Blasturbator is offline Find More Posts by Blasturbator
Old Jan 29, 2012, 02:59 PM
fredmdbud is online now
Find More Posts by fredmdbud
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Toysonics.com has them, though it's always good to confirm before placing an order.
http://www.toysonics.com/f-22-raptor...ess-motor.html
fredmdbud is online now Find More Posts by fredmdbud
Old Jan 29, 2012, 03:11 PM
Joined May 2011
yeah i want the receiver ready tho =/
Old Jan 29, 2012, 03:13 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
The only differences between the ARF and RR are 2 servos and an ESC. You don't have any spares lying around?
Stock ESC is only 20-30A.
Old Jan 29, 2012, 03:16 PM
Joined May 2011
no spares at all, do you know if it comes with the rods?, if it does come with ill just buy 2 servos and the esc
Old Jan 30, 2012, 12:05 AM
Joined May 2011
Also does a 3s 1300 would be ok or too heavy?
Old Jan 30, 2012, 12:22 AM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
I've flown with a 3S 1000mAH 30C battery. If you have the CG set correctly, it should fly OK, you'll just have to give it a good toss to give it enough speed to generate lift and airflow over the control surfaces.
Old Feb 01, 2012, 06:57 PM
Joined May 2011
nice i think ill just stick to 950mah if i get to find them
Old Feb 01, 2012, 08:00 PM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Will be way too heavy on the F-22. Will end up being a nose heavy pig to fly unless you ballast the tail get the CoG right.
Slaanesh is offline Find More Posts by Slaanesh
Discussion Adelaide & SA flying & chat #2 Zootster Australia 22406 Today 06:26 PM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 04:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 11:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 20, 2010 12:07 AM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 04:42 PM
