Old Jan 01, 2012, 10:22 AM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Originally Posted by jessejay1 View Post
I have a skyangel f22 50mm , inside motor compartment does the esc go on the top or bottom of the plane. Its not clear int he manual
Anywhere on the topside (in case the ESC doesn't fit the molded recess) - that way you minimize airflow blockage.
fredmdbud is offline Find More Posts by fredmdbud
Old Jan 03, 2012, 05:13 PM
Build'm,Fly'm,Crash'm
redlite's Avatar
Sacramento CA
Joined Oct 2009
Paint, custom graphics and some ordnance help the look. Opportunity knocks only so often... The fin and intake checkerboards are the kit's original, saved with tape, the rest is from Callie G.
The LG and doors are purely theatrical. The ordnance will fly with the model, being only grams of foam, plastic and balsa.
Joe
redlite is offline Find More Posts by redlite
Old Jan 03, 2012, 06:00 PM
RA-TA-MA-HAT-TA
munce31's Avatar
Melbourne, Australia.
Joined Feb 2010
Joe
Superb and scale for a 50mm. If only skyangel/jpower made the a7 more scale like you have by extending the nose.
munce31 is offline Find More Posts by munce31
Old Jan 03, 2012, 06:02 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
Not so much the weight but the drag. Let's hear how she flies!
Old Jan 03, 2012, 06:39 PM
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Looks super. Can't wait to hear about the performance.
Joe 1320 is offline Find More Posts by Joe 1320
Old Jan 03, 2012, 07:48 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Joe
Truly amazing job!! Is the wing movable or will it be stationary?
gooniac33 is offline Find More Posts by gooniac33
Old Jan 04, 2012, 12:11 AM
redlite's Avatar
Sacramento CA
Joined Oct 2009
Thanks gents...next flight will be number 5, a few more mods are ready for testing, them being fixed flaps at neutral, a NACA style cheater hole on the bottom and ordnance.
So far, it's a handful and it likes to deviate from flat flight if speed is not maintained (wing loading is high). The latest set up is promising, but a little more weight and drag has been added. Lucky I have a pilot who is fearless and loves a tough assignment.
Hand launching is the hardest part by far, it must be flung hard and slightly up with flat wings or else. I saw the primer on hand launching these 50mm jobs...they all launch badly if not done by the numbers, with the exception of a couple in the series.
At first, it was in the plans, but after some consideration, the landing gear is always out when the red is out and my model is a belly scratcher, so it would look a bit funny without the LG down. The wing is bolted down for flight.
Joe
Old Jan 04, 2012, 01:27 PM
United States, NY, New York
Joined Dec 2009
thanks for the great information on jets.
bigtruck169 is offline Find More Posts by bigtruck169
Old Jan 04, 2012, 03:34 PM
lud
Making mischief in the air
lud's Avatar
Berkshire UK
Joe
looks realy realy impressive .. would love to see a video ..
lud is offline Find More Posts by lud
Old Jan 04, 2012, 04:15 PM
dude_109's Avatar
Houston, TX
redlite,
Excellent job. I assume the ventral fins survive belly landings well?
dude_109 is offline Find More Posts by dude_109
Old Jan 05, 2012, 12:12 PM
Peachtree City, GA
Joined Nov 2001
F-86 motor wire loose
My motor wire pulled loose on my F-86. Wing glued on with epoxy. debating between pulling out the motor or cut the wing off to get to wire. Has anyone removed motor and replaced?
Bill PTC
BillPTC is offline Find More Posts by BillPTC
Old Jan 05, 2012, 02:19 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Bill PTC
I really hate it when that happens....to prevent this in the future be sure to tape all connections that are hard to reach...
Do you have to cut off the wing? no other option?
Old Jan 05, 2012, 03:23 PM
lud
lud's Avatar
Berkshire UK
cut the wing off n then make it removable..
Huge number of replacement motor options on the main thread...
still think the std motor on 4s/ 6 blade impellor is hard to beat price wise.. I've got a AEO 50 to put in another model as n when one omces out I like ..
a black mantis 4800KV seems to work ok on the Std shroud / fan
Old Jan 05, 2012, 03:55 PM
redlite's Avatar
Sacramento CA
Joined Oct 2009
They are foam elevators off a HL MiG as are the faux LG doors that are from the interior ducting off the same MiG carcass. At the moment they are tacked on with CA, pop off when struck. Once the flight trim has been figured out, I was thinking thin ply 'skids' for durability.
Joe
Old Jan 05, 2012, 10:35 PM
Peachtree City, GA
Joined Nov 2001
Did not have to do surgery. Was able to pull one end back thru with string and then plug in the wire with long forcep. Because the original connection was under the duct system did not wrap it before gluing the wing.
Bill PTC
Discussion Adelaide & SA flying & chat #2 Zootster Australia 11229 Today 12:59 AM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
