Old Aug 29, 2011, 12:50 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Just picked up some Wemo micro fans and a HET 240-15 6000kv motor to transplant into some of my planes. Can't wait to get these in!
Pat
crxmanpat is offline Find More Posts by crxmanpat
Latest blog entry: Nico Hobbies
Old Aug 29, 2011, 01:08 PM
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Originally Posted by T-BONEZ View Post
understood on both threads, i'll give the flaps idea a try, hopefully it works, do i need alieron differentials in it?
you'll need to fly it first and see the result. In a prototype A-7 that I designed for a kit, it wasn't needed. However, there was no anhedral on the wings and the correct dihedral on the horizontal stab. That probably had the effect of a more neutral setup. the JPower kit doesn't have any dihedral on the horizontal stabs and little, if any anhedral on the wings.
You could just add nose weight, that might help if you put the bird in a flat spin. Without a rudder, it's much more difficult to get it out of that flat spin. If it were me, I would try the flaps first and see if it works well enough. having dual aileron servos set up with a flap channel would make it easy to dial in from the transmitter.
Joe 1320 is offline Find More Posts by Joe 1320
Old Aug 29, 2011, 01:40 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Flaps did work really well with keeping the nose down. And on landing they really helped out. This really is a plane that should have landing gear and take off from the ground though. It needs a super hard toss!
gooniac33 is offline Find More Posts by gooniac33
Old Aug 30, 2011, 10:03 PM
Joined Jun 2007
THANKS JOE, THANKS GOONIAC,
Gooniac, don;t mind if i ask, may i have your settings for the control surfaces and c.g?
thanks mate
T-BONEZ is offline Find More Posts by T-BONEZ
Old Aug 31, 2011, 01:57 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
thanks mate
It is long gone. And I wiped out the model memory....
Old Sep 01, 2011, 01:25 PM
USA, MI, Portage
Joined Sep 2003
When you guys went from a 3s to a 4s, how did you rebalance your plane? I put in a new 4s 1300 and it is way nose heavy now. My 4S packs weigh like153 g and the old 3S about 122g.
skylane42 is offline Find More Posts by skylane42
Old Sep 01, 2011, 03:04 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
It depends on the model. But usually you can move the pack further back. And sometimes they come out just a tad more nose heavy than with the 3s packs. Which plane are you referring to?
Old Sep 01, 2011, 03:23 PM
USA, MI, Portage
Joined Sep 2003
T-33
Old Sep 01, 2011, 03:29 PM
dude_109's Avatar
Houston, TX
Not much room to work with in T-33. My 3S 1000mah are already all the way back. 4S just makes it more nose heavy. I don't fly that plane on 4S anymore. It has a weird tendency to nose down right at launch when nose heavy. On the other hand, 4S gives plenty of power for you to point the nose more vertical so it will smooth out into straight flight before nosing towards the ground.
dude_109 is offline Find More Posts by dude_109
Old Sep 02, 2011, 02:28 AM
2 metre rule applies!
DRAMJET's Avatar
BOOGI, Australia
Joined Dec 2008
My T33 balances nicely with a 1000 mah 3s Zippy in the rear of the batt area.
It had a launch impact at full power a few months ago which left 1 blade on the rotor(almost did the job good Dude!) Replaced with 6 blade unit from Don's but smoked the Esc so now running a 30a unit. Clocked at 75-80kph and handles real nice. Seem to be getting the launches better now which takes the out of the flight.
DRAMJET is offline Find More Posts by DRAMJET
Old Sep 02, 2011, 09:03 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
I have used 4s in mine from the beginning. Yes it is at the more nose heavy side of things but you can launch it at a 30-45 degree angle with 3/4 power and it just flies away. It won't dip at that power setting.
Old Sep 06, 2011, 05:32 PM
netsurfr's Avatar
United States, WI, Milwaukee
Joined Jul 2009
Maidened my Blue Angels a4 today in way too windy (15mph) condition (at least for me). Don't know how I managed to save the launch but I did & made me look great saving it! Flew very well given the wind so very happy w/ it.
Skyangel 50MM EDF Blue Angels A4 Maiden - Almost Crashed! (1 min 16 sec)
netsurfr is offline Find More Posts by netsurfr
Old Sep 08, 2011, 12:39 PM
Thatsright I drankthe rum
K9000wner's Avatar
USA, MN, Robbinsdale
Joined May 2006
it cost what ???
Just received kits of T45 and L39 from HK and a 1000mah batt...
found a packing slip / invoice .
now I accept that a profit $$$ needs to be made but CRIPES!!...
Slips shows ....mini EDF fighter kit --unit price --$6.20
both kits and 1000mah 3s 25c pack -- unit price --$1.63
HOLY CRIP showed shipping at $7.75usd
I paid MORE!......
does this sound right to you who have business es
and not horribly marked up ?
I guess I thought a biz markup was in the 30 -50 % range not
in the 300 -500% range
K9000wner is offline Find More Posts by K9000wner
Old Sep 08, 2011, 12:42 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Disregard those amounts. That was just for the Customs invoice. HK always makes the costs seem rediculously low to avoid high customs fees.
Pat
Old Sep 26, 2011, 10:22 AM
Bajora's Avatar
Sonoma County
Joined Sep 2004
Not really anything new to report except another update from Jalin yesterday that I should receive samples of the deltas in the next few weeks.
Also new 35mm Micro EDFs: F18, F16, T45 ....AND .....A10 and Mig 29!!
If you follow the Sky Angel mini warbirds .... A1 Skyraider and Sea Fury are also due in soon
Bajora is offline Find More Posts by Bajora
Discussion Adelaide & SA flying & chat #2 Zootster Australia 10516 Today 08:37 PM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
