Old Aug 27, 2011, 07:46 PM
Razors edge 29 is online now
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
To the Red Arrows Owners
guys can someone PLEASE do me a favor and post pics of where exactly the elevator servo and ESC are supposed to sit in the fuse?
I have PNP version which came servoless and the pics in manual suck.
I think
the ESC is supposed to sit above the elevator rod tubes, and the elevator servo is supposed to sit in front of the esc in the one cut out.
BUT
why is the cut out soo large? which way is best to mount servo?
lengthwise so esc wires can run beside it?
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Aug 27, 2011, 07:54 PM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
United States, NV, Las Vegas
Joined Nov 2010
I think
BUT
Picture attached. ESC mounted behind the servo, deep inside the fuse. If you take the cover for the motor off, you can see there is a cutout on the top portion of the inside, and the ESC should tuck in there. Make sure you extend the power wires to your battery.
-= GYRO =- is offline Find More Posts by -= GYRO =-
Reply With Quote  (Disabled)
Old Aug 27, 2011, 07:56 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
great thank you very much
Looks like I have some soldering to do - lengthen power wires of ESC
How do you find you the aileron servos on top of wing? create any off flight characteristics?
Originally Posted by slickg66 View Post
Picture attached. ESC mounted behind the servo, inside the fuse.
Old Aug 28, 2011, 09:46 AM
skylane42 is offline
Find More Posts by skylane42
USA, MI, Portage
Joined Sep 2003
When you guys upgrade to the 4S pack .. do you keep the small bullet connectors or change to a mini deans or what? Also, just what size and where have you been getting them at? I found some Turnigy 1600 4S 20C but that is about all I am finding.
skylane42 is offline Find More Posts by skylane42
Old Aug 28, 2011, 10:33 AM
Joined Nov 2010
The plane flies just fine with the servos on the top. I did it because I land on a carpet runway.
I use the 3.5mm bullets on all my models.
Old Aug 28, 2011, 11:22 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Cool
Do you mind posting a pic of the tail?
How much should the tips of the H stabs point down?
Mine is quite a bit, not sure if that's normal or not.
Old Aug 28, 2011, 11:31 AM
MRGTX is offline
Find More Posts by MRGTX
MRGTX's Avatar
United States, CT
Joined Aug 2005
The jump from 3cell to 4 cell won`t kill the ESC? BTW, what amp ESC comes with these?
Yep...your ESC should be ok. 4s makes a big speed amd climb improvement for the stock motor. Just make sure that your fan isnt too badly out of balance or it might come apart.
MRGTX is offline Find More Posts by MRGTX
Old Aug 28, 2011, 11:52 AM
Joined Nov 2010
Cool
I didn't do any incidence mods to the tail, so this is "factory". I don't have any closeups of the plane's tail, and it was destroyed in a recent crash, sorry.
Old Aug 28, 2011, 12:36 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Sorry to hear about your crash.
Thanks for pics - the checkered graphics look great.
Your elevator tips are pointed down correct?
Old Aug 28, 2011, 12:47 PM
Joined Nov 2010
Yes, the elevators tips had about a downward cant of near 10 degrees.
Old Aug 28, 2011, 01:20 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
cool
thanks a million
Old Aug 29, 2011, 02:41 AM
T-BONEZ is offline
Find More Posts by T-BONEZ
Joined Jun 2007
hey gooniac33,
I bought an f8 crusader too and i am having difficulty getting it to fly, how's yours? is the c.g in the manual correct? my crusader keeps pitching up crazily on launch and goes into a flat spin.
thanks a bunch!
T-BONEZ is offline Find More Posts by T-BONEZ
Old Aug 29, 2011, 09:11 AM
gooniac33 is online now
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Originally Posted by T-BONEZ View Post
hey gooniac33,
thanks a bunch!
I dialed mine in and then sold it. My first launch was the same and thankfully it is a pretty strong airframe. But you need to move the CG a little forward of what they say on the manual and add lots of elevator throw. It needed a lot of differential in the ailerons to fly right. 68% on mine and then it would roll without adverse yaw. I also nipped the exhaust as well since the exhaust is only 48mm which is way too big. But it never did really fly the way that I liked. So I sold it before I killed it...
gooniac33 is online now Find More Posts by gooniac33
Old Aug 29, 2011, 09:52 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
hey gooniac33,
thanks a bunch!
manually set the ailerons with a down incidence (flaps) to push the nose down and it will fly out without pitching the nose up.
Joe 1320 is offline Find More Posts by Joe 1320
Old Aug 29, 2011, 12:46 PM
T-BONEZ is offline
Joined Jun 2007
understood on both threads, i'll give the flaps idea a try, hopefully it works, do i need alieron differentials in it?
Discussion Adelaide & SA flying & chat #2 Zootster Australia 22641 Yesterday 10:48 PM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
