Old Mar 29, 2011, 11:26 AM
FoamJunkE is offline
Find More Posts by FoamJunkE
EDF Junkie
FoamJunkE's Avatar
San Antonio, TX
Joined Jul 2010
Originally Posted by SamL View Post
Guys
I can't seem to balance my AMX. It seems very tail heavy with the battery (1000mah) as far forward as possible. Can someone confirm the CG for me please. The manual shows 36mm back from the front of the tapered leading edge. Looks very far forward on the wing to me.
Mine is right at about the panel line area of the leading edge and it flys fine with several diff packs.. I do have to place the packs partialy into the fuse just past where the intakes line up. It does seem far forward, but it works.
FoamJunkE is offline Find More Posts by FoamJunkE
Old Apr 05, 2011, 07:00 PM
forevercat is offline
Find More Posts by forevercat
*crunch*
forevercat's Avatar
United States, CA, Saratoga
Joined Aug 2010
by any chance, does somebody have a picture of the f-16 with the stock battery installed? i cannot find a position to fit the CG without cutting foam, adding bracing. i hope to get her in the air by this weekend!
forevercat is offline Find More Posts by forevercat
Old Apr 06, 2011, 12:59 AM
Impailer is offline
Find More Posts by Impailer
FLY IY, BREAK IT, FIX IT,
Hampshire, United Kingdom
Joined Jun 2005
I dont have a pic (and cant take one as I have now converted to 4s), but my stock battery was up front. I had to add 5g of lead to the tail to get CG.
Impailer is offline Find More Posts by Impailer
Old Apr 29, 2011, 09:17 AM
homiefoamie is offline
Find More Posts by homiefoamie
Foam Is Where The Heart Is.
homiefoamie's Avatar
Austin, Tx
Joined Feb 2009
Whats this hot water soak ppl talk about? Does it remove wrinkles and how do I do it? Just soak in hot water? Of course not the electronics
Dustin
homiefoamie is offline Find More Posts by homiefoamie
Old Apr 29, 2011, 10:10 AM
dude_109 is offline
Find More Posts by dude_109
dude_109's Avatar
Houston, TX
These types of foam will get soft and the cell can puff back up after a squashing session (crash). Hot water will get the foam to do so. However, too hot as in boiling will over do this and you get the alligator skin looks which would be hideous on a scale plane. About 190-200* is more than you will need.
I make hot water in my coffee maker so its hot but not boiling. I haven't measure the exact temperature of my coffee maker but pouring the water on while flexing the foam to the shape you need. Keep holding the foam to the new shape while the temperature cools down (about 1 minute) will have the foam hold the new shape.
I've done this fix on wings and stabilizers that were warped in shipping box as well as after hideous crashes.
dude_109 is offline Find More Posts by dude_109
Old May 07, 2011, 04:12 AM
StyRo FuN is offline
Find More Posts by StyRo FuN
Joined Nov 2009
A-4 Skyhawk CG
Hi guys,
Need help with the correct CG of my skyhawk. Mine seems to be too nose heavy. Anybody flew the bird? recommended CG is 100mm from the LE.
TiA
StyRo FuN is offline Find More Posts by StyRo FuN
Old May 07, 2011, 06:49 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Originally Posted by StyRo FuN View Post
Hi guys,
TiA
Mine balances perfectly at eh panel line that runs across the top of the fuse and down across the shield decal on the side of the intake.
Joe 1320 is offline Find More Posts by Joe 1320
Old May 07, 2011, 10:45 AM
Impailer is offline
Joined Jun 2005
Wicked 5400/4S/Wemo F-16 maiden went fine....
4s5400- SkyAngel 50mm EDF F16.wmv (2 min 57 sec)
Not a huge difference to the 3S/Wicked 6000 it was flying with, but a lot of fun.....
will put this setup in the F-16 I am presently glassing and spraying.....
1080p for best viewing....
Old May 08, 2011, 08:37 PM
Joined Nov 2009
hi joe,
tnx for the quick reply. if its not too much to ask, can you post pix of how you positioned electronics in your A4. I find it weird on mine since im not getting the correct balance.
Appreciate the effort
thanks again
Old May 09, 2011, 12:22 AM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
I cut out the foam. added a 1500ma 3 25c cell and she screamed. Much better flight times than the 3min from the stock 800mah
lipoflyer is offline Find More Posts by lipoflyer
Old May 12, 2011, 07:28 AM
Jensst is offline
Find More Posts by Jensst
Balsa Kamikaze
Jensst's Avatar
Germany, NRW
Joined Feb 2001
@all 4s flyers on stock setup: how are your motors/ESCs holding up?! Are they still alive?
On my Jpower L-39 the stock motor burnt on 4s while running on the testbench. I upgraded to a Turnigy 2615-4800 from HK and a Wemotec Microfan. The stock fan was way out of balance.
Haven't flown it yet. Has anyone flown this kind of setup on 3s/4s?
_jens
Jensst is offline Find More Posts by Jensst
Old May 12, 2011, 07:51 AM
dude_109 is offline
dude_109's Avatar
Houston, TX
_jens
How long did you have it running on the bench before it burnt? 3 of my 4 planes run 4S at times and are fine so far. How did you mount the Wemo to that Turnigy's shaft?
Old May 12, 2011, 08:09 AM
Impailer is offline
Joined Jun 2005
_jens
I have a 5400 Wicked motor on 4S and a Wemo fan in my F16. Works fine @ 515W - see video above
Old May 12, 2011, 08:23 AM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
_jens
haven't burned one up yet, then again I don't fly wide open throttle all the time.
Old May 12, 2011, 08:56 AM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Stock ESC's are good! 3s and 4s! Just make sure that there is a lot of cold air blowing over it.
gooniac33 is offline Find More Posts by gooniac33
Discussion Adelaide & SA flying & chat #2 Zootster Australia 22529 Today 02:13 AM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
