Old Mar 14, 2011, 07:20 AM
dude_109 is offline
Find More Posts by dude_109
dude_109's Avatar
Houston, TX
My T-45's wing tip does curve downwards near the tip. The wing itself is slightly anhedral before glueing. I really have to push the upper part to the fuselage to get it to be very slightly dihedral. Don't know if mine was warped or what but the next one (if there is), I'll run the wing middle under hot water to bend them slightly up.
Oh, I also fixed some of the incidence in the horiz stab.
dude_109 is offline Find More Posts by dude_109
Old Mar 14, 2011, 09:49 AM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
My Red Arrows T-45 actually twist at the tips and has no dihedral at all. I know that the real plane is not that way but I really like the way it looks on mine. And it flies wonderfully! From what I can tell the Red T-45 is made slightly different. All of the ones that I have seen have flat wings and they are made from a slightly stiffer foam. The white T-45 is different and has the dihedral like the real one. But they both fly the same. I have flown my with CrazyJ in formation and they fly exactly the same.
gooniac33 is offline Find More Posts by gooniac33
Old Mar 14, 2011, 10:24 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Originally Posted by ciscovet View Post
E-lm
Thanks for the info. What about a plane w/o elevons, say my t-45 that runs ailerons separate from elevators?
Then is more simple ... you don't need a mixer, and you can plug the Gyro straight between RX and Servo
Tchuss
e_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Mar 14, 2011, 11:38 AM
Bajora is online now
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
Latest News on the Next 50mm EDF Jets to be Released ...
I posted this up over in the original 50mm thred but thought I would share it here too:
Rumor has it there are more new 50mm models coming!
The A6 and F8 are imminent ... following them in the pipeline next should be the JAS 39 and Mirage 2000. SO I guess you delta enthusiasts can see that Jalin does watch and take ideas from this thread?! Also, new 50mm models will include the Fouga Magistar and U2.
Also upcoming, in the 40mm Micro product line (which is actually 35mm I just found out) will be the F18, F16 and T45. And how about a twin 35mm Mig 29 and A10?!
Bajora is online now Find More Posts by Bajora
Old Mar 14, 2011, 11:56 AM
collective itch is offline
Find More Posts by collective itch
United Kingdom, England, Dorset
Joined Mar 2011
sweet, looking forward to the mirage, any idea on dates?
collective itch is offline Find More Posts by collective itch
Old Mar 14, 2011, 12:14 PM
dude_109 is offline
dude_109's Avatar
Houston, TX
Jon,
You left out the A-7...that is also coming, right?
Put me down for A-7, F-8, JAS39, Mirage2000 in 50mm. Then for 35mm. I'll take T-45 & A-10
Old Mar 14, 2011, 12:32 PM
AA6JB
Bajora's Avatar
Joined Sep 2004
Yesiree ... the release of the A7 and F8 should be imminent!
Old Mar 15, 2011, 09:13 AM
lud is offline
lud
Find More Posts by lud
lud
Making mischief in the air
lud's Avatar
Berkshire UK
Any pictures of the F8 ??
I hadnt planned on any more after the A-7 but it's bigger brother would be cool to have as well..
lud is offline Find More Posts by lud
Old Mar 15, 2011, 12:45 PM
dude_109 is offline
dude_109's Avatar
Houston, TX
Jon, is it too late to have Jalin reshape the canopy for the A-6? Should be smoother transition into the fuselage as opposed to the bubble... Hate to complain but the cartoon bubble keeps bugging me and has reduced the A-6 to a "maybe" on my list.
Old Mar 17, 2011, 01:42 AM
Impailer is offline
Find More Posts by Impailer
FLY IY, BREAK IT, FIX IT,
Hampshire, United Kingdom
Joined Jun 2005
Originally Posted by Joe 1320 View Post
Finally got some video of the T-45 on 4s. I'm taking it real easy, it's the stock fan (balanced) and stock motor on 4s. It sure takes off in a hurry.]
Great stuff Joe - am waiting for a suitable ESC (plumped for 40A) and will be joining you with 4S on the stock motor - will also be trying a 6 blade fan on it.
Do you know the amp draw on 4S?
thanks in advance.
Impailer is offline Find More Posts by Impailer
Old Mar 17, 2011, 09:00 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
thanks in advance.
It is in the 22-25amp range. And sometimes less. A 30amp ESC will work fine.
Old Mar 17, 2011, 09:36 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
thanks in advance.
On the stock 5 blade fan (balanced) I get 22A peak and settles down to 21A after a few seconds.
Ironically, the 6 blade impeller shows 18A and 275 Watts. In theory the additional blade should make consumption go up, there must be a reduction in pitch or blade area. This is two different examples of the same motor with different fans so it's not a back to back comparison using the same motor, but I can't imagine motors at this level being that far out of spec compared to each other. I used a 30A pentium and it's not even remotely stressed.
Just be prepeared for a little bit of left torque roll at higher throttle, mostly noted at launch. Evidently not quite enough stator. Flys great even with that.
Joe 1320 is offline Find More Posts by Joe 1320
Old Mar 17, 2011, 10:21 AM
impostor is offline
Find More Posts by impostor
Renegade Eggroll
USA, IL, Chicago
Joined Jan 2011
Hey guys - I'm going to maiden my T-45 this weekend if the weather co-operates. It is completely stock. I'm going to use Sky Lipo 3S 1000mah batteries. I'm setting the timer for 4:00min. Is that too long for the stock configuration and this battery?
Thanks!
Tom
impostor is offline Find More Posts by impostor
Old Mar 17, 2011, 10:22 AM
bentech is online now
Find More Posts by bentech
bentech's Avatar
Canada, QC, Brossard
Joined Jun 2006
just receive my F-16 from hobbyking yesterday i just finished building this little jet and everything work perfect. My only problem is the CG. To get it balance, i have to put my suport at 45 mm from the leading edge of the wing. In the manuel, the balance point is supposed to be at 60mm. If i put it a 60mm, the plane is nose heavy. the battery pack is alerady at the maximum in the back of the battery tray. I use a HK 6ch 2.4 Ghz RX that is very light weight. So, what should i do ??
bentech is online now Find More Posts by bentech
Old Mar 17, 2011, 10:34 AM
crazyj is offline
Find More Posts by crazyj
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, WA, Kent
Joined Oct 2002
Thanks!
Tom
4 minutes should be fine
crazyj is offline Find More Posts by crazyj
Discussion Adelaide & SA flying & chat #2 Zootster Australia 22870 Today 03:14 AM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
