Old Mar 09, 2013, 03:29 PM
Arxangel is offline
Find More Posts by Arxangel
Arxangel's Avatar
Bulgaria, Sofia-grad, Sofia
Joined Feb 2012
Originally Posted by mopetista View Post
Thank you, I've actually seen this, but I did not know it was the same motor and fan.
Arxangel is offline Find More Posts by Arxangel
Old Mar 09, 2013, 04:24 PM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Managed a short flight today of the AMX and the helmet cam worked!.
It helps a lot if someone throws it for you.!!
This the second flight of the AMX kit bought from HobbyKing.
Cyclone Power 50mm 10Blade EDF
Turnigy 2627 4200kv outrunner
Blue Series 30A ESC
2x Corona 918 9gr servos - Taileron/Elevon configuration. Ailerons pinned.
In the airframe the setup pulls:
3S 850mah 45c battery - 190watts at 10.8v and 17.5amps
3S 1000mah 45c battery - 205watts at 11v and 18.6amps
4S 850mah 25c battery - 370watts at 14v and 26.4amps
These are not peak. They are taken after the fan runs on full throttle for 10seconds.
Sounds pretty good and goes very well. I can't stand the noise of low blade count fans any more.
On full throttle on 4S it picks up a lot of speed and get small pretty quick so I can't say that I explored its speed capabilities.
On 3S it needs at least half throttle to keep going.
This fan needs 4S
SkyAngel AMX - 50mm Cyclone Power 10 Blade - Turnigy 2627 4200kv 3S/4S (1 min 26 sec)
anlucas is offline Find More Posts by anlucas
Old Mar 09, 2013, 05:17 PM
dahawk47 is offline
Find More Posts by dahawk47
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
Opa !
dahawk47 is offline Find More Posts by dahawk47
Old Mar 09, 2013, 07:42 PM
Mike20 is offline
Find More Posts by Mike20
Mike20's Avatar
Joined Sep 2012
So got in both my 8 blades edf units today and found out there's no way to make them work with the stock motors or edf units. So I guess I'm gonna have to buy the complete 8 blade unit that comes with the 5800kv motor and motor shaft adapter and I'll just have two spares. Any idea if I sand down the lip if it will effect performance or airflow? I plan to just make it even with the rest of the unit.
Mike20 is offline Find More Posts by Mike20
Old Mar 09, 2013, 08:47 PM
Patrizio_g is offline
Find More Posts by Patrizio_g
Patrizio_g's Avatar
London, Ontario
Joined May 2006
Hi guys i just want to join in the action with 50mm EDF i currently have a 64mm EF2000
but i want to move down to 50mm.
being reading here for a wile and im wondering how you fit bigger bat. gyros etc... i will be interested on putting some fpv gear on it as well lol.
what are your thought!!! what airframe i like the Jas35 the F35, F16 any recommendation and advice will be appreciated.
-Pat
Patrizio_g is offline Find More Posts by Patrizio_g
Old Mar 09, 2013, 09:51 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Got my Katana today! Made it here with another plane in literally like 3 days. Thats half a world away in 3 days! Gotta love/hate ems The quality of the foam is nice, the already glued in pieces are lined up, the decals look decent (for the price) the fan however... is miserable! Its soo far out of balance. There are blades that have flash (not sure if thats the term in this type of molding) that strike the shroud and its really just awful to look at! Other than that, I think its a keeper. I will be flying bone stock first, then going to a thrust tube, then going to the wemo/6k,kv wicked setup. Cant wait for a calm day
3d astronaut is offline Find More Posts by 3d astronaut
Old Mar 09, 2013, 09:55 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
Originally Posted by Jacques.Eloff View Post
Picked up an AMX airframe from Hobbyking. Wondering if anyone has tried tailerons only (ie pinned ailerons)?
My experience with the F-18 is that it flies better this way, so interested to hear the views of others.
Jacques
its great rigged that way , i did a flight report on mine just a ways back in this thread.
chuck.
chas650r is offline Find More Posts by chas650r
Old Mar 09, 2013, 10:28 PM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Blue Series 30A ESC
This fan needs 4S
http://www.youtube.com/watch?v=SpmjhK8N6jc
Sounds good! But you need to limit the amount of throw on the wings surfaces if you ever want to throw it on your own. I saw it do what mine used to do before it became uncontrollable... The tail does all of the work. I am loving how that fan sounds though!! Thanks for posting!
EMS can be awesome and awful all at the same time! It usually shows in 2-4 days when I do it that way. But I have been waiting for things to show up in warehouses stateside before I go for it. The Katana was purchased from Hobby B and it took about 3 weeks to get! Not gonna do that again...EMS or stateside only...
Gonna maiden the 55mm equipped Screamer tomorrow! Can't wait to see how that goes! Will post results when I get them!
gooniac33 is offline Find More Posts by gooniac33
Old Mar 09, 2013, 11:59 PM
hate2crash is offline
Find More Posts by hate2crash
Joined May 2010
Okay, i guess i will order stock for now...thax everyone...Gooniac does your L39 handle 3s 1300s well? I took one and it fit perfect in the back compartment...not sure were the cog should be yet...it is the easiest kit to assemble out of the f9f and t-45 which i have and i like the servo in the back..very nice designed plane...thax again
hate2crash is offline Find More Posts by hate2crash
Old Mar 10, 2013, 12:18 AM
Joined May 2010
I found this stock motor from HobbyB http://www.hobbyb.com/skyangel-2605-...?cPath=128_141 I see they also sell a pack of 5 edf units for $19...Anyone know if all hardware is included to mount motors in these edf units? also i see they sell 6 bladed fan whats the performance difference using the stock motor..i am guessing it draws a little more amps and possibly a slight increase in thrust along with a slight sound change...thax
Old Mar 10, 2013, 01:01 AM
anlucas is offline
anlucas's Avatar
Joined May 2011
Great tip! Looks like the culprit for all of my failed attempts to hand launch before.
It definitely felt that way. Need to dial them down a lot.
Old Mar 10, 2013, 04:35 AM
tengarang is offline
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
United States, CA, San Jose
Joined Aug 2010
Blue Series 30A ESC
This fan needs 4S
beautiful!
tengarang is offline Find More Posts by tengarang
Old Mar 10, 2013, 07:19 AM
K9000wner is offline
Find More Posts by K9000wner
Thatsright I drankthe rum
K9000wner's Avatar
USA, MN, Robbinsdale
Joined May 2006
http://www.hobbyking.com/hobbyking/s...r_55_64mm.html,,,,,,
who wants to do a test on this setup for us 3S fliers
I will guess about ...3S 1000mah 45c battery -
250 watts at 10.?v and 24 amps +-12%
K9000wner is offline Find More Posts by K9000wner
Old Mar 10, 2013, 07:46 AM
Arxangel is offline
Arxangel's Avatar
Joined Feb 2012
I was close to ordering this motor for a future Stinger, but in the last minute changed to the 2836.
Old Mar 10, 2013, 12:45 PM
Joined May 2010
Anyone know how to explain how to post pictures here...I can't seem to be able to figure it out..thax
Discussion Adelaide & SA flying & chat #2 Zootster Australia 22870 Today 03:14 AM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
