Old Feb 15, 2013, 04:27 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
The A6 is the only one that I don't have. I look forward to a flight report.
Joe 1320 is offline Find More Posts by Joe 1320
Old Feb 15, 2013, 04:53 PM
Mrgeorgedoors is offline
Find More Posts by Mrgeorgedoors
Mrgeorgedoors's Avatar
United Kingdom, Warrington
Joined Nov 2012
Will keep you posted joe, not sure when it'll be out yet , im out tomorrow but already got my planes ready for tomorrow plus looks a little windy I prefer calm days for maidens
Looking forward to it though, I mite end up with another yet before that's maidened lol
What's the F8 like? Wanted an A4 but non in stock over here yet
Mrgeorgedoors is offline Find More Posts by Mrgeorgedoors
Old Feb 15, 2013, 05:57 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
The a-7/8 is a troubled child. The fan is not mounted in an optimum location and the resulting curved duct creates an adverse yaw to the right as power is applied. Tricky to launch, but once on step is flys ok. Stall it, you get a non recoverable flat spin right down to the ground. Perhaps the most challenging of the group to fly.
Old Feb 16, 2013, 03:05 AM
ozfella is offline
Find More Posts by ozfella
Nasir Khan
Australia, NSW, Fairfield
Joined Feb 2009
Originally Posted by green_flyer View Post
excellent nose repair. whilst its in good shape you may want to consider taking a plaster cast of it with alginate and plaster of paris.
I made a plaster cast of my F22's nose. Its easy and fun, now I'm going to do a plaster cast of the noses of my other jets.
My next idea is to make another mould using the alginate, then pour in a little resin, and maybe even stuff in a bit of glass cloth, then when its set sand the foam nose down so it fits inside the resin cast, and hopefully that will produce a really tough nose.
However I suspect this will shift any impact forces further down. At least the nose should stay in good shape.
Very nice Green Flyer! could you please put up photos of the process?
ozfella is offline Find More Posts by ozfella
Old Feb 16, 2013, 04:18 AM
green_flyer is offline
Find More Posts by green_flyer
we can take off without that
green_flyer's Avatar
London, UK
Joined Nov 2008
Hi Nasir,
I'm going to cast the nose of another jet soon, I will do a video.
green_flyer is offline Find More Posts by green_flyer
Old Feb 16, 2013, 05:30 PM
Mike20 is offline
Find More Posts by Mike20
Mike20's Avatar
Joined Sep 2012
Ok quick question guys. I'm acquiring a 5800kv motor and 2 edf units one with a 5 blade and one with a 6 blade. Which rotor and motor combo would give me the most speed? I have a 50 amp ESC so do you guys think I could still go to 4s or should I stay at 3s using the 5800kv motor in my t45?
Mike20 is offline Find More Posts by Mike20
Old Feb 16, 2013, 05:38 PM
ozfella is offline
Nasir Khan
Joined Feb 2009
Hi Nasir,
Thank you Green Flyer. Will keep an eye out. Cheers
Old Feb 16, 2013, 05:49 PM
Dirty Dee is offline
Find More Posts by Dirty Dee
Dirty Dee's Avatar
United States, IL, Northbrook
Joined Sep 2011
anyone running a T-33 on 4S? I have everything all put together, but its coming out nose heavy with a 1000mAH 4S all the way to the back. do you just add some lead to the tail? Right now COG is 43mm from LE
Dirty Dee is offline Find More Posts by Dirty Dee
Old Feb 16, 2013, 10:16 PM
gooniac33 is online now
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
The cg that they say in the manual is actually the rear ward cg. So long as it balances in between the cg that they list and the leading edge of the wing it will be fine. I used a 4s 40c 1000mah in mine and it was perfect even with it being ahead of the cg in the manual.
gooniac33 is online now Find More Posts by gooniac33
Old Feb 16, 2013, 10:20 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Finally upgraded the lipos for the A-10. Twin 4300 KV motors, hobbyking 30A ESCs, and finally flown with a 4s 2200 mah pack. performance was great! Lots more vertical pull. Lands a little hotter, but a small price to pay.
Old Feb 17, 2013, 09:07 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
With a 5800kv ... I give my opinion which may vary from others - but that's life !!
I would use the 5 blade as the 6 if anything like mine will load up more. The 50A ESC will be ok on the 3S ... but may be pushed to limits with the 4S ... my 5000kv / 6 blade combo really hammers my 4S packs ...
But I would go with the 50A ESC - as I suspect you will not be WOT 100% of the time.
Nigel
solentlife is offline Find More Posts by solentlife
Old Feb 17, 2013, 10:01 AM
Mike20 is offline
Mike20's Avatar
Joined Sep 2012
Nigel
Ok thank you Nigel. No biggie ill put the 6 blade in my mig 15 and the 5800kv in the T45.
Old Feb 17, 2013, 12:54 PM
Joined Nov 2012
My latest sabre has 5800kv with 8 blade fans and 30a Esc using 1300 3s. Havnt a clue how it flys yet have done some mods but just a little windy for my liking to chuck it.
Went to chuck my T45 today 1st time since I repaired after crash last month, just to find the elevator servo is buggered so that annoyed me as I had 10 packs charged for that and the A6 but again the wind stopped me from a maiden with that.
Old Feb 17, 2013, 01:40 PM
Valkpilot is offline
Find More Posts by Valkpilot
Valkpilot's Avatar
Joined Mar 2012
Ok folks, need some input. I'm debating on wether to get the SA F9F or to try the Starmax
64mm version. The price difference is $10 before S&H, and I've had the 64 version before,
unsucessfully. About the only plus currently is that the Starmax has a steerable nose and won't require modification for LG.
Valkpilot is offline Find More Posts by Valkpilot
Old Feb 17, 2013, 01:56 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
my take is the starmax is a far better airframe than the 50mm. the s/max looks better, has no thrust line issues, better power to weight, more good choices for fan upgrades and if u want gear , it's a no brainer. it will also stand a better chance of not being warped out of the box, although the elev is know to be at times. oh and did i mention it looks better.
not to get o/t , but what was the problem the first time around?
chuck.
chas650r is offline Find More Posts by chas650r
Discussion Adelaide & SA flying & chat #2 Zootster Australia 22641 Yesterday 10:48 PM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
