Old Feb 01, 2013, 02:51 PM
Mrgeorgedoors is offline
Find More Posts by Mrgeorgedoors
Mrgeorgedoors's Avatar
United Kingdom, Warrington
Joined Nov 2012
Are there any spares available for these? Think I need a new fan cover for this sabre
Re seated the fan so it was straight and when the glue was dry I put the cover on and fits as it should, however the gap at the top now has practically gone but that's made the gap bigger at the bottom once the cover is on so I think this mite be a problem.
Fan put in same position but level
Can see a gap on the left there too. Don't really want to fly it just incase this could cause a problem it mite be ok but if its not it could end in disaster. Looks like a new cover would sort it if there are any available.
Cheers
Rod
Mrgeorgedoors is offline Find More Posts by Mrgeorgedoors
Old Feb 01, 2013, 03:06 PM
Mike20 is offline
Find More Posts by Mike20
Mike20's Avatar
Joined Sep 2012
So is it true that the changesun 10 blade edf unit is more powerful then dons set up?
Mike20 is offline Find More Posts by Mike20
Old Feb 01, 2013, 03:07 PM
gooniac33 is online now
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
I think that it will be fine. So long as it is straight and there aren't any major gaps. Try it out and see. You can tell if there are gonna be problems just by running it up on the ground. Should have plenty of power though!
gooniac33 is online now Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
The 10 blade 50mm? Just because there are more watts doesn't mean that there will be more power....Don's stuff is pretty good! Not many match up to his....
Old Feb 01, 2013, 03:28 PM
Joined Nov 2012
Think ill tape up the cover too can sort of see through a bit. It had power from what I remember I havnt powered it up again since, just the servos to install then wings and ill give it a chuck.
Rod
Old Feb 01, 2013, 03:31 PM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
It looks like the intake lip has been cutoff the fan housing.
It should still fly ok though with that gap around the housing.
jim350 is offline Find More Posts by jim350
Old Feb 01, 2013, 03:57 PM
Mike20 is offline
Mike20's Avatar
Joined Sep 2012
I was just wondering cause I'm looking for the best set up or upgrade for my t45 and it's between his and the changesun. I would like to get the max amount of speed I can. I only wish dons had the same sound as the 10 blade.
Old Feb 01, 2013, 04:14 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
quote: I only wish dons had the same sound as the 10 blade.
yep , u pay for the sound in the hi blade count in efficiency.
chuck.
chas650r is offline Find More Posts by chas650r
Old Feb 01, 2013, 04:22 PM
Mike20 is offline
Mike20's Avatar
Joined Sep 2012
I don't know chuck according to paradise hobby the changesun is putting out 399watts compared to dons 375. I just did the math and even if I lost some due to the airframe I think i would still get about the same if not more and the sound.
Old Feb 01, 2013, 04:33 PM
Joined Nov 2012
Well it did look quite rough and there wasn't a lip so looks like that's been done
Rod
Old Feb 01, 2013, 04:43 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
so if i have a 500 watt fan is that better yet? it's about what u get out of the watts in that matters.
so once again, generally speaking, the hi blade count fans will not give u the thrust/ efflux speed that the lower blade count will for the same watts in.
chuck.
Old Feb 01, 2013, 04:50 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Comparison by pure watts can be misleading. Typically what I have seen posted with the high blade count fans (in the 50-70mm size) is higher watts for equal speed or less speed for equal watts. The sound of a Wemotec 50mm does not really bother me, so the whoosh sound of the 10 blade fans really does not do anything for me personally. However, if for equal watts you get the same speed and the whoosh sound is an added bonus then I may try one out. So someone please post a video of a Skyangel Screamer with one of these new 10 blades fans at about 370-400 watts going 100 mph flat and level with no tailwind then I will believe the 10 blade fans are just as good as lower blade fans.
The Don is offline Find More Posts by The Don
Old Feb 01, 2013, 06:37 PM
gooby is offline
Find More Posts by gooby
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
The maiden of my A-6 went great! After trimming, it was easy to fly and much more stable than I thought it was going to be. I set the timer for 3 minutes, but I could probably fly longer. I had trouble judging how fast the landing speed should be. I didn't want to stall so it came in a little fast and it flipped over in the soft grass with no damage at all.
gooby is offline Find More Posts by gooby
Old Feb 01, 2013, 06:40 PM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Originally Posted by Mrgeorgedoors View Post
........Re seated the fan so it was straight and when the glue was dry I put the cover on and fits as it should, however the gap at the top now has practically gone but that's made the gap bigger at the bottom once the cover is on so I think this mite be a problem. ........Cheers
Rod
My solution would be to use card or thin depron to seat the EDF unit in and close up the gap ... sanding of the edge to smooth transition.
If the EDF unit is a good fit .. ie a tight friction fit - then I've found that glue is not necessary. My high-power unit in my T45 has no glue whatsoever .. it never moves.
Nigel
solentlife is offline Find More Posts by solentlife
Old Feb 01, 2013, 06:53 PM
solentlife's Avatar
Joined Jan 2010
chuck.
Simply put Watts does not = speed.
For example : take a motor and put a propellor on it. You get xxx watts and xx speed / thrust.
Take same motor and put a heavy flat plate beam on it ... you get xxx watts and zero speed / thrust.
As I understand from what I read - the high blade count fans use a finer pitch and rely on the number of blades to get the air volume moved. This in turn gives the reduction in sound.
Look at high performance speed EDF's and you see a small number of blades often 3 .. but serious pitch. So high speed but poor acceleration.
I would put my 6 blade T45 up against any other and reckon I would match or beat in speed ... the only set-up I reckon I'd have trouble matching is Don's own gear ! He's got far more knowledge about this than I ever will.
My problem is power demand ... my 1600 4S at WOT gives me under 3 mins so careful use of throttle is needed to get decent run-times. But at 140kph - I reckon I'm pushing the max limit the T45 50mm can get to and I get a real thrill out of it.
I have had a higher reading - 160kph, but discounted it as another model was flying at the time and could have affected the doppler.
Nigel
Discussion Adelaide & SA flying & chat #2 Zootster Australia 23103 Sep 26, 2016 07:27 PM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
