Old Jan 24, 2013, 08:25 PM
dude_109 is offline
Find More Posts by dude_109
dude_109's Avatar
Houston, TX
Originally Posted by Mike20 View Post
Why is the bob balancer so much???
Go to my blog and see my cheap, but good enough, static balancing. As for the housing, remount the motor's 2 screws in a way that centers the motor best. Mount the housing so that the 4 static blades are in a + instead of X direction when looking at the plane level to give the strongest structure from deforming.
I haven't broken a blade since taking that extra set up care.
dude_109 is offline Find More Posts by dude_109
Old Jan 24, 2013, 08:30 PM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Originally Posted by Mrgeorgedoors View Post
My edf's went weird on me today. And this is the result
The break on the T45 ... is near or on the mould joint. The T45 has a 'soft joint' right there and is not unusual to part ... epoxy 5 minute to rejoin ...
The Chinese glue used is crap !!
My T45's have all broken at that joint more than once. I would not recc'd strengthening the joint. I did on one of mine and the next break was much worse ...
Nigel
solentlife is offline Find More Posts by solentlife
Old Jan 24, 2013, 09:36 PM
FoamJunkE is offline
Find More Posts by FoamJunkE
EDF Junkie
FoamJunkE's Avatar
San Antonio, TX
Joined Jul 2010
Model Masters Blue Angels blue/yellow
Originally Posted by Valkpilot View Post
Is Model Masters an acrylic? I thought it was enamel, and couldn't be used on foam.
Blue= 4687 Yellow= 4684
The small rectangular piece is from the inside the fuse battery bay and has the blue applied. This will be my second airframe that I paint.
FoamJunkE is offline Find More Posts by FoamJunkE
Old Jan 25, 2013, 04:44 AM
Mrgeorgedoors is offline
Find More Posts by Mrgeorgedoors
Mrgeorgedoors's Avatar
United Kingdom, Warrington
Joined Nov 2012
It does look like guidance failure. What TX/RX setup were you using?
The Sabre doesn't look too bad, just might need to dunk it. And the Goshawk
looks like a clean break. A little CA and maybe some toothpicks
as rebar should work.
I'm using spektrum rx/tx.
DX7s AR400 ,
T45 all sorted ready to rock n roll again. Sabre nose has been dunked in hot water and glued back together. Crack on with that later today and finish my Texan also.
Mrgeorgedoors is offline Find More Posts by Mrgeorgedoors
Old Jan 25, 2013, 07:01 AM
Valkpilot is offline
Find More Posts by Valkpilot
Valkpilot's Avatar
Joined Mar 2012
Thanks for the info. BTW is that the 50mm Hornet, and if so, did it come
with LG or at least the slots cut out for LG?
Valkpilot is offline Find More Posts by Valkpilot
Old Jan 25, 2013, 07:09 AM
EDF Junkie
FoamJunkE's Avatar
San Antonio, TX
Joined Jul 2010
Valkpilot,
Yes, its the 50mm Hornet and it came the nose lg base istalled but no other lg parts. I dont use them anyways, I dont like to fly my jets dirty.
Old Jan 25, 2013, 07:32 AM
Valkpilot's Avatar
Joined Mar 2012
Valkpilot,
To each his/her own. Tried both hand and cat launches, no joy. But I do have
access during most of the year to a paved runway for 50mm and above, and can fly my UMX MiG off of a sidewalk.
Old Jan 25, 2013, 07:52 AM
EDF Junkie
FoamJunkE's Avatar
San Antonio, TX
Joined Jul 2010
Yes, I totally understand the hand launch thing so I dont mean to knock anyone. I know exactly how frustrating it can be. Im just starting my 4th year in the hobby and have countless number of flights probably well into the thousands with these 50mm edf's so I've become very comfortable with the hl.
Some I launch right and some left handed depending on the behavior of the jet that Im launching.
Old Jan 25, 2013, 08:06 AM
alpea 41 is offline
Find More Posts by alpea 41
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
My Grippen was a difficult hand launch so much so that only I could successfully throw it with a 2 handed launch , my right hand pushing from the tail cone. And have somebody else take the Tx till it was flying. So I've decided to make it a pusher with a Suppo 2212 06 22000 Kv and a 6x4 prop. I've made longer gear legs they are spindely and look weird but my goal is to fly it without the 2nd person as a launch pilot. It did take off of asphault O K but on my dirt home field the short gear meant it ingested sand and rocks .
alpea 41 is offline Find More Posts by alpea 41
Old Jan 25, 2013, 08:38 AM
Valkpilot's Avatar
Joined Mar 2012
I had the Grippen, but only got two flights out of it. It's the only plane I've ever physically lost. I was trying a Tactic RX with the Any-Link on my DX6i. This was before the AR400 came out and the cheapest Spectrum RX was about $50.
I'm pretty sure that it was the interface, because the SAAB was on it's second
outbound leg and suddenly spun like a football and went out of sight into the woods.
Old Jan 25, 2013, 07:12 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
Nigel
glad you mentioned that joint...i thought about running some bamboo skewers along the inside
i'll leave it like it is
KCinNC is offline Find More Posts by KCinNC
Old Jan 26, 2013, 04:36 PM
Joined Nov 2012
Well as its my birthday coming up in a few wks it's the perfect excuse to buy a new plane
Trouble is I don't k ow which one any ideas?
I quite fancied the A-4F sky hawk but hk only have it in the blue angels colour which is disappointing as i really wanted that one nxt.
I'm also looking at the A-6 intruder and F-16.
Hmmm
Old Jan 26, 2013, 05:21 PM
trroadster is online now
Find More Posts by trroadster
trroadster's Avatar
Canada, AB, Edmonton
Joined Oct 2006
Hmmm
Try HobbyB or Toysonics.com. Google will show the way
trroadster is online now Find More Posts by trroadster
Old Jan 26, 2013, 05:27 PM
Joined Nov 2012
Cheers
Toy sonics have the A-4F in the navy colours
Will buy that along with a better fan
Rod
Old Jan 26, 2013, 06:36 PM
voxel is offline
Find More Posts by voxel
United States, FL, Altamonte Springs
Joined Jun 2012
Anybody fly the Sukhoi Su-34 Twin 50mm? Curious how it is? Thinking of a dual 4s 10 blade 50mm setup - motors arrive in a few weeks.
voxel is offline Find More Posts by voxel
Discussion Adelaide & SA flying & chat #2 Zootster Australia 23117 Today 07:06 AM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
