Old Jan 23, 2013, 04:24 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
We use Bob's balancer to do all our dynamic balancing.
Using that in combination with a quality Wemotec Microfan is about as good as it gets for mild to wild power, with no vibration or exploding fans.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Jan 23, 2013, 05:56 PM
Mike20 is offline
Find More Posts by Mike20
Mike20's Avatar
Joined Sep 2012
So how do you guys even out the weight on the rotors?
Mike20 is offline Find More Posts by Mike20
Old Jan 23, 2013, 06:36 PM
efflux RC's Avatar
Joined Aug 2009
The wemo rotors are prebalanced (weight added) at the factory. On the micros, the spinner is not removable, so it's fine tuned on the dynamic balancer by incrementally rotating the rotor on the shaft adaptor. More putty is added to the inside of the hub if required.
Site Sponsor
Old Jan 24, 2013, 03:53 AM
green_flyer is offline
Find More Posts by green_flyer
we can take off without that
green_flyer's Avatar
London, UK
Joined Nov 2008
you can balance your edf using equipment you already have, fingers and ears. Its the same method of moving the weight (tape or bluetack) around to find the sweet spot then increasing or decreasing the weight. Less precise but free.
if you have one of those smartphones you can also use it to balance your edf.
someone found cheap accelerometers that can be used too. and another guy has a method using a laser and a mirror.
http://www.rcgroups.com/forums/showthread.php?t=1267814
http://www.rcgroups.com/forums/showthread.php?t=1740895
http://www.rcgroups.com/forums/showthread.php?t=1714824
link to accelerometer post:
http://www.rcgroups.com/forums/showp...2&postcount=16
I balance mine by hand/ear, but I really like the accelerometer idea, I'll be getting one.
green_flyer is offline Find More Posts by green_flyer
Old Jan 24, 2013, 06:37 AM
Valkpilot is offline
Find More Posts by Valkpilot
Valkpilot's Avatar
Joined Mar 2012
T-33
Want to get the regular AF version, but might get the "Blue Angels" version.
But my question is how do you remove the pre-applied stickers?
Valkpilot is offline Find More Posts by Valkpilot
Old Jan 24, 2013, 07:16 AM
London, UK
Joined Nov 2008
you are better off getting the airframe only from hobbyb without stickers.
I removed them from my AMX using isopropyl alcohol rubbing it on gently with a brush, takes ages. Then I got some acetone (nailpolish remover) and that melted them away quickly, but it will also dissolve the paint. I was recently straightening the wings of my F22 in very warm water and that made some of the decals come off, but others seem to be stuck fast.
Old Jan 24, 2013, 08:35 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
sticky tape takes the stickers / paint of ... that's the stuff that normal handling doesn't remove !!
Nigel
solentlife is online now Find More Posts by solentlife
Old Jan 24, 2013, 09:18 AM
Valkpilot's Avatar
Joined Mar 2012
But does the acetone damage the foam? I wouldn't mind spot-painting, and
the Hobby-B kit doesn't come with control rods, nor do they sell them seperate.
Old Jan 24, 2013, 09:28 AM
Whiskey Whiskey is offline
Find More Posts by Whiskey Whiskey
United States, CA, Fairfield
Joined Jul 2004
I've used low odor mineral spirits to remove paint, and I know Nitrocharged had used naptha to do the same without damaging the EPO foam.
The tape is by far the best method for removing the paint. Don't stick it to the paint, just quickly drag it across the paint and the paint will peel off in large sections. As paint sections are removed use a fresh spot on the tape to prevent dragging "paint pills" on the foam and marring the surface.
Using chemicals turned out to be extremely messy and annoying. When I accidenetly discovered the tape method I was very releived that there was an easier way.
Whiskey Whiskey is offline Find More Posts by Whiskey Whiskey
Old Jan 24, 2013, 09:58 AM
FoamJunkE is offline
Find More Posts by FoamJunkE
EDF Junkie
FoamJunkE's Avatar
San Antonio, TX
Joined Jul 2010
I just recently stripped down my F-18 using low odor mineral spirits and it took all the paint off and left the decals perfectly intact. I plan to glass and repaint in Model Masters Blue Angels Blue and Yellow paint thats more accurate than the stock dark blue paint. It is a messy job but for such a small airframe its not too bad IMO.
I have found it next to impossible to get some of these water slide decals off of EPO airframes. Now that is a pain for sure.
FoamJunkE is offline Find More Posts by FoamJunkE
Old Jan 24, 2013, 11:24 AM
Mrgeorgedoors is offline
Find More Posts by Mrgeorgedoors
Mrgeorgedoors's Avatar
United Kingdom, Warrington
Joined Nov 2012
My edf's went weird on me today. And this is the result
Mrgeorgedoors is offline Find More Posts by Mrgeorgedoors
Old Jan 24, 2013, 12:14 PM
alpea 41 is online now
Find More Posts by alpea 41
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
I think I would send in my transmitter
alpea 41 is online now Find More Posts by alpea 41
Old Jan 24, 2013, 07:59 PM
Valkpilot's Avatar
Joined Mar 2012
Nigel
Would one of those lint rollers that use masking tape work?
Old Jan 24, 2013, 08:01 PM
Valkpilot's Avatar
Joined Mar 2012
Is Model Masters an acrylic? I thought it was enamel, and couldn't be used on foam.
Old Jan 24, 2013, 08:05 PM
Valkpilot's Avatar
Joined Mar 2012
It does look like guidance failure. What TX/RX setup were you using?
The Sabre doesn't look too bad, just might need to dunk it. And the Goshawk
looks like a clean break. A little CA and maybe some toothpicks
as rebar should work.
Discussion Adelaide & SA flying & chat #2 Zootster Australia 22526 Yesterday 03:33 AM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
