Old Dec 13, 2012, 03:55 AM
dahawk47 is offline
Find More Posts by dahawk47
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
crash,
Yes, the T-45 comes with attachable gear. Not steerable as there is no rudder. I never installed mine as this plane is really a hand launcher and not only would they look stupid, they just add drag. Since I've learned to never throw anything away, I've saved them for a rainy day.
dahawk47 is offline Find More Posts by dahawk47
Old Dec 13, 2012, 08:12 AM
nebuchadnezzar is offline
Find More Posts by nebuchadnezzar
gilford, new hampshire, usa
Joined Nov 2003
Aha! Did you see that there is now a new official diagnosis for the "hoarding disease"?!
nebuchadnezzar is offline Find More Posts by nebuchadnezzar
Old Dec 13, 2012, 09:04 AM
dahawk47 is offline
Augermeister
dahawk47's Avatar
Joined Jul 2011
LOL ! I know. What I found was when I threw out misc parts and pieces, a new build would come along and I'd smack myself in the head for having thrown out something I could have re-used. One little screw, washer, clevis, horn, rod, snap ring, connector, prop adaptor, piece of CF, shrink tube,etc. Saves me some trips to the LHS. Plus, when I bring my tool box to the field, there's always someone asking: " Does anybody have a ....?" I usually have it.
So, I admit I'm a hoarder !
-Hawk
Old Dec 13, 2012, 09:25 AM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
aren't we all hoarders? the problem arises when i have so much i don't know what i have and can't find it anyway
chas650r is offline Find More Posts by chas650r
Old Dec 13, 2012, 09:29 AM
AirbusDriver is offline
Find More Posts by AirbusDriver
Canada, ON, Toronto
Joined Jan 2012
Originally Posted by mopetista View Post
+1 - don't forget to put the lipo in the rear of the cockpit area, then you'll be fine with 3 cells 850mA to 1000mA
I'm using the Zippy Compact 3S 1000mah 25c in my F16. It fit with no trimming, other than removing the barrier thing in the middle. It's at the rear of he compartment. I needed a few grams in the tail to get 60mm CG. I'm considering adding just a bit more to get 65mm as people here have recommended.
AirbusDriver is offline Find More Posts by AirbusDriver
Old Dec 13, 2012, 09:56 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Yep, I am a member of that club as well.
Joe 1320 is offline Find More Posts by Joe 1320
Old Dec 13, 2012, 12:06 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
@Hobby B
Thanks for the code.
You should edit your profile to put a link under your username instead of registered user.
I believe that's one of the sponsor perks.
Hard to order with no PNP's in stock. You expect some in soon?
IFlyRCs is offline Find More Posts by IFlyRCs
Old Dec 13, 2012, 02:40 PM
hate2crash is offline
Find More Posts by hate2crash
Joined May 2010
Originally Posted by dahawk47 View Post
crash,
Thx hawk, I will be running my 3s 1000mah packs i use in my f9f....I also have 3s 1300 mah packs anyone using packs this large...and is cg in manual spot on...of coarse i'm not even sure if this plane comes with a manual lol...thanx again for all the great pointers...
hate2crash is offline Find More Posts by hate2crash
Old Dec 13, 2012, 03:09 PM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
I fly mine with 4S 1600 Zippy Compacts ... which are way heavier than stock recc'd. For this size - I have about 25grams added to tail to help bapance out, but note that this does not bring balance back to manuals CoG point .. I am quite a way fwd of that. But she flies fine.
The T45 is actually very tolerant of CoG as long as you do not go REAR of the advised.
I also fly mine with that weight on 3S of 1300 up to 2200 sizes. I make no changes at all to the model.
Note that the manual says clearly that when balanced she should have nose pointing a few degrees DOWN from horizontal when upright ... that is absolutely correct.
If you don't have a manual - they are available from Skyangel direct for download .... http://www.skyangelrc.com/
nigel
solentlife is online now Find More Posts by solentlife
Old Dec 13, 2012, 05:23 PM
Joined May 2010
Thx nigel... with 4s are u running stock motor and fan? thats a whole lot of battery for that little t-45...Thats awesome!
Old Dec 13, 2012, 08:19 PM
presa1200 is offline
Find More Posts by presa1200
presa1200's Avatar
Joined Nov 2010
nigel
nigel I can't find any link to download manual on http://www.skyangelrc.com/
presa1200 is offline Find More Posts by presa1200
Old Dec 13, 2012, 09:24 PM
Mike20 is offline
Find More Posts by Mike20
Mike20's Avatar
Joined Sep 2012
Since we're on the topic of cg I'm curious what others have their cg at for their t45s. The manual says 50mm but mine is VERY nose heavy at 50mm. To the point that my cg machine from tower hobbies can't move forward anymore. Anyone find the sweet spot? I use sky lipo 3s 800 mah 40c.
Mike20 is offline Find More Posts by Mike20
Old Dec 13, 2012, 09:33 PM
dahawk47 is offline
Augermeister
dahawk47's Avatar
Joined Jul 2011
I found the T-45 to fly well a little nose heavy.Rather have it that way than the alternative.
Old Dec 13, 2012, 09:37 PM
SPEED-E-FLYER is offline
Find More Posts by SPEED-E-FLYER
INDORUS EXPARAMINTO
SPEED-E-FLYER's Avatar
Springfield, Missouri, United States
Joined Jul 2002
I need the CG for the F-9 , AMX, and T-33 please.
Larry
SPEED-E-FLYER is offline Find More Posts by SPEED-E-FLYER
Old Dec 14, 2012, 01:16 AM
Tom77 is offline
Find More Posts by Tom77
Joined Feb 2009
Larry
Hi Larry,
There is another thread in this same sub-forum with the cg for all these 50mm planes. I forget the exact thread title, but it is something about "CG of 50mm skyangle... something something" so it is pretty easy to find. (Except now I can't find it?!?)
Have fun with all those. I have the T-33 and it flys really well and looks great in the sky! (That one is a little hard to launch though.)
Tom77 is offline Find More Posts by Tom77
Discussion Adelaide & SA flying & chat #2 Zootster Australia 23107 Today 04:00 AM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
