Old Dec 07, 2012, 06:18 PM
Scamp73 is offline
Find More Posts by Scamp73
Scamp73's Avatar
United States, NC, Autryville
Joined Jan 2012
Originally Posted by alpea 41 View Post
Spektrum calls it elevon also. One servo to aileron one servo to elevator if up or right is reversed switch the plugs. If both control surfaces are reversed then reverse the channel directions... Or something like that. And of course, un inhibit elevon mixing. Most importantly check the direction of the controls b 4 flying.
Figured it out. V-tail mixing did it on the DX7
Scamp73 is offline Find More Posts by Scamp73
Old Dec 07, 2012, 06:42 PM
alpea 41 is offline
Find More Posts by alpea 41
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
My son says it's called "delta mixing" on the DX -7." V tail " mixes rudder and elevator. So you would have to use both sticks to fly it
alpea 41 is offline Find More Posts by alpea 41
Old Dec 07, 2012, 06:48 PM
hate2crash is offline
Find More Posts by hate2crash
Joined May 2010
Hey guys...I was wondering if anyone new how to find air frame for sky angel F9F i had a couple of pretty bad crashes...I remember a guy posted a direct link to f9f kit on HK site but i can't seem to locate... went to HK and not sure how they have it listed...thx
hate2crash is offline Find More Posts by hate2crash
Old Dec 07, 2012, 07:17 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
http://www.hobbyb.com/skyangel-jpowe...html?cPath=121
Joe 1320 is offline Find More Posts by Joe 1320
Old Dec 07, 2012, 07:35 PM
Cody f86saber is offline
Find More Posts by Cody f86saber
Edge of the World
Cody f86saber's Avatar
Canada, NB
Joined Apr 2006
Originally Posted by www.hobbyb.com View Post
We have both in stock.
http://www.hobbyb.com/skyangel-jpowe...nly-p-336.html
Now, buy ANY TWO Skyangel 50mm EDF planes and get THREE stock 50mm EDF unit FREE. No code required.
Merry Christmas to all of you.
Will you be carrying replacement parts like the nose cones for the 50mm series of EDFs? Thank you.
Cody f86saber is offline Find More Posts by Cody f86saber
Old Dec 07, 2012, 07:57 PM
Edge of the World
Canada, NB
Joined Apr 2006
Originally Posted by AirbusDriver View Post
So I've added a 3" long (1/4" dia) steel rod into the back of the rudder/fin and now I'm pretty much right at 60mm but I'm wondering if I should keep adding weight to get to 65mm. I'm using the zippy 3S 1000s mounted in the rear of the hatch with the RX toward the front. Where else can I hide the excess weight?
My F-16 was nose heavy in stock configuration. My Center of Gravity is at +70mm and I moved the fan back a considerable distance, relocated the ESC in the ducting and this allows me to balance a number of packs, moving them forward or aft as needed. The plane travels flat and true but can approach landings in a high alpha with persuasion from the elevator. Here are some pics that might help illustrate how I did it. Best wishes.
Old Dec 07, 2012, 08:54 PM
Scamp73 is offline
Scamp73's Avatar
Joined Jan 2012
You are correct. My friend programmed it for mesaying one thing but actually doing another.
Old Dec 08, 2012, 02:40 AM
efflux RC is online now
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
My F-16 is waiting to be built. Toooo many projects!
Haven't decided on the 3s or 4s Wemo/HET setup yet. Either way it should be a little rocket.
Be sure to add a 75% FSA thrust tube if ya really have the need for a bit more speed.
We currently have the HET motors on sale.
efflux RC is online now Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Dec 08, 2012, 06:05 AM
green_flyer is offline
Find More Posts by green_flyer
we can take off without that
green_flyer's Avatar
London, UK
Joined Nov 2008
I never belived that saying, if there is a tree or some other obstacle in your airspace you are bound to hit it eventually.
Well, I finally hit the high voltage pylon wire in my flying field. Managed to keep the AMX in the air and landed safely. Looks worse than it is, now I got to repair it with something. maybe glass and resin?
Oh, and I can confirm, styrospray 1000 does crack on impact
green_flyer is offline Find More Posts by green_flyer
Old Dec 08, 2012, 09:21 AM
pajlotmato is offline
Find More Posts by pajlotmato
Slovakia, Veľký Krtíš
Joined Dec 2006
I maidened my L-39 Albatros today, outside temperature -5°C, wind calm, perfect for maiden flight...It is EXCELENT FLYER, I LOVE THIS JET...My setup: inrunner motor http://www.himodel.com/electric/5828...F130-2030.html from HiMODEL, this EDF: http://www.hobbyking.com/hobbyking/s...inch_50mm.html with Turnigy Plush 30A ESC and battery Turnigy nano-tech 3S 1300 mAh 35-70C which perfectly fit to the front of the fuselage under canopy, RTF weight 380g but I had to add 5g metal weight to the front of the fuselage because of CG, output power from edf more than 290W, for level flight is sufficient 40% of power. Landing is pleasure...ENJOY video...
mini L-39 Albatros 50mm EDF (3 min 12 sec)
pajlotmato is offline Find More Posts by pajlotmato
Old Dec 08, 2012, 09:51 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Great job on the plane and nice video. Thanks for not using music!
So the L-39 is a slow landing floater.
Gotta have one now.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Dec 08, 2012, 12:43 PM
Joined May 2010
Originally Posted by Joe 1320 View Post
Very cool, I live in usa...Do they ship from china? how long do they usually take to deliver using air mail which is $28 for 2 shy angel air frames... thx for the link
Old Dec 08, 2012, 01:25 PM
Mike20 is offline
Find More Posts by Mike20
Mike20's Avatar
Joined Sep 2012
So maidened the t45 after I glued her back together after my big crash. I put 4 magnets on the fuselage and 4 on the main wing and it held on good. (I haven't tried inverted flying yet) I also put my control linkages on top of the main wing and put in the HX900 servos in to replace the jittery stock ones. I tried out my new sky lipo 3s 1600mah 40c packs and it made the plane nose heavy but flyable. So good day flying with decent weather. Grey sky with ESE 13mph winds. Love how visible this plane is in grey skies. I have the t45 kit with a 50amp ESC I'm still deciding what to put in that. I think I may stay with 3s and go with the wemotec edf unit and 4800kv motor from don. Will this setup be fast?
Mike20 is offline Find More Posts by Mike20
Old Dec 08, 2012, 01:34 PM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
http://www.youtube.com/watch?v=PhtpM9RTths
That looks like a good power set up! Plane flies wonderfully! What surprised me the most about the L-39 is how slow it lands! I may have to try one of those motors in the 8 blade 50mm housing that I have.
Also you may want to just get a battery that is 5g heavier rather than adding the weight. I just moved my battery further forward and that helped.
Mine is 2 years old now and I usually fly it about 3-4 times per weekend. Still love it and always put on a great show with it!
gooniac33 is offline Find More Posts by gooniac33
Old Dec 08, 2012, 02:09 PM
Bajora is offline
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
I think that is a custom paint job on your L39? Looks pretty sweet!
Bajora is offline Find More Posts by Bajora
Discussion Adelaide & SA flying & chat #2 Zootster Australia 22760 Today 06:56 PM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
