Old Nov 23, 2012, 03:51 PM
cmd is offline
cmd
Find More Posts by cmd
cmd
cmd's Avatar
Niceville, FL
Bottom of the page indicates it is 64mm dia.
My error, at the bottom of the page it says 64mm dia is next!
Originally Posted by solentlife View Post
Anyone tell me about this one ?
http://www.rclander.com/default.aspx...b-b17b80c294f2
I don't see any mention of the diameter - I can only assume that the model Id having 50 in it may mean it's a 50mm ?
Nigel
cmd is offline Find More Posts by cmd
Old Nov 23, 2012, 06:37 PM
bribtb is offline
Find More Posts by bribtb
Joined Oct 2011
Originally Posted by miketre View Post
Only the first batch of the 4S version had problems. My 2nd batch (V2) has held up well.
On the 3S version, I had about 2 failures. One of them was my fault. I thought it was a 4s plane and flew it on 4s. I have 3 or 4 other 3S units that are still holding up.
Hi, what kind of numbers are you getting from the 3s and 4s versions? I am get only 15A on the 3s with 170 watts kv 4600.
Thanks, Brian
bribtb is offline Find More Posts by bribtb
Old Nov 23, 2012, 07:11 PM
dahawk47 is online now
Find More Posts by dahawk47
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
Originally Posted by AirbusDriver View Post
Should the ESC on the F-16 be in the airflow from the intake or is it ok to be just behind (and under) the canopy (just running stock 3S)?
Still waiting on my lipo shipment to arrive so I can maiden her.
Air,
A great little 3S lipo for the f-16 that fits like a glove is the Hyperian G3 850mah.
Pat sells them at Niko Hobbies: http://www.nicohobbies.com/store/ind...3162377ca9abec
No cutting of foam required even though the F-16 has probably the smallest cabin in the series.
-Hawk
dahawk47 is online now Find More Posts by dahawk47
Old Nov 24, 2012, 12:46 PM
AirbusDriver is offline
Find More Posts by AirbusDriver
Canada, ON, Toronto
Joined Jan 2012
I ordered the zippy compact 1000mah 25c's about a month ago. They "should" be here this week. I'm planning on mounting them in the aft section of the compartment to try to get 65-70mm CG.
Thanks for the advice!
AirbusDriver is offline Find More Posts by AirbusDriver
Old Nov 24, 2012, 03:07 PM
green_flyer is offline
Find More Posts by green_flyer
we can take off without that
green_flyer's Avatar
London, UK
Joined Nov 2008
I got a M5 tap today, and managed to set up the Lander 53mm rotor on the turnigy motor. I actually quite like the Lander design, it has these indexing blobs on the inside of the rotor, so I drilled a couple of holes on the M5 prop adapter so they would fit in. Very useful for inrunners as it prevents the motor turning as you tighten the rotor securing nut.
Tapping the plasitc dome was very easy.
I test fitted the turnigy motor in the lander housing just for fun, fits perfectly, but I wont be using it because of its weight, and because I dont want to ream out foam and limit my choice of fans just yet.
Tomorrow hopefully a test run in the Jpower stock housing to see what it can do.
green_flyer is offline Find More Posts by green_flyer
Old Nov 26, 2012, 12:12 AM
miketre is offline
Find More Posts by miketre
miketre's Avatar
Joined Dec 2010
Thanks, Brian
On my 4S, IIRC, I was getting 29A. This was with the V2. Didn't measure the V1 that burned up.. ESC timing is on low.
I don't think I ever measured any of my 3S alloys. I only measure it if I'm putting together a fan and motor, or if I'm having problems with my set up.
I'm using the HK 3s version which has a 4800kv motor, so it is probably different than your 4600kv version. My ESC timing is on high.
miketre is offline Find More Posts by miketre
Old Nov 26, 2012, 06:23 AM
London, UK
Joined Nov 2008
I am getting those exact numbers too 170W, 15A, 11.3V using a nanotech 850mah, mine is the 4600k version also, I got it from RC Castle not HK. Looks like the HK version is hotter, I wish I got that one instead.
However mine is mounted in a JPower-like housing and rotor shaved down to 50mm, so I lost a little fan swept area.
323g static thrust peak.
Old Nov 26, 2012, 09:01 AM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
I can't wait to try out this new 10 blade unit....
gooniac33 is offline Find More Posts by gooniac33
Old Nov 26, 2012, 09:51 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
what 10 blade unit? I have a ChangeSun 10 blade 70mm on the way, is there a 50mm version?
Joe 1320 is offline Find More Posts by Joe 1320
Old Nov 26, 2012, 10:45 AM
flylow2011 is offline
Find More Posts by flylow2011
Joined Nov 2011
the new 10 blade rclander 50mm fan, 97 gr, looks very good on paper to me :-)
here http://www.rclander.com/default.aspx...b-b17b80c294f2
I have been thinking of using this one for a phase 3 f-16 or something similar...
with up to 650g / 27A it is not bad for a phase 3 F-16 though :-)
flylow2011 is offline Find More Posts by flylow2011
Old Nov 26, 2012, 11:40 AM
bribtb is offline
Joined Oct 2011
The stock fan has more power than the Rclander. Mine is from Toysonics. You have to on the Mig 15 give it a really good throw to get it launched. I have talked to Tim and he's checking into it. The one from them are all silver.
Brian
Old Nov 26, 2012, 11:53 AM
London, UK
Joined Nov 2008
Brian
Thats not what I found. I have 4 stock fans and none of them produced more than 265g static in any airframe, on a 850mah battery. The Lander fan (at least my one) produced 323g and thats even when cut down to 50mm in the stock JPower housing.
I read on HK that they posted some 3s fans with the 4s motor wrongly labelled, and people were struggling to acheive 250g thrust, maybe they sent you one with a 4s motor by accident.
Old Nov 26, 2012, 02:35 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
yes what he said...LOL I said the exact same thing you did...but yes it is true!!
Old Nov 26, 2012, 03:28 PM
London, UK
Joined Nov 2008
I did a static thrust test of the Turnigy 5000kv inrunner. Sadly, its a bit dissapointing, I had higher hopes. Efficiency is low, the motor is essentially an amp hog. Almost 22A, 238W for only 343g static.
Here is a comparison of the Turnigy motor with the Lander motor. I wouldnt want to eat up 7A more for only 20g more thrust. My search for a high efficiency low weight motor continues.
Its true some things were not constant, different airframes, different ESCs, but still I was expecting more out of the Turnigy.
Lander Rotor, JPower housing/JPower copy housing, Nanotech 3s 850mah 45C, 25A ESC (Phoenix/Turnigy plush)
Motor--------------------Airframe----------------Peak Thrust----------Peak A----Peak V---Peak W----Efficiency
Lander 4600kv-------F35-----------------------323g---------------------14.98------11.36------170-----------1.9g/W
Turnigy 5000kv------F22-----------------------343g---------------------21.77------10.96-------238----------1.44g/W
Turnigy 5000kv Lander rotor F22 airframe (0 min 44 sec)
Old Nov 26, 2012, 03:36 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
ya , that test leaves some to be desired , the f22 has about the worst ducting , both in and out.
chuck.
chas650r is offline Find More Posts by chas650r
Discussion Adelaide & SA flying & chat #2 Zootster Australia 22627 Today 05:39 AM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
