Old Nov 19, 2012, 11:53 PM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Originally Posted by chas650r View Post
this get funnier by the post.......... the above still doesn't address how the rotor is held on the shaft, 2.3 or 3mm.
You can laugh ... but I'm screaming around the skies with what must be one of the fastest 50mm T45's ...
The shafts that are supplied with the Turnigy motors are actually same as the stock size motor INTERNALLY ... it is only the external part that is 2.3 or 3mm.
I took the shafft of the burnt out Jpowers 4300 motor and installed that into the 2610 5000kv motor.
Laughing now ?
The way I did it has been posted so many times here and on Wattflyer that I got lazy and left out the swap of shaft.
Nigel
solentlife is online now Find More Posts by solentlife
Old Nov 20, 2012, 12:02 AM
solentlife's Avatar
Joined Jan 2010
Originally Posted by KCinNC View Post
nigel , i like the canopy latch you have on the t-45, any tips on how you did that ? i'm tired of usng a rubber band to hold the canopy on
I got fed up retrieving hatches of models so decided to find a better way. They are on ebay and Hobby King ... sprung pin jobs.
http://www.hobbyking.com/hobbyking/s...0pcs_bag_.html
They are really meant to be mounted inside a fuselage for gliders etc. but our foam models are too thick. So I made a slot as you see at rear of canopy in the fuselage .. epoxied the latch in place. The canopy was then put in place and pin allowed to mark the rear ... a spent ballpen ink tube was cut and epoxied into the canopy at that point for pin to engage. If you don't fit a tube - the foam soon wears and enlarges.
The speeds my T45 is doing now - and the flex on airframe - no way will the factory magnets hold that canopy ...
Reminds me - I must get some more !!
Nigel
Old Nov 20, 2012, 12:21 AM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
Nigel
good deal...i can use these big time !
KCinNC is offline Find More Posts by KCinNC
Old Nov 20, 2012, 12:42 AM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
Laughing now ?
Nigel
the laughing had nothing to do w/ what u did or how , it was the fact that some here could not get that the motor in question does not come w/ a threaded shaft.
simple and effective fix , just needed the answer
chas650r is offline Find More Posts by chas650r
Old Nov 20, 2012, 05:41 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
The better setup would be the cut down lander rotor. You'll get higher thrust with a lower amp draw due to more effecient rotor design. If you want even faster, Don's wicked 6000 kV in the wemo on 4s. Hands down it whips anything else in the 50mm catagory. You know what they say, there's always someone faster.
Joe 1320 is offline Find More Posts by Joe 1320
Old Nov 20, 2012, 06:30 AM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Joe,
Seeing that video of the Screamer has me thinking I need to make a special one myself. I do have to say the Wemotec fan may be more costly than other 50mm fans but it sure works well
The Don is offline Find More Posts by The Don
Old Nov 20, 2012, 06:37 AM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Nigel,
If you get some video with the passes a little closer to the camera and the throttle held a second or two longer I can doppler the speed of your T45 and we can compare to other T45s that have been dopplered.
Don
Old Nov 20, 2012, 08:50 AM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Originally Posted by The Don View Post
Joe,
Now that I have seen it work I will be getting one too. There is more room in the Katana so I may try it in that plane. But the Screamer was amazing with that set up! Not sure what other airframes could fit the battery needed to supply the power required.....But I am gonna think about it....
gooniac33 is offline Find More Posts by gooniac33
Old Nov 20, 2012, 12:16 PM
solentlife's Avatar
Joined Jan 2010
As before - I'm not confident enough to cut down a rotor ..... so the Lander is out.
6000kv ... now that's another matter ....
And too true - there usually is ....
One of the problems with the T45 is the airframe literally hits a max at about 140kph in the 50mm size ... the amount of thrust I'm getting now should have pushed her way past that - but it doesn't ... If the same could be put into the F16 or sinilar - that would be a different result.
Nigel
Old Nov 20, 2012, 12:22 PM
solentlife's Avatar
Joined Jan 2010
Nigel,
Don
RCSpeedo has dopplered mine at just over 140kph ...
Stock was 85kph with 90 after a short dive.
4S on the stock was 110kph with 120 after short dive.
51mm 7 blade and 4890kv was 120kph
My present 50mm with 6 blade and 5000kv hits consistent 140kph.
I don't know what Doppler program your using but my RCSpeedo on PC and Android seems to do the job OK ...
OH and when I said "fastest 50mm etc. " I was prodding to get response !! I know I'm not fastest ... but it's still not bad.
Nigel
Old Nov 20, 2012, 12:50 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Nigel
My T-45 with himax 50mm combo, 4s 40c 1000mah sky lipo pack and no other mods is doing about 80mph. Stock exhaust diameter as well. I am sure that if I messed with it a little that I could get it in to the 85mph range or higher. It has way over 1:1 thrust to weight and can climb up as far as the battery and radio will allow it. So just a little more to go and it will gain some speed. The intakes are a little big but I can make use of what I have. 4100kv on 4s makes good speed! But the 6000kv set up from Don would really make it scream!!!
Old Nov 20, 2012, 02:13 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Joe,
Don, with your balancing equipment, I wouldn't even hesitate. The Screamer is just that... a screamer. Yours would simply be a Wicked Screamer.
My T-45 is getting it's power system yanked and your 6000 kV 4s combo is going in to break over the 100 mph / 165 Kph level. Then it will go in the Screamer for a max speed effort. I personally think the Screamer is THE speed airframe in this series. I also want to test my Hoffman 5580 kV on 4s just as a comparison. I currently have that in a Hyperflow fan and it's an amp hog, I want to try it in the Wemo.
Old Nov 20, 2012, 03:50 PM
Mike20 is offline
Find More Posts by Mike20
Mike20's Avatar
Joined Sep 2012
I miss flying do I've decided to rebuild my crashed t45 and use the stock setup and when I have the money I'll get the airframe and dons wicked combo. My only problem is I don't have a vertical stabilizer. And I'm not good at forming foam so is there anything else I could make it out of or even a way I can make another one?
Mike20 is offline Find More Posts by Mike20
Old Nov 20, 2012, 04:19 PM
Great_Goose is online now
Find More Posts by Great_Goose
Flying from Vic Park
Great_Goose's Avatar
Australia, SA, Adelaide
Joined May 2011
Mike20, I have one if you want to pay the postage from Oz.
Do you need any bits?
Great_Goose is online now Find More Posts by Great_Goose
Old Nov 20, 2012, 07:44 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
balsa and paint or flim?
Discussion Adelaide & SA flying & chat #2 Zootster Australia 22874 Today 04:34 AM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
