Old Nov 18, 2012, 02:53 PM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
I know some have seen this before but here it is again ...
50mm T45
2610 Turnigy 5000kv
50mm 6blade fan in stock shroud
50A ESC
4S 1600 LiPo
Cheap set-up but boy does she motor on it .... I love the sound of that 5000 on song ....
T45 50mm 4S 1600 21-09-12 (4 min 58 sec)
Wondering where to go next to get even more speed / power out of her ... she's at over 700grams thrust with above ..... so it will need serious modification to improve on that ....
Nigel
solentlife is online now Find More Posts by solentlife
Old Nov 18, 2012, 05:33 PM
flylow2011 is offline
Find More Posts by flylow2011
Joined Nov 2011
50mm T45
2610 Turnigy 5000kv
50A ESC
4S 1600 LiPo
Nigel
how do you fit the 6 blade rotor on that motor shaft?
you use an adapter for it ??? How?
thx
flylow2011 is offline Find More Posts by flylow2011
Old Nov 18, 2012, 07:58 PM
alpea 41 is offline
Find More Posts by alpea 41
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
you have to drill the hole a little, then it threads onto the shaft
alpea 41 is offline Find More Posts by alpea 41
Old Nov 19, 2012, 12:47 AM
Bajora is online now
Find More Posts by Bajora
KA6KHM
Bajora's Avatar
Joined Sep 2004
Our complete article on the Katana and Screamer is now up over on HDFlyer.com
Bajora is online now Find More Posts by Bajora
Old Nov 19, 2012, 01:03 AM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
That was really nice Video Jon. You guys always do great work. Thanks !!
We now have the 4s setups too. 337 Watts.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Nov 19, 2012, 08:57 AM
solentlife's Avatar
Joined Jan 2010
thx
The shaft is M3 threaded ... so you ream the rotor shaft hole to just UNDER a M3 thread tap size ... you then use the thread tap to cut the M3 thread into the rotor hub. I put 3 good fit washers on shaft as spacers before screwing the rotor on. This prevents the hub from grounding on the shroud mount area and motor screws.
The direction of rotation tightens the rotor onto the shaft so i don't even need a locking nut or anything else.
It was purely by accident I found this worked !!
But please use a tapered reamer ... do not drill out the rotor hub. Because of the taper - I reamed from BOTH sides so that thread tap wasn't going to split the hub.
easy peasy ...
nigel
Old Nov 19, 2012, 09:04 AM
dahawk47 is offline
Find More Posts by dahawk47
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
Jon,
Site and articles are great ! How do you keep your Katana looking so nice? Mine scratches up very easily and now looks like I've been landing her in a gravel pit. I even mini-waxed it.
dahawk47 is offline Find More Posts by dahawk47
Old Nov 19, 2012, 10:09 AM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Originally Posted by dahawk47 View Post
How not to fly the Katana
http://youtu.be/7oWD027uBpE
Not off to a good start on this one. Low thrust though I had a new 4S 850mah Nano this time. Also seemed tail heavy. I had the battery against the firewall and the RX out in front . I'll try moving the lipo forward. The 4800kv Don's setup should be fine but I still wonder why there are only 4 blades to the fan.
It was the launch that doomed that flight....but the battery is way too small as well but I see that you changed that later on... The smallest that can be used is the 4s 40c 1000mah packs. But you really should use bigger than that....
Well,
Gave the Katana another go today after yesterday's debacle. Good news to report but unfortunately, there was no-one to run my i-phone camera.
Installed the 1000mah 4S nano , moved it forward and mounted the rx upright along the firewall. Balanced much better and made a world of difference. Launched her underhanded with less AOA this time. Perfect. Only had a couple clicks of down and she trimmed-out nicely. Flew on high rates and she's still a little too twitchy for my liking but will add-in a little more aileron expo. Was gusty today.
Overall, IMO , the Katana is an easy flier not much unlike the T-45 and even the Phase 3 F-16 which flies on rails. Probably not going to set any speed records but that's okay with me. When I want speed, I pull out my Rare Bear. She's very maneuverable with the rudder but I haven't tried anything crazy yet. Not sure if she will flat spin.
On the QC site, the paint job is awful. Flakes off way too easily.
The 4800kv Don's set up is a very good option for this plane given the fact that you need a decent 4S lipo of at least 1000mah. Had my doubts initially but I can now highly recommend. The little 850 4S Nano cube doesn't cut mustard IMO. She needs and deserves a decent 4S battery.
If the weather holds I will give her another go tomorrow and try to get some footage.
I'm a happy camper again!
-Hawk
Glad you got it going!! I love mine as well and need to do a quick vid of mine as well. It has about 400watts of power and really flies nice! It isn't super wicked fast but it is powerful and flies so smooth!! And I haven't even hooked up the rudder servo yet...LOL
50mm T45
2610 Turnigy 5000kv
50A ESC
4S 1600 LiPo
http://www.youtube.com/watch?v=S3nyh...9&feature=plcp
Nigel
Now that sounds like my T-45 does with a fresh battery!! It flies great in spite of that super huge heavy pack!
Jon,
My issue with the Katana is the decals...they flack off really easily... But the flying characteristics make up for it all...it is one of the best flying 50mm planes in this series!!
Now that I have some extra fundage coming....I will be getting about 4 different set ups to try out in these little jets. I will be getting a Screamer and another F/A-18 airframe to try out the new fans. I am really wanting to get this 50mm 10 blade fan in there.... Lots to come!!!
gooniac33 is offline Find More Posts by gooniac33
Old Nov 19, 2012, 10:30 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
-Hawk
That seems to be the case with all of them. On some of mine, the decals flake off if you look at them the wrong way, others are durable is heck. My Katana seems to be quite good, where my parts of my F-16 decals flake off with every flight. I've learned to be real good with touch up paint.
Joe 1320 is offline Find More Posts by Joe 1320
Old Nov 19, 2012, 10:48 AM
mopetista is online now
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
easy peasy ...
now would you believe it most people find out (by accident or otherwise) how to get a plastic rotor with a 2mm to fit a threaded 3mm shaft - by enlarging the hole :-)
joking aside, I think the question was rather how to fit the 6-blade rotor to a Turnigy 2610 motor which has a 3mm - non-threaded - shaft. That is the motor you state you are using, not the stocker. I guess it has been asked before but I don't remember the answer...
cheers
Clemens
mopetista is online now Find More Posts by mopetista
Old Nov 19, 2012, 01:06 PM
Mike20 is offline
Find More Posts by Mike20
Mike20's Avatar
Joined Sep 2012
cheers
Clemens
The turnigy 2610 motor comes with both 2.3mm and 3mm shafts. So I'm guessing he used the 2.3mm and that's why he had to ream out the hole to fit the shaft.
Mike20 is offline Find More Posts by Mike20
Old Nov 19, 2012, 08:01 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
KCinNC's Avatar
United States, NC, Mooresville
Joined Aug 2007
nigel , i like the canopy latch you have on the t-45, any tips on how you did that ? i'm tired of usng a rubber band to hold the canopy on
KCinNC is offline Find More Posts by KCinNC
Old Nov 19, 2012, 11:17 PM
DonQ8401 is offline
Find More Posts by DonQ8401
Why am I addicted!!!
DonQ8401's Avatar
United States, IL, Columbia
This is what we do on the weekend. You can see some 50mm in there. I am the one that does a roll and almost hits a Stinger.
http://www.photoshop.com/users/Tripl...c1a3652cf2150b
DonQ8401 is offline Find More Posts by DonQ8401
Old Nov 19, 2012, 11:55 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
this get funnier by the post.......... the above still doesn't address how the rotor is held on the shaft, 2.3 or 3mm.
chas650r is offline Find More Posts by chas650r
Old Nov 20, 2012, 12:14 AM
KCinNC is offline
KCinNC's Avatar
Joined Aug 2007
here
easy peasy ...
nigel
Discussion Adelaide & SA flying & chat #2 Zootster Australia 22422 Today 10:52 AM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 04:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 11:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 20, 2010 12:07 AM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 04:42 PM
