Old Nov 11, 2012, 08:40 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
what kind of 30's were failing? was that w/ 5 or 6 blade? i have been using the 30amp h/wings on 4's w/ no issues, but only w/ the 5blade (21 amps ) and only w/ 2 servos. the servos count is a bigger issue imo due to the linear bec. 21 amps should not be a issue on the 30amp esc.
the 40 amp w the switching bec cures all but there is a big size and weight penalty.
chuck.
chas650r is offline Find More Posts by chas650r
Old Nov 11, 2012, 09:04 PM
alpea 41 is offline
Find More Posts by alpea 41
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
6 blader, Pentium Hobby Wing
alpea 41 is offline Find More Posts by alpea 41
Old Nov 11, 2012, 09:15 PM
Cheese5 is offline
Find More Posts by Cheese5
Cheese5's Avatar
United States, CA
Joined Jul 2010
The 6 blader draws at full throttle around 28A constant. It peaks at 31A and then drops steadily with my F-22. (stock everything except ESC and 6 blade fan)
Cheese5 is offline Find More Posts by Cheese5
Old Nov 11, 2012, 09:30 PM
alpea 41 is offline
alpea 41's Avatar
Joined Oct 2007
"That esplains it Lucy" said Ricky Ricardo
Old Nov 11, 2012, 10:33 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
egsackery!
Old Nov 12, 2012, 03:31 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Originally Posted by dahawk47 View Post
Mike,
The 50amp esc will solve your problem.Not sure about the little 2mm plugs though. I do recall experiencing an esc shut down on the T-45 w/ the 30 amper. Helpless feeling.
First thing I did was to get rid of the bulllets and fit a Deans .... No way with the amps I'm pushing through mine would those itty bitty bullets be man enough.
Nigel
solentlife is offline Find More Posts by solentlife
Old Nov 12, 2012, 05:33 AM
Mike20 is offline
Find More Posts by Mike20
Mike20's Avatar
Joined Sep 2012
Yea I'm thinking either deans but for now the yellow plugs which I believe are XT60 come pre soldered on. I'll use my charger adapter for now to go from the jst to the yellow plug. I've used deans in all my electric rc cars so after I get a solder iron Ill go that route.
Mike20 is offline Find More Posts by Mike20
Old Nov 12, 2012, 05:45 AM
solentlife's Avatar
Joined Jan 2010
Just for the record .... my T45 draws more than 40A when opened up ....... but I'm running 4S on a 5000kv motor with 6 blade rotor ........ gives me more than 1.1 to 1 thrust to weight ...
I have with experimenting with various such as 7 blade run over 60A !!
When I ran stock motor / fan - the stock ESC worked with 4S OK ... it was my antics that blew mine ...
Nigel
Old Nov 12, 2012, 06:22 AM
Mike20 is offline
Mike20's Avatar
Joined Sep 2012
Yea mine works now. I guess it just got hot and shut down. I thought I gave it plenty of time to cool down.
Old Nov 12, 2012, 09:52 AM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
A good combo worth trying out. A fellow flier at my field had an AEO 50mm 8 blade fan hooked up to the stock Skyangel motor on 4s. Less than 19amps draw and just under 300 watts with a lot of thrust! It was in his Screamer and it was much more than 1:1 thrust to weight! I think that may be the best combo that I have seen thus far! Very efficient! It flew great too but even at half throttle it was pretty fast! My have to get some 50mm 8 blade fans to try out....
Flew my Katana more this weekend and am just loving the way it flies!! I still have to hook up the rudder but it is on rails!! It tracks like a much bigger ship and can slow way down as well! Great flying jet! I need to try out a screamer...
gooniac33 is offline Find More Posts by gooniac33
Old Nov 12, 2012, 10:30 AM
dahawk47 is offline
Find More Posts by dahawk47
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
I'm hopeful to re-maiden my Katana later on today (weather permitting) with the Don's Wicked 4800kv set-up. Will remember to load a 4S in there ! Expecting good results
dahawk47 is offline Find More Posts by dahawk47
Old Nov 12, 2012, 11:13 AM
Mike20 is offline
Mike20's Avatar
Joined Sep 2012
Are there any US sites that sell the katana yet? The hobbyb.com website charges a lot for shipping. Hobbyking does too if you order from their international warehouse but their cheap prices makes up for it.
Old Nov 12, 2012, 11:31 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
It will scream with that combo...Literally!! I heard a fellow flier with that same set up in an F-22 this weekend and it was WICKED indeed! The Katana will love it! Just make sure to have a thrust tube in there...
dahawk47 is offline
Augermeister
dahawk47's Avatar
Joined Jul 2011
Mike,
I think Hobbyb has the early line on new Jpowers Skyangel releases. I went with the combo version w/out motor and bought the Don's Wicked 4800kv setup. Looks like it's sold out for now. Banana and Toysonics carry some of the others in the series.
Old Nov 12, 2012, 11:32 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
$77 shipped to my door is not too expensive.... Thats Servos, esc and plane....
Discussion Adelaide & SA flying & chat #2 Zootster Australia 22981 Today 05:02 AM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
