Old Sep 30, 2012, 07:25 PM
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
Originally Posted by Joe 1320 View Post
They had one prior to all these new models, I can't understand why it went away. It was about these same size as the current models and had a 64mm fan crammed in there. Performance was great!
Well, that one was actually an F-4B/N not a J or hard wing S. Either way it was a b!tch to launch but flew OK if you ever got it going. Mine ended up going straight in from about 100' due to a control failure (suspected broken clevis). What remained of the EPS airframe was low grade packing material.
Ted
G550Ted is offline Find More Posts by G550Ted
Old Sep 30, 2012, 09:51 PM
jchtr3a is offline
Find More Posts by jchtr3a
Warbird Fanatic
jchtr3a's Avatar
United States, PA, Coraopolis
Joined Jun 2012
F-86 cog
The manual for the F-86 puts the CG at 107mm back from where the leading edge of the wing meets the fuse. About 4 and 1/4 inches. Seems pretty far back. Even so I am having a hard time getting the plane to balance.
Most flyers seem to want it a bit nose heavy. I'm using a Turnigy Nanotec 950mah which just fits under the canopy.
Is that 107mm COG right? If so where is the best spot to put some weight in the nose?
It's a great little plane, and I can't wait to fly it. Just a bit worried that if it is too tail heavy, I'll wreck it.
jchtr3a is offline Find More Posts by jchtr3a
Old Oct 01, 2012, 06:09 AM
cmd is offline
cmd
Find More Posts by cmd
cmd
cmd's Avatar
Niceville, FL
Look here:
http://www.rcgroups.com/forums/showthread.php?t=1480110
cmd is offline Find More Posts by cmd
Old Oct 01, 2012, 07:55 AM
green_flyer is offline
Find More Posts by green_flyer
we can take off without that
green_flyer's Avatar
London, UK
Joined Nov 2008
Its amazing what a difference balde design makes!
I decided to remove the JPower-like 6-blade rotor I was using with a 30g 4900kv inrunner (the F35 flew quite well with it so I was a bit hesitant).
In its place I put in a cut-down HK Alloy fan rotor, aka Lander 53mm alloy fan.
The thing i noticed about this rotor is that the blades had a reducing pitch towards the tips, similar to the Wemo rotor. I had a gut feeling that this was a better blade desing than the simple paddle-like 6-blade rotor copy of JPower 5-blade.
It turns out I was right, 3A less, 20W less, but 16g more thrust at peak and settling to higher stable thrust. Not bad at all.
If only HK or someone would sell the separate adaptors as well as the rotors (which are only around $2), I would get more of these.
Here are some numbers and video to back up claim:
Motor: Neutron 705 4900kv 30g inrunner
ESC: Phoenix 25
Lipo: Hyperion 3s 850mah 25C
HK Alloy Fan rotor cut down to 50mm in JPower clone housing
Thrust--Amps-----Volts----Watts--WOT time elapsed
333g----15.24A---11.05V---168w---0s
290g----13.72A---10.50V---144W---14s
JPower clone 6-blade fan
317g----18.34A---10.40V---189W---0s
279g----16.63A---9.92V----165W---8s
Static thrust test JPower 50mm F35 with 5-blade cut-down rotor from Lander 53mm alloy fan (0 min 30 sec)
Static thrust test JPower 50mm F35 with Neutron 4900kv 6-blade clone fan (0 min 19 sec)
green_flyer is offline Find More Posts by green_flyer
Old Oct 01, 2012, 08:13 AM
Whiskey Whiskey is offline
Find More Posts by Whiskey Whiskey
United States, CA, Fairfield
Joined Jul 2004
Nice results, and that just goes to show that comparing whats Watts between different power systems is not reliable.
I had tried the HK Alloy cut down to fit in the stock housing along with the paired 3S 4800 kv inrunner in my F-35. I was so disappointed in the performance that I went back to the stock power system on 3S.
After that I tried the 4S on stock and that's currently my favorite setup.
I think what happened in my experience is that eflux has been sacrificed for higher thrust and less amp draw. Basically all the numbers we regularly use are advertised to be better, which they are, but the one that we can't reliably measure and are never provided with has been diminished.
Whiskey Whiskey is offline Find More Posts by Whiskey Whiskey
Old Oct 01, 2012, 08:28 AM
London, UK
Joined Nov 2008
Thanks.
I agree, watts to me is a almost useless measurement when comparing fans. I dont want more watts, I want less watts more thrust
I think the Lander 40g inrunner, although it is long, is weak. I tried my Lander/HK alloy inrunner in its original alloy fan and got only 343g peak (outside of an airframe). Inside an airframe its going to suffer losses and produce less thrust. Of course the HK alloy fan is 53mm inner diameter, so by cutting down to 50mm diameter we are losing approx. 14% fan swept area.
Old Oct 01, 2012, 09:50 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Picked up the Katana from the post office, they left me a notice on Saturday. That's usually the way the timing works for me. sunday would have been a great day to do the build. Oh well, at least the fun starts tonight. Everything looks good, no warps or damage. I just can't help myself, I'm going to put in an order to hobbyb for a few more airframes and motors/fans, I've gotten hooked on the 35mm series, the only 35mm planes I don't have now are the F-16 and T-45.
As soon as the EDF madness stops, I'm going to start hitting the prop planes. I've managed to resist myself for the longest time on those and I'm getting weak.....LOL.
great test BTW on the 6 blade. It's basically what I found some time back. The rotr is fairly stong, but not very effecient. In fact, all the haoye fans I ever tried were amp hogs for the output they made. Not very effecient at all.
Joe 1320 is offline Find More Posts by Joe 1320
Old Oct 01, 2012, 10:22 AM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
well i agree w/ u guys , there is a lot more to rotor design than meets the eye. that being said whiskey hit the nail on the head, its easy to get more static thrust w/ less amps. same with a prop , just reduce the pitch and add blade area. but eflux speed goes away, so it depends what u want. the over all performance is a combo of static thrust, eflux speed, and cfm , which is important as well.
very few manufactures give us much tech info on there rotors / fans, making informed decisions difficult at best. so the watts are still the easiest way to judge basic needs. one thing i know , there is no magic rotor/ motor combo cuz i have tried a bunch. so it still comes down to watts / pound , and for me 250 -300 / pound is minimum for a fun ride.
i have bench tested lots of bits combined w/ other bits and then installed them in a test jet . interestingly mostly a watt is a watt if and only if the motor is not overloaded. i had the same feelings about certain rotors , ie , man this has got to be better, only to find out that ya it's different ,maybe not better.
what would be cool would be to have different pitch rotors of the same type so u could tune the fan the the airframe, like u can w/ a prop. but for now i just go w/ the low blade count/ high pitch for fast , low drag airframes and higher blade count/lower pitch rotors for draggy planes.
so keep testing and reporting and will all benefit.
chuck.
chas650r is offline Find More Posts by chas650r
Old Oct 01, 2012, 10:25 AM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
good luck w/ that joe and if u find the cure let my wife know.
chuck.
Old Oct 01, 2012, 10:28 AM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
chuck.
And to add to that, everyone has different ideas as to what they want. Some want only the lowest amp draw coupled with the largest battery for long flights. Some want blazing speed and could care less about flight times, others want the sound of a turbine without regards to amps draw. There are soooo many choices.
Old Oct 01, 2012, 11:31 AM
London, UK
Joined Nov 2008
True, there are so many possible set ups.
Just to check my understanding, if everything else is kept the same (fan diameter, intake area, exit area, fan swept area, etc) but the static thrust is higher for one set up, does that mean the efflux speed is higer too?
I'm thinking more air has to move through the same size hole per second?
(thrust being the volume of air moved per second)
Old Oct 01, 2012, 12:13 PM
gooniac33 is offline
Find More Posts by gooniac33
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
I am going to order an RClander fan from Toysonics and then a Katana Airframe from HobbyB and try it out. I already have the 4s 25c 1550 mah gens ace packs....
gooniac33 is offline Find More Posts by gooniac33
Old Oct 01, 2012, 12:21 PM
dahawk47 is online now
Find More Posts by dahawk47
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
Might get a chance to maiden the Katana later today. I have the Don's Wicked 4800KV Wemo set up with balanced fan. 40 amp esc came with the combo deal. Too chicken to go with 4S from the start but will later if all goes as expected. Goony, everytime I look for a gens ace packs from Nitroplanes, they are out of stock. Not 100% sure about the throws.Re-reading manual. Looks like they need to be dropped a notch or two on the TX.
dahawk47 is online now Find More Posts by dahawk47
Old Oct 01, 2012, 12:24 PM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Just ordered my Katana. $77 shipped is a steal!!! Can't wait to get started on it....
Old Oct 01, 2012, 06:34 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
u are correct , but only regarding static eflux speed, as one type of set up may unload more than another .
if EVERY thing is equal and let say u change timing on the esc and u see more static thrust then u have more eflux speed and most likely more unloaded speed.
chuck.
Discussion Adelaide & SA flying & chat #2 Zootster Australia 22752 Today 02:22 AM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
