Old Sep 27, 2012, 11:25 PM
chuck
santa barbara, CA
Joined May 2009
Originally Posted by alpea 41 View Post
To me the F-22 seemed to be the most draggy of the 6 or 7 planes I've seen fly . But the new version 2 seemed a little quicker on 3 cells.
is the new version different or just not bent ?
chas650r is online now Find More Posts by chas650r
Old Sep 27, 2012, 11:37 PM
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
Just new.lol
alpea 41 is offline Find More Posts by alpea 41
Old Sep 27, 2012, 11:56 PM
chuck
santa barbara, CA
Joined May 2009
half the drag issues w/ my 22 is the design and the other half is left over warps after removing 75% when new. worst airframe i have ever bought , warpwise. a straight one would be cool.
chuck.
Old Sep 28, 2012, 12:02 AM
alpea 41's Avatar
Joined Oct 2007
Mine too. The new one was warp free 3 or 4 weeks ago.
Old Sep 28, 2012, 01:07 AM
boingk's Avatar
NSW, Australia
Joined Feb 2011
Hi there guys, I've had a Panther F9F 50mm in the past which I kept stock, and ordered another airframe for it as the current one needs some TLC to say the least.
Hobbyking sent me an L-39 Albatross instead... which I actually like!
My current plan is to use an AEO 50mm / 5800kv EDF setup with a 30A ESC in airflow and Turnigy NanoTech 45C 1000mAh 3s lipo packs.
Does that sound alright? I haven't designed an EDF power system before and was wondering if I'd overlooked something completely obvious.
Cheers - boingk
boingk is offline Find More Posts by boingk
Old Sep 28, 2012, 02:20 AM
Luck is my skill
queadlunnrau's Avatar
On Earth
Joined Jun 2009
Yo how did the f22 fly with the tv setup, looks pretty clan and I liie usong the clear plastic to hide it in flight
queadlunnrau is offline Find More Posts by queadlunnrau
Old Sep 28, 2012, 09:35 AM
chuck
santa barbara, CA
Joined May 2009
was that from b/h or?
Old Sep 28, 2012, 09:44 AM
gooniac33's Avatar
Sunnyvale
Joined Feb 2009
Cheers - boingk
That fan will work great! But if you can go up in the battery size. A 1300 would be a little better since it is gonna pull more amps. I have had an L-39 for almost 2 years now and it is still one of my faves! If you fly around at 1/2 throttle you can get some good flight times. And it is fast too! great all around plane...
gooniac33 is offline Find More Posts by gooniac33
Old Sep 28, 2012, 10:05 AM
alpea 41's Avatar
Joined Oct 2007
The F-22 w/ T V was slower than stock. It also was a little nose heavy w/ a 1000ma 4s battery. It high alpha-ed nice but you could tell the T V vanes took away from thrust. The V2 F-22 is from B H.
Old Sep 28, 2012, 10:46 AM
chuck
santa barbara, CA
Joined May 2009
thanks on the b/h , and ,ya the 22 is nose heavy and hates it , i moved my cg back from stock callout and will never go back.
Old Sep 28, 2012, 01:32 PM
boingk's Avatar
NSW, Australia
Joined Feb 2011
Thanks mate, very much appreciated. If she's tailheavy I will put a larger pack in (another HK order!) but otherwise I plan on keeping it light on the throttle unless I'm doing vertical or lowfield passes. I know these birds suck the mAh
- boingk
Old Sep 28, 2012, 02:17 PM
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Cheers - boingk
Well, I had to use a 3s 1000 mAh pack to get the CG correct when using the stock motor and fan. That AEO fan is going to draw 31A at wide open throttle and if you use a 1000 mAh pack, it's going to run out pretty quick. Using a larger pack will likely make it nose heavy unless you start cutting and moving the battery rearward. I personally think you'll need to use a higher capacity speed controller, and have multiple lipos on hand. Fly for a couple minutes, land and swap packs. I would also use 40C cells with that fan or the lipos will get really toasty.
Joe 1320 is offline Find More Posts by Joe 1320
Old Sep 28, 2012, 04:17 PM
chuck
santa barbara, CA
Joined May 2009
i agree w/ joe , another thought is to try to move the fan back so u can carry the bigger battery. w/ that kind of current draw the smaller packs just dont work well , even at 2 min flights u cant really use the power as battery heating is such an issue if u want any cycle life out of the pack.
i moved the wicked/wemo combo back in my screamer and now i can use a1600 and still get cg w/ no tail weight . at 30 amps wfo my flight times are still only 3 minutes w/ just a couple of full bursts but at least the battery is just warm.
chuck.
Old Sep 28, 2012, 04:36 PM
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
I'm ready to put together my new Katana. Any tips? I received motor and balanced fan from Don's. Nicely done. Looks like this plane is not very servicable. Once you mount the wing to the fuse, it's gonna be hard to get at the esc if necessary. On the servo tray for the elevators and rudder, is it safe to assume they are both mounted in the same orientation?
Battery placement. A deep cabin. Have the rx mounted on the vertical wall. An 850-1300mah 3S or 4S might be better mounted along it's side.
Anyone else have this bird? Have not seen very much discussion which is a bad omen.
-Hawk
dahawk47 is offline Find More Posts by dahawk47
Old Sep 28, 2012, 05:31 PM
Joe 1320's Avatar
Joined Feb 2006
-Hawk
I can't comment on the Katana yet, mine is on the way and should be here soon. I have lots of power system options sitting here just waiting, I just need to see what I'm dealing with before settling on the final setup.
Discussion Adelaide & SA flying & chat #2 Zootster Australia 11271 Today 07:44 PM
Help! Where can I buy Genkem Nova 27 in SA? MegaTesla South Africa 2 May 14, 2011 03:25 PM
Discussion SAL-SA Glider in Gobi dune romanticus Slope 11 Nov 30, 2010 10:40 PM
Question SA 2010-02 Castle ICE 100 "failed cut off" ?? LandCruiser Castle Creations 2 Oct 19, 2010 11:07 PM
T-33 Spring-air minis HW609 Derrek Curtis Electric Ducted Fan Jet Talk 3 Apr 25, 2001 03:42 PM
