Great job Lance , I think you will see its all fun mannn .
Sean , your over the top buddy , I dont know weither to compliment you or ask you for a price list for your parts lol !!! That tail assembly is fantastic , and so is the sliiding canopy !!! I am em-bare-assed to start my build in this forum !!!!!!
Latest blog entry: The Ultimate Hobby shop "Orange...
The tailwheel sets the spacing for the rear forks and I went from there.
The parts are made from 2-sided copper clad pc board: http://www.radioshack.com/product/in...ductId=2102495 I used almost two complete sheets. I cut it using my dremel cut-off wheel then sanded to shape with my belt/disk sander and the dremel sanding drum. Here's some more pics. The forks were covered with 5-min epoxy and a healthy mix of micro balloons. Later in the process I sanded this down for a more appealing shape. |
1)They are part of a real aircraft cowling kit
2)you will use them for actvation (open and closing ) the gear doors on the corsair tail wheel and main doors |
Well thanks to Sean I made the jump into Giant eletric . I am following the guru (my word not his lol ) .
I ordered the same Hacker , ESC(Castle) , and a motor mount from Hacker . , I also ordered a tail wheel and slinding canopy kit from SeanInc. but they are out of stock and telling me they wont ship hahah
Lance, I'm pleased you liked the tailwheel. Nice job on your Corsair to dress it up a bit. I assume you want to use spray cans instead of a spray gun? If you have a gun I've had good luck spraying klasskote and it's fuel proof. I use a detail gun at about 30psi to spray clear. It's a 2-part epoxy.
http://www.klasskote.com/ |
Lance great job on the lines , looks great !!
sean interesting idea on the fasteners , |
Still progressing on the corsair, got the tailwheel doors done (realized I didn't take any pics, will have to get some up later).
I don't like the idea of pull-pull for the elevator, and hence changed it for a direct pushrod. The rudder will remain pull-pull. In order to clear the tailwheel I offset the elevator control horn slightly. I also built a shelf for the elevator servo behind the cockpit (note it's not aeropoxied in yet in this picture). Not ideal for an access standpoint, but required for the geometry and having a full depth cockpit. The carbon rod across the fuse is slightly lower than the bottom of the cockpit floor and will allow the cables for the rudder and tailwheel steering to ride along in smoothly. I also centered the rudder servo in the stock servo tray. |
| Thread Tools | |
| Discussion Cute Little Corsair <<< "Cartoon Corsair">>> Slow flying model of the F4u Corsair D | DaDesign | Foamies (Scratchbuilt) | 35 | Mar 15, 2012 08:05 AM |
| Discussion F4U Corsair 60 w/Retracts ARF by Hangar 9 | V2rider | Electric Warbirds | 10 | Dec 25, 2010 05:49 AM |
| Discussion BH versus ESM Corsair ARF | ggiblin | Electric Plane Talk | 0 | Nov 16, 2010 08:49 PM |
| Discussion F4U Corsair | Papo_60 | Beginner Training Area (Aircraft-Electric) | 6 | Oct 31, 2010 05:03 AM |
