Old Feb 26, 2011, 06:09 AM
Ldm is offline
Ldm
Find More Posts by Ldm
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
I am going with two of these babys but I should be 2 to 4 pounds lighter , I hope it works as I have 4 of them . Same motor , same esc smaller prop
Capacity: 5000mAh
Voltage: 5S1P / 5 Cell / 18.5V
Discharge: 45C Constant / 90C Burst
Weight: 715g (including wire, plug & case)
Dimensions: 161x50x44mm
Balance Plug: JST-XH
Discharge Plug: 4mm bullet-connector
Ldm is offline Find More Posts by Ldm
Old Feb 26, 2011, 02:22 PM
strictlyscale is offline
Find More Posts by strictlyscale
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
What prop you going to run on 10S?
I'm sure you can come in arounf 18-20lbs if you keep it stock. Should balance no problem with the batteries alone.
strictlyscale is offline Find More Posts by strictlyscale
Old Feb 26, 2011, 04:03 PM
Ldm is offline
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
will be trying an APC electric 22x10 two blade and a 20x10 , my goal is to come in under 18Lbs .
i will have an interior , retracts , light weight wheels , will probably scratch the robart tail retract for either home made or a small light one retract .
Love the sound system , but dont want to add the weight as this is my first giant eletric and I dont have your experience Sean
Old Mar 05, 2011, 02:13 AM
Ldm is offline
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
Sean , any updates on you prop test ?
Old Mar 05, 2011, 06:39 AM
Philadelphia, PA
Lou,
I hadn't planned on doing any more tests on the prop. Should I be? At the moment I'm still with the APC-e 22x12.
Old Mar 05, 2011, 11:40 AM
Ldm is offline
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
Nope , I was not sure if you made the final decision , glad to hear you are all set .
Good luck with the maiden !!!!
Old Mar 05, 2011, 12:02 PM
TripleW is online now
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Good Luck!
I Hope the weather clears up for you. I'm guessing there is still snow on the runway. TW
TripleW is online now Find More Posts by TripleW
Old Mar 07, 2011, 08:05 AM
Philadelphia, PA
Just got back to town and looks like majority of the snow is gone, although we have had a lot of rain. I would expect we are still a month away from being able to get into and fly at our field...and two months or so from flying anything nice there. The club hires heavy equipment to roll the field in the spring. You'd be crazy to fly anything of any importance or weight before that.
Old Jun 09, 2011, 09:34 PM
waynemia is offline
Find More Posts by waynemia
A trail of smoke is GOOD!
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Originally Posted by strictlyscale View Post
Thanks for checking in Ron! ...now the pressure is on.
Also, thanks for the vote of confidence on the motor choice. I'm aiming to go with 10S, should still have plenty of power.
Got the stitching other wing panel finished today (only the top of the wing so far). You can see the pitot tube in place. It slides into a brass tube in the wing which has a pin soldered in the rear of it. That pin engages a slot on the end of the pitot tube so it stays vertical.
I am working on an H-9 Corsair 60, 1/8th scale. I am trying to get the meaurements to fabricate a pitot tube. I have not been able to find anything definitive. I would appreciate any help you could provide.
Thanks, Wayne
waynemia is offline Find More Posts by waynemia
Old Jun 10, 2011, 01:13 PM
Philadelphia, PA
Wayne,
I just took a best guess from a 3-view dwg I have. I worked out the size of the pitot vs the wing chord at that location, then used my wing cord at the pitot location and the same ratio to come up with mine.
Sean
Old Jun 10, 2011, 05:52 PM
waynemia is offline
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Wayne,
Sean
I need the measurements for mine if you have them.
Old Jun 11, 2011, 04:50 PM
Philadelphia, PA
Sure I'll measure Monday if I can remember where I put the tube.
Old Jun 13, 2011, 06:55 AM
Philadelphia, PA
Wayne,
My pitot tube is 5.5" long and sticks out 3.25" from the LE of the wing. It's located 2.5" in from the tip on the left wing panel. The wing chord at that location is 9". The wingspan is 74" overall.
I hope that helps serve as a guide for your to scale off of.
Sean
Old Jun 13, 2011, 08:14 PM
waynemia is offline
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Wayne,
Sean
This will be a great help Sean. Can I bug you for the diameter also?
Old Jun 14, 2011, 01:20 PM
Philadelphia, PA
Sure, I used a pce of carbon rod for the main pitot and a pce of wire for the front tip. The main tube is 0.159 OD and the tip is 0.096 OD. The tip is 5/8" long.
Again, these are just my best guess for a pitot and what looked like it was correct.
Discussion Cute Little Corsair <<< "Cartoon Corsair">>> Slow flying model of the F4u Corsair D DaDesign Foamies (Scratchbuilt) 37 Jan 03, 2015 01:27 PM
Discussion F4U Corsair 60 w/Retracts ARF by Hangar 9 V2rider Electric Warbirds 10 Dec 25, 2010 05:49 AM
Discussion BH versus ESM Corsair ARF ggiblin Electric Plane Talk 0 Nov 16, 2010 08:49 PM
Discussion F4U Corsair Papo_60 Beginner Training Area (Aircraft-Electric) 6 Oct 31, 2010 05:03 AM
