Old Feb 09, 2011, 11:20 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
dude...your so fast!
looking sweet! you kill me as always
can't wait till spring to see some flight reports coming from you, we still have to see that F-86 rip too... did you fly the F-18?
man your going to have one hell of a spring
lucky dog,,, but you worked your butt off for all of them
looking forward to it all
Ron101 is offline Find More Posts by Ron101
Old Feb 10, 2011, 05:39 AM
strictlyscale is offline
Find More Posts by strictlyscale
Dream Build Fly Scale
strictlyscale's Avatar
Philadelphia, PA
Thanks Ron, I can't wait that's for sure. Still need to take care of a few small things on the Corsair, including the balance.
The F-18 hasn't flown yet as I smoked the CC ESC on a test run and need to install the replacement. I also needed weight in the tail to balance, so I'm working on trying to move some gear rearward to avoid that extra weight.
The F-86 is all painted and basically ready. I'll post some pics in the next day or so in that thread. I want to change a couple things on it internally. One is to pull out the current radio setup and install the new futaba s.bus arrangement. It will avoid the reversers and save a little more weight in the process.
strictlyscale is offline Find More Posts by strictlyscale
Old Feb 10, 2011, 08:52 AM
Philadelphia, PA
Added the antenna today to the fuselage using some 15lb black fishing line and crimp fittings. Knowing how easy it is to knock these things off while moving the model I needed to make it somewhat removable but still stay relatively tight. Came up with the solution shown which appears to work very well. Behind the line that goes into the fuselage I've added a spring to keep a little tension on the line. On the stab I have a small hook which makes it removable for transport and the hook comes undone with a little pull on the line thanks to the spring in the fuselage. Hope that explanation is clear!?!
Old Feb 10, 2011, 09:08 AM
Philadelphia, PA
Got it outside for some pics this morning. Sunny but only 21 degrees so it was a little chilly.
All that's left is to connect the ailerons to the servos in the wing and to balance. I've ordered a new (heavier) rx pack to put up in the nose.
Old Feb 10, 2011, 09:35 AM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
That is just awesome! How many hours a day do you put in on a project like this? TW
TripleW is offline Find More Posts by TripleW
Old Feb 10, 2011, 09:44 AM
Philadelphia, PA
Here's the initial sound test out in the driveway.
Corsair initial sound test with guns and turning pilot head (1 min 5 sec)
Old Feb 10, 2011, 09:45 AM
Philadelphia, PA
Thanks! Typically I get about 2-3 hrs a day in the afternoons to work on the model. I was also able to get in a couple full days due to poor weather keeping me at home.
Old Feb 10, 2011, 09:48 AM
Philadelphia, PA
Here's a shot showing the equipment layout inside the fuselage. With a number of lines going to the wing I wanted to ensure they don't interfere with the servos in the fuse. I used a pce of honeycomb plate as it's rigid and light to protect the servos from the wing wires (ailerons, flaps, retracts, speakers).
Old Feb 10, 2011, 10:03 AM
Orvis is offline
Find More Posts by Orvis
Leduc, AB, Canada
Joined Oct 2008
Sean,
Your work is outstanding! No one here could ever say you are not dedicated to the hobby.
Seriously, when can I send you my Typhoon for detailing?
Cheers,
Peter
Orvis is offline Find More Posts by Orvis
Old Feb 10, 2011, 03:06 PM
konachris is offline
Find More Posts by konachris
konachris's Avatar
Joined Oct 2005
Sean,
You can't get any better than that! It's time for another magazine article from you. I will be waiting for some flight video and a flight review from you soon.
Build on,
Chris
konachris is offline Find More Posts by konachris
Old Feb 10, 2011, 03:41 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
corsair nut is offline Find More Posts by corsair nut
Old Feb 10, 2011, 08:07 PM
Ron101 is offline
Ron101's Avatar
Joined Jul 2007
awesome man!
wow you do need to move 21 degrees... I'm such a wuss I couldn't take it
I really hate could and really hot
The guys give me hell I have a 60 to 90 rule for flying.. any higher or lower its not as fun
Old Feb 10, 2011, 10:29 PM
mpope1 is offline
Find More Posts by mpope1
mpope1's Avatar
gilbert,az
Joined Dec 2005
Really impressive, can't wait to see it in the air when it warms up!
mpope1 is offline Find More Posts by mpope1
Old Feb 11, 2011, 05:35 PM
Zephyr7 is offline
Find More Posts by Zephyr7
Joined Sep 2009
I sure do like you build.Can't wait to see it fly. If your going to fly at Quakertown i would like to watch
Zeph
Zephyr7 is offline Find More Posts by Zephyr7
Old Feb 11, 2011, 09:16 PM
Chad Veich is offline
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
Superb work as usual Sean! My brother and I have an ESM Bearcat waiting on the shelf that will be getting "bashed" in similar fashion. If it is half as nice as your Corsair I will be very happy with it. Good luck with the maiden when the time comes.
Chad Veich is offline Find More Posts by Chad Veich
Discussion Cute Little Corsair <<< "Cartoon Corsair">>> Slow flying model of the F4u Corsair D DaDesign Foamies (Scratchbuilt) 37 Jan 03, 2015 01:27 PM
Discussion F4U Corsair 60 w/Retracts ARF by Hangar 9 V2rider Electric Warbirds 10 Dec 25, 2010 05:49 AM
Discussion BH versus ESM Corsair ARF ggiblin Electric Plane Talk 0 Nov 16, 2010 08:49 PM
Discussion F4U Corsair Papo_60 Beginner Training Area (Aircraft-Electric) 6 Oct 31, 2010 05:03 AM
