Old Dec 02, 2010, 09:42 PM
CoolBudz is offline
Find More Posts by CoolBudz
RCPlaye
United States, CT, East Hartford
Joined Aug 2009
Yak 54 Indoor 3D EP ARF 32" Power System
Hey guys, I need some help, I wanted to find a suitable power system
for the
Great Planes Yak 54 Indoor 3D EP ARF 32"
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXVNC8
Im looking for a motor that can give this good power, i was wondering do you think this motor is good? or should it be stronger?
http://www.hobbyking.com/hobbyking/s...idProduct=2046
I was also wondering what would be a low cost esc that's pretty good with this motor or the one you suggest that can go with this plane.
Thanks guys/geniuses I need power, also any rule of thumbs will be
appreciated.
Also does anyone know the voltage and mA of the battery I should use with this plane
CoolBudz is offline Find More Posts by CoolBudz
Old Dec 02, 2010, 10:16 PM
Meez is offline
Find More Posts by Meez
3D Crazy
Meez's Avatar
Putrajaya, Malaysia
Joined May 2010
64g is too heavy. You should find motor weighing around 20g like Hacker A10-9L or Rimfire 250.......
If you looking for cheap setup than i recommend Himodel C2204-1500kv 26g with Himodel ESC 10Amp. 360 to 460mah 2 cell 20C batttery with 9050 GWS HD prop........
Good luck
Meez is offline Find More Posts by Meez
Old Dec 02, 2010, 10:30 PM
CoolBudz is offline
RCPlaye
Joined Aug 2009
is there a motor wattage you would recommend for this plane
Old Dec 02, 2010, 11:21 PM
CoolBudz is offline
RCPlaye
Joined Aug 2009
I was doing quite a bit of research and decided between these 5 planes.
I like all of them the same but can only get 1. So what do you guys think, which one is the best or better deal.
http://www.hobbyking.com/hobbyking/s...idProduct=9195
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8472
http://www.hobbyking.com/hobbyking/s...dProduct=11342
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9203
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXVNC8&P=FR
Old Dec 03, 2010, 01:25 AM
Meez is offline
3D Crazy
Meez's Avatar
Putrajaya, Malaysia
Joined May 2010
Watt around 75w.
As for the plane, i recommend you the Piaget EPP. Very durable plane............
Old Dec 03, 2010, 05:29 PM
CoolBudz is offline
RCPlaye
Joined Aug 2009
Thanks man Im gunning for that plane, um what do you think
would be good power for the motor 75 watt? 200 watts? Also how much
motor weight do you think this plane can take? and do you know the average flight times of these 3d planes?
Article Great Planes Pluma 3D Indoor/Outdoor EP ARF 32.5" Bajora 3D Flying 28 Jan 10, 2012 08:22 PM
Discussion YAK-54 3D EP setup? tomson5 3D Flying 2 Sep 06, 2010 10:33 PM
Discussion Need advice - GreatPlanes Yak 54 3D Indoor ARF - First 3D coop402 3D Foamies 5 Jun 27, 2010 09:34 PM
Discussion EP YAK 54 3D ARF or X-Ray EP ARF Pla123 3D Flying 13 May 10, 2007 06:49 PM
Sold Great Planes E Performance Series EP YAK 54 3D ARF 41" - Reduced Spid Aircraft - Electric - Airplanes (FS/W) 6 May 03, 2007 08:09 PM
