| Thread Tools |
| This thread is privately moderated by bobskinner, who may elect to delete unwanted replies. |
micro Slow Stick Build Guide
First some video:
Start by carefully cutting all the tabs that hold the parts into the balsa sheet and then remove the parts from the sheet. Next carefully sand the edges of the parts to remove any remnants of the tabs. Be particularly careful with the edges that form the joins for the 2 parts of each wing half. Do not sand away more that absolutely necessary to remove the tabs. Bevel the rudder and elevator by sanding a 45 degree angle on the side where each will hinge to its respective stabilizer. The rudder in the picture was beveled on the wrong side. It does not make much of a difference but I think it is better to have the bevel on the one side and the control horn on the opposite side. The ember has the rudder control horn on the right side so the bevel should be on the left (when looking at the plane from behind). The elevator is correctly beveled in the pictures (the front bottom of the elevator). |
Covering...
To cover the wing and tail I like to use Coverite microlite, it's relatively easy to work with and pretty light. Any lightweight covering should suffice though.
Cut a piece of covering for one wing half that extends past the wing edges by about 1/4" all around. Do the same for the other wing half. Place the horizontal stab and elevator upside down on the work surface (beveled side facing up) and use a piece or 2 of tape to hold them together as you would like them to be once covered (tape on the bottom only). Cut a single piece of covering for the horizontal stab and elevator also extending about 1/4" past the outside edges. Do the same for the vertical stab and rudder as was done with the elevator (bevel side up and tape together). Cut 2 pieces of covering for the vertical stab/rudder combo each piece big enough to extend a little past the edges of the part. To cover the wing I place the covering so that it overlaps the join in the middle of the wing by about 1/16". Cover only the top of the wing and horizontal stab/elevator. The covering serves as the hinge for the elevator. Be careful to mot shrink the covering on the parts too much to avoid warping or breaking them. I like to cover the top and edge of the parts leaving only the bottom surface uncovered. Trim excess covering with a sharp blade and remove tape from bottom of elevator. For the vertical stab/rudder, cover the side opposite the bevel first, NOT the side with the bevel. Trim excess covering and remove the tape from the uncovered side of the part. Now fold the rudder back against the vertical stab (towards the covered side). Carefully apply the covering to the uncovered side of the vertical stab then iron the covering down across the entire hinge/bevel area (so that when you open the rudder back out to it's neutral position the covering is inside the beveled area also). Then cover the remaining portion of the rudder. Trim excess covering. Cut through covering over the slots for the control horns in the rudder and elevator and install control horns. I usually cut my own horns by hand unless I have some lying around from a small enough plane that has been "retired."
Finally! It is mostly done!
Please PM me if anything is unclear or could/should be reworded. I will be taking some more pictures when I build another set to try and clarify the covering process a little more. I have these kits available for sale in the classifieds section if anyone is interested. Thanks, Bob |
| Thread Tools | |
| Build Log Radical RC Stick 400 Prototype Build Log | Chophop | Electric Plane Talk | 100 | Sep 03, 2011 07:44 PM |
| Build Log micro submarine build log.... | nemoskull | Submarines | 0 | Sep 17, 2010 04:14 PM |
| Discussion Biplane pusher Slow Stick build and flight log | Swanlander | Aerial Photography | 45 | Jul 22, 2007 04:28 AM |
