Old Jan 12, 2011, 08:48 AM
kman24 is offline
Find More Posts by kman24
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
Originally Posted by luvmykids2 View Post
Are there parts out there anywhere for this plane?
I would imagine that Nitroplanes could get you a part. You may have to call them directly.
kman24 is offline Find More Posts by kman24
Old Jan 13, 2011, 09:29 PM
kman24 is offline
kman24's Avatar
Joined Jan 2010
Reverse Flap Servo
I am getting ready to install the flaps on mine and was contemplating whether to try and get a reversed servo or a y-cable with a servo reversing module. After doing a little searching, I found some good instructional guides on how to reverse a typical servo by swapping a couple pairs of wires inside. So, I tried it and it worked
Now I just need to install the servos and the other hardware, but I am still missing one of the flap hinges. I actually contacted Nitroplanes a few weeks ago about getting another hinge and they said they would mail me one. But, I haven't seen it come yet I suppose I could just install the 2 outer hinges and install an ordinary control horn in the middle of each flap and attach it to the servos. It would look as clean but it would work.
KMan
Old Jan 21, 2011, 01:46 PM
Rimmyman is offline
Find More Posts by Rimmyman
San Jose, CA
Joined Mar 2006
KMan
why go through all that trouble? I just installed mine facing the same direction. the flaps move in much the same way, but no additional or costly work.
I used the outer 3 to secure the flap hinges and the middle is just the control throw.
granted, i'm a novice pilot, but it works great work me
Rimmyman is offline Find More Posts by Rimmyman
Old Jan 21, 2011, 02:46 PM
kman24 is offline
kman24's Avatar
Joined Jan 2010
I reversed the one servo just to see if I could do it. I saw that it could be done by just swapping a couple pairs of wires inside. It didn't take long, only about 15 minutes and it it just required a screwdriver and a soldering iron. Here is a video on how to do it if you are ever interested.
How to REVERSE a Servo. (4 min 32 sec)
I will probably just do what you did and only attach the outer 2 hinges with a control horn in the middle. Should do the trick.
KMan
Old Jan 21, 2011, 06:42 PM
Rimmyman is offline
San Jose, CA
Joined Mar 2006
KMan
oh i've done that to a servo, its a good tip. just have steady hands.
my flaps are sturdy and work well, you will enjoy landing with them though. its truly inspiring to see
Old Jan 30, 2011, 01:55 PM
kman24 is offline
kman24's Avatar
Joined Jan 2010
I finally got my flaps installed and working. This is my first plane with flaps so I am anxious to try them out soon. I had Nitroplanes send me a replacement flap hinge since I was missing one from the original kit. Took them a little while, but they came through for me (thanks Nitroplanes!!!). Right now, I have the flaps set for 50% travel. This gives me about a 45 degree angle from level. Does this sound reasonable for those who are using flaps on this plane? Or do I need more/less?
KMan
Old Jan 30, 2011, 06:32 PM
Rimmyman is offline
San Jose, CA
Joined Mar 2006
I have mine set to the knob so i can trim it as needed.
Old Feb 05, 2011, 11:25 PM
TheRCEdge is offline
Find More Posts by TheRCEdge
USA, TN, West Bradley
Joined Jan 2011
What kind of flight time are you getting out of a 2200mAh 25C
TheRCEdge is offline Find More Posts by TheRCEdge
Old Feb 06, 2011, 11:35 AM
simplefly is offline
Find More Posts by simplefly
simplefly
United States, IL, Glen Ellyn
Joined Sep 2010
Dynam Sr Trainer
Here is mine.
simplefly is offline Find More Posts by simplefly
Old Feb 07, 2011, 10:16 AM
kman24 is offline
kman24's Avatar
Joined Jan 2010
Simplefly - from your pictures it looks like the top of your rudder is a little crooked from shipping. Mine was the same way. I heated it up a bit and straightened it out the best I could. Otherwise, it looks good! Post some video when you get it up in the air
KMan
Old Feb 07, 2011, 06:53 PM
simplefly
Joined Sep 2010
Kman, thanks for the tip. I'll try to streighten it. I'll post videos when I get a chance.
Old Feb 08, 2011, 04:00 PM
Joined Jan 2011
Just got mine in today. Can't wait to get it up in the air.
Scott T.
TheRCEdge.com
(Team XAircraft USA)
Old Feb 08, 2011, 07:03 PM
luvmykids2 is offline
Find More Posts by luvmykids2
United States, CA, Santa Maria
Joined Dec 2006
Man, my wings flex on hard turns or loops. I am going easy on this now after seeing that. Anyone snap the wings yet? They are so narrow...
luvmykids2 is offline Find More Posts by luvmykids2
Old Feb 09, 2011, 01:48 AM
Joined Jan 2011
Im going to change out the prop and spinner what would be the best for this model...
Scott T.
TheRCEdge.com
Old Feb 09, 2011, 08:18 AM
simplefly
Joined Sep 2010
I'd like to do same. I wanna change the motor as well. It sounds kind of weird.
Discussion telemaster sr ARF jrplane Electric Plane Talk 1 Nov 27, 2010 09:43 PM
Discussion Dynam Sky Trainer 4CH RTF NJRC Beginner Training Area (Aircraft-Electric) 10 Nov 18, 2010 08:45 PM
For Sale Aero Sprint Elec. ARF Trainer 50" W/S puplover Aircraft - Electric - Airplanes (FS/W) 0 Nov 15, 2010 04:15 PM
Sold Aero Sprint ARF trainer by Parma puplover Aircraft - Fuel - Airplanes (FS/W) 0 Nov 13, 2010 02:47 PM
Sold MM Special High-Wing Trainer ARF Kit AJ750 Aircraft - Electric - Airplanes (FS/W) 4 Oct 29, 2010 10:36 PM
