Old Oct 28, 2012, 09:50 AM
fuzzyhead is offline
Find More Posts by fuzzyhead
Old F-4 Crewchief
fuzzyhead's Avatar
Schertz, Texas, United States
Joined May 2004
I took my SR-22 out this morning. Its been several weeks since I flew her last. To my dismay when I flipped her over to install the battery, the battery hatch was gone.Have no idea when or where it departed. My guess is that it dropped off while in the bed of my truck then blew out during my travels.
Any idea where I can get a replacement? Looked at all the online vendors but no hatches. Any suggestions for? Don't really want to buy a complete fuselage just for a small plastic door.
fuzzyhead is offline Find More Posts by fuzzyhead
Old Oct 28, 2012, 11:07 AM
Spookeay is offline
Find More Posts by Spookeay
Always puts it on the numbers.
Spookeay's Avatar
United States, AL, Sylacauga
Joined Jul 2012
You won't get the door with the fuselage. You need to buy the plastic kit I think it's like $6.
Spookeay is offline Find More Posts by Spookeay
Old Oct 28, 2012, 12:32 PM
Old F-4 Crewchief
fuzzyhead's Avatar
Joined May 2004
Did not know that.
Old Oct 28, 2012, 12:49 PM
Old F-4 Crewchief
fuzzyhead's Avatar
Joined May 2004
I did an online search and found several parts kits but none include the door. Doesn't look too hard to improvise and make one.
Old Oct 31, 2012, 05:51 PM
Old F-4 Crewchief
fuzzyhead's Avatar
Joined May 2004
No luck finding a new door. Making one freehand. Not pretty but functional. If anybody has a destroyed SR22 with an unneeded battery hatch let me know.
Thanks. Rick
Old Nov 17, 2012, 09:23 PM
Spookeay is offline
Spookeay's Avatar
Joined Jul 2012
To quite over here. Let spice things up... Lets get some SR talk going.
I got a Gopro....stuck it in the window.... Had a lot of fun you know, with that go pro in the window. made my plane really go, almost get out of control. But I never go postal
GoPro Hero test (6 min 14 sec)
Old Nov 22, 2012, 05:36 AM
rcflyinff is offline
Find More Posts by rcflyinff
rcflyinff's Avatar
United States, FL, Titusville
Joined Mar 2012
Happy Thanksgiving! To windy to fly, so lets eat and check out the Black Friday plane deals
rcflyinff is offline Find More Posts by rcflyinff
Old Nov 27, 2012, 03:39 PM
Arceneaux811 is offline
Find More Posts by Arceneaux811
Joined Nov 2012
Turnigy Batteries
Hi guys noobie here, but was wondering will the Turnigy 2200mah 3s 20,25 or 30C Batteries work n the Dynam SR Trainer and if so will the RTF stock charger charge them?
Arceneaux811 is offline Find More Posts by Arceneaux811
Old Nov 27, 2012, 04:24 PM
kman24 is offline
Find More Posts by kman24
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
I have been using the Turnigy 2200mah 20C batteries in mine. They barely get warm. Don't know anything about the charger in the RTF model but it should have the standard charging port for 3s lipos.
Kman
kman24 is offline Find More Posts by kman24
Old Nov 29, 2012, 09:35 PM
rcflyinff's Avatar
Joined Mar 2012
I'm looking to put a pilot & co-pilot in the SR22. Any idea what size would look good and where should I purchase them from? Thank you
Old Nov 29, 2012, 10:19 PM
kman24 is offline
kman24's Avatar
Joined Jan 2010
I had used my pilots from my Dynam T-28 in this plane and they look good in there. It is posted a ways back. The pilots can be obtained from Hobby King.
Kman
Old Dec 07, 2012, 02:26 AM
Eric Henderson is offline
Find More Posts by Eric Henderson
Eric Henderson's Avatar
United States, NV, Las Vegas
Joined Dec 2005
Cg change
December 6, 2012 TRAINER SR (1 min 0 sec)
Cut the battery area open and fitted a horizontal pocket out of scrap foam. This moved the battery and the CG back to 35mm. The elevator got "lighter" and the glide improved. Landing was much better. No bouncing and full flap really slowed everything down.
Eric.
Eric Henderson is offline Find More Posts by Eric Henderson
Old Dec 08, 2012, 11:53 AM
Fei Hu is offline
Find More Posts by Fei Hu
Staying 3 mistakes high!
Fei Hu's Avatar
United States, GA, Lilburn
Joined May 2011
Originally Posted by Eric Henderson View Post
http://youtu.be/gdP1_OXybXc
Eric.
Can you show some pics? I'd love to change the battery bay in mine too.
Fei Hu is offline Find More Posts by Fei Hu
Old Dec 08, 2012, 01:38 PM
Joined Dec 2005
I will do so.
Upon reflection I should have done that. What botherd me apart from it being nose-heavy, was the blue LIPO impersonating a "pilot".
Also, I had no documenation for doing the flaps and the servo position/orientation did not have the two additional servos going in the same direction. I used an 8 channel RX and one channel per flap to get correct direction, a mix to get equal throws and neutrals for each flap. There is no adjustment on my flap push rods because they are pre-bent and buried in the wing and hiiden by the flap hinge.
The flight video was a bust due to visibilty for the camera guy, and focus issues, but I would report that you can set an egg-timer to do the rolls. Not the highest roll rate in the world with those tiny ailerons.
I fly with 2:1 aileron differential and about 1/2" CAR and it feels just fine. Getting the CG back was achieved by simply laying the battery flat after it goes in through the bottom hatch. The trick was to guide it and get it to stay in one place. You don'thave to move much weight very far to get a lovely airplane to fly -- Pictures to foillow tomorrow - The Stores are open and it's Honey-do's right now!....
Eric.
Old Dec 08, 2012, 05:45 PM
Joined Dec 2005
painting on foam models
Masking tape will not work on the original paint. A trick is to use a rubber band.
It works well on surfaces where you can put the band all of the way around. Wing tips, noses fuselage striping/banding etc. I also use Aluminum foil as a broader mask. It folds and stays in place until you can apply some masking tape to join the rubber band edge with the foil.
When I am taking the masking off, I often pop the band with a sharp knife. Pretty clean and does not pull off the existing paint from the foam.
Eric.
Discussion telemaster sr ARF jrplane Electric Plane Talk 1 Nov 27, 2010 09:43 PM
Discussion Dynam Sky Trainer 4CH RTF NJRC Beginner Training Area (Aircraft-Electric) 10 Nov 18, 2010 08:45 PM
For Sale Aero Sprint Elec. ARF Trainer 50" W/S puplover Aircraft - Electric - Airplanes (FS/W) 0 Nov 15, 2010 04:15 PM
Sold Aero Sprint ARF trainer by Parma puplover Aircraft - Fuel - Airplanes (FS/W) 0 Nov 13, 2010 02:47 PM
Sold MM Special High-Wing Trainer ARF Kit AJ750 Aircraft - Electric - Airplanes (FS/W) 4 Oct 29, 2010 10:36 PM
