Old Aug 28, 2012, 11:24 PM
DriverRX8 is offline
Find More Posts by DriverRX8
Brain/Thumb Interlock Off
DriverRX8's Avatar
Joined Mar 2011
Originally Posted by kman24 View Post
The wings do flex but don't break unless you fly it straight into the ground. In that case you can just glue them back on Kman
I can verify all of the above statements!
DriverRX8 is offline Find More Posts by DriverRX8
Old Aug 31, 2012, 10:27 AM
stevea3342 is online now
Find More Posts by stevea3342
stevea3342's Avatar
United States, CT, Bridgeport
Joined May 2012
I just received my SR trainer with a blue motor. The website said it is supposed to be 1100kv, but the motor is labled 950kv. Is this normal? Worth complaining about?
You can see the picture of the motor I got, but it seems like this is the one that should have come on it:
http://www.hobbypartz.com/60p-dym-00...15-kv1100.html
Maybe this is why people haven been complaining about performance a few posts back.
stevea3342 is online now Find More Posts by stevea3342
Old Aug 31, 2012, 01:01 PM
kman24 is online now
Find More Posts by kman24
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
Possibly, looks like they pulled a fast one on us. That is maybe why they are so cheap now
Kman
kman24 is online now Find More Posts by kman24
Old Aug 31, 2012, 08:17 PM
warbirdzzz is offline
Find More Posts by warbirdzzz
Joined Jul 2012
Hey guys!
Been reading all of the 30-ish pages of this thread as I have a SR Trainer that is waiting to be built.
Mine came in in one piece, all as advertised except for the motor and ESC. Mine came with a BLUE 950kv motor and 30A ESC.
Put in a wattmeter to test the combo out and got 108 watts pulling 11A on a fresh charged 3S 25C.
That is a little scary low isn't it? I've read the bird might be thought of underpowered even with the 1100kv motor.
Anyone got any ideas as for a replacement for the motor?
I have a Turnigy D3542/5 1250KV Brushless Outrunner Motor but it seems too big to fit and the X-mount for the motor won't fit the firewall on the plane.
Any ideas?
Alex
warbirdzzz is offline Find More Posts by warbirdzzz
Old Aug 31, 2012, 08:32 PM
kman24's Avatar
Joined Jan 2010
Sounds like the output from this NEW blue motor is quite disappointing
I have this motor in one of my small warbirds and it would be a good fit for this plane. Someone else in this thread used it with good results and if you read the reviews for the motor, another owner of this plane reported good results...
http://www.hobbypartz.com/86ma67-2215-1500kv.html
Kman
Old Aug 31, 2012, 08:58 PM
Joined Jul 2012
Thanks for the reply KMan!
That motor sure looks like a good step up from what i have right now. 300W should defo make it fly better.
Do you think that motor can handle the stock prop?
Thanks again!
Alex
Old Aug 31, 2012, 09:32 PM
kman24's Avatar
Joined Jan 2010
Thanks again!
Alex
I am not sure. I could run a quick test with the one I have and see what it draws. Let me get back to you on that
Kman
Old Aug 31, 2012, 09:35 PM
rcflyinff is online now
Find More Posts by rcflyinff
rcflyinff's Avatar
United States, FL, Titusville
Joined Mar 2012
Oh crap, I don't like the sounds of this. We are waiting for our plane to come in Tuesday. Curious to see if it also has this blue motor installed. Probably does. Little man wants to paint the top of his plane red. Anyone had any experience on doing this (prepping, painting, clear coat)? I've read that some are using the Polycrylic from Miniwax as a clear coat, but there are some concerns about the product yellowing over time. Has anyone experienced this? If so, what is a good alternative? Thank you for your replies......
rcflyinff is online now Find More Posts by rcflyinff
Old Aug 31, 2012, 10:23 PM
stevea3342's Avatar
Joined May 2012
On the ammeter, the 950kv 'blue' motor pulled about 14.1 amps peak on a 3 cell. If the 3 cell is about 12.4 volts, we are at 173 watts. I don't have a way to measure thrust, but the plane felt pretty strong. on the stock prop (in the basementm lol). I'll fly it for the first time tomorrow and see how it goes.
I have faster planes (gliders) already but I got this one specifically to practice take offs and landings and get used to flaps (and I wanted the tricycle gear). I think it will still serve the purpose and still be a nice "Sunday Flyer"
I'm curious to see how you guys will make out with the 300 watt motor. If this is dangerously underpowered with the stock motor, I may be joining you.
Old Aug 31, 2012, 10:25 PM
kman24's Avatar
Joined Jan 2010
Thanks again!
Alex
I ran a quick test with an APC 9x6 two blade prop and measured 32A and 340 watts, yikes! So, it looks to me that 1500kv is too much for this setup. So, for this size prop the lower kv motors would be a better option. Here is the 1300kv rocket motor that would be a good candidate IMO. I don't have one I can test with, but if my stock 1100kv motor draws 22A and the 1500kv motor I tested draws 32A, then the 1300kv motor should be somewhere roughly halfway in between : )
http://www.hobbypartz.com/86ma71-2215-1300kv.html
Kman
Old Aug 31, 2012, 10:32 PM
kman24's Avatar
Joined Jan 2010
Sounds like you should be fine then. You could always put a higher pitch prop on it if you wanted a little more oomph, as well.
Kman
Old Sep 01, 2012, 12:53 PM
rcflyinff's Avatar
Joined Mar 2012
Three more days and counting until it arrives! So I've been reseaching on how to paint this plane. Sounds like an awful lot of work. I saw a thread where someone used the self-adhesive monokote trim strips. I'm thinking about trying this. Has anyone else ever tried these? As far as the clear coat goes, would you apply before or after the strip is applied? Thanks for your help, and have a great Labor Day weedend.
Old Sep 01, 2012, 08:21 PM
stevea3342's Avatar
Joined May 2012
I had a few nice flights today using a 3cell 2200 with the stock 950kv motor. It taxied and took off nice. It doesn't leap from the runway into the air, but it does a nice scale take off.
It handled an 8-10pmh wind fine and floats in for a landing. I was worried about nosing over and breaking the prop and front gear, but it didn't have that tendency. I added the flaps but haven't used them yet. I would recommend this plane to anyone looking for a slow smooth plane. This may make a great aileron trainer as well.
I think I will leave it stock. Sure, it would be a lot more fun with 250watts, but then to enjoy the fun, the wing will probably have to be reinforced and the ESC upgraded. At that point, it may be better to just switch to a plane that is more capable out of the box. Still, if I had the parts laying around, I might go for it anyway
Old Sep 01, 2012, 08:30 PM
mfpage is offline
Find More Posts by mfpage
NORDPAC S3
mfpage's Avatar
United States, OR, Estacada
Joined Jan 2009
I upgraded motor and prop. Now pulling 22 amps and 228 watts. Really nice, flies with authority.
Mfpage
mfpage is offline Find More Posts by mfpage
Old Sep 01, 2012, 08:31 PM
stevea3342's Avatar
Joined May 2012
Mfpage
Which motor and esc (and prop) did you use?
Discussion telemaster sr ARF jrplane Electric Plane Talk 1 Nov 27, 2010 09:43 PM
Discussion Dynam Sky Trainer 4CH RTF NJRC Beginner Training Area (Aircraft-Electric) 10 Nov 18, 2010 08:45 PM
For Sale Aero Sprint Elec. ARF Trainer 50" W/S puplover Aircraft - Electric - Airplanes (FS/W) 0 Nov 15, 2010 04:15 PM
Sold Aero Sprint ARF trainer by Parma puplover Aircraft - Fuel - Airplanes (FS/W) 0 Nov 13, 2010 02:47 PM
Sold MM Special High-Wing Trainer ARF Kit AJ750 Aircraft - Electric - Airplanes (FS/W) 4 Oct 29, 2010 10:36 PM
