Old Feb 24, 2011, 06:28 PM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Originally Posted by Darth_Elevator View Post
Pardon my ignorance, but what's the best way to produce a paper template from the dxf files posted above if I don't have a plotter? Take the dxf files down to a copyshop with a plotter and have them print them out? Use software that will convert the dxf files to a tileable pdf? Use some dxf viewer program that will produce a tiled printout? Any suggestions? Thanks
Also, do you guys recommend any good online sources for depron, especially somewhere with reasonable shipping so a small order won't break the bank? I bought some thin depron online about 3 years ago but I can't for the life of me remember where.
Ditto to rcfoam.com. My local hardware store/hobby shop is a dealer for them so I don't have to pay shipping...just taxes!
Regarding the dxf file. You can use a free program called inkscape to both edit it and convert the dxf to a PDF. As far as a tiled printout goes there are programs that'll do that but I'm not familiar with any of them.
Btw...it definitely can be done but you're probably not going to have much fun cutting one of these out by hand. Let me know if you want me to laser cut one for you. I won't do it for free but it's really not that expensive either.
Brian
cpdude is offline Find More Posts by cpdude
Old Feb 24, 2011, 06:57 PM
0011000011001 is offline
Find More Posts by 0011000011001
byte me!
0011000011001's Avatar
Joined Aug 2008
If MIT KID has no objections, i have the plans converted to .pdf.
Also, Ive just finished weighing the complete airframe with all electronics..33grams
0011000011001 is offline Find More Posts by 0011000011001
Old Feb 24, 2011, 07:04 PM
Suicufnoc is offline
Find More Posts by Suicufnoc
Suicufnoc's Avatar
Joined Aug 2010
Hey can you tell me the wingspan so I know what scale to print to? thanks
Suicufnoc is offline Find More Posts by Suicufnoc
Old Feb 24, 2011, 07:36 PM
byte me!
Joined Aug 2008
im not actually sure about the recd ws...i just made it the same as my suk
Old Feb 24, 2011, 07:41 PM
cpdude is offline
Joined Jan 2004
I'm showing a wingspan of 426.63mm measured just in front of the aileron counterbalances.
Brian
Old Feb 24, 2011, 08:07 PM
Suicufnoc's Avatar
Joined Aug 2010
Sweet thanks. I decided to go up to 18". About an inch bigger, should be ok
Brian
Old Feb 24, 2011, 08:53 PM
cpdude is offline
Joined Jan 2004
@Suicufnoc - I wouldn't think that's a problem. I've added close to that on one version I did...it still flew!
Brian
Old Feb 25, 2011, 12:49 PM
Darth_Elevator is offline
Find More Posts by Darth_Elevator
How do I change this text?
Darth_Elevator's Avatar
The Beautiful Mountains of Utah
Joined Oct 2006
Sweet! I'll gladly pay you to cut one for me. Drop me a pm with your paypal address. Thanks!
Darth_Elevator is offline Find More Posts by Darth_Elevator
Old Feb 25, 2011, 12:51 PM
Suicufnoc's Avatar
Joined Aug 2010
Sweet hopefully it works out. I should have a little extra power with the setup I'm doing, so if it's a little heavy it should be ok. Though if it doesn't have good enough vertical I guess I'll have to make a little bit smaller one. Or just make it ligher!
Just ordered Depron Aero and carbon from RcFoam. I recommend them to anyone. And I've got elecs on backorder from HobbyKing. I'll probably have 3 airframes ready by the time they ship... oh well
Old Feb 25, 2011, 02:43 PM
Joined Oct 2006
Which electronics did you go with? I've just ordered one of cpdude's laser cut kits, so now I have to decide whether to rip the electronics out of my 4-site and build the Yak 55 now, or wait until I finish destroying the 4-site to rip out the electronics, or just order completely new stuff for the Yak 55.
Old Feb 25, 2011, 04:22 PM
Suicufnoc's Avatar
Joined Aug 2010
GPS-C03 motor/gearbox - Should get about 55g thrust, according to other's results. I'm gonna use a 5x4.3 gws prop. Could probably go 5x3 or 6x3.
1 cell 3 amp esc
Turningy Nanotech 1s 160mah - I think there's a 120mah version too if you want lighter
1.7g linear servos - Rudder/Elevator
2.0g servo - Going to try one of these on ailerons. I think it will be enough, if not I'll probably go to two linear servos. Or maybe just two of these.
And I'm using an FrSky 3g micro reciever but I'm assuming you're using Spektrum, so you could use This
Old Feb 25, 2011, 04:34 PM
cpdude is offline
Joined Jan 2004
@Darth - I'm really not offering a kit. I'm just trying offering laser cutting services to my fellow modelers and maybe coveri some of my costs.
@Suicufnoc - I'm definitely interested in hearing out how the single aileron servo works out.
Brian
Old Feb 25, 2011, 05:07 PM
Suicufnoc's Avatar
Joined Aug 2010
Now I just need to get some plastic. Probably go with the drop cloth I guess, or mylar if I can find some. I keep seeing things around the house that might work. I'm considering a very thin plastic bag from a store. The ones that are too weak to hold the groceries and rip.
Plus you get free cool artwork. Walmart logo or something...
Old Feb 25, 2011, 05:25 PM
Joined Oct 2006
Suicufnoc, thanks very much for the links.
Old Feb 26, 2011, 01:02 PM
Suicufnoc's Avatar
Joined Aug 2010
No problem. I'll let you know how it works out. The gearbox is on backorder though, so I don't expect to get the stuff for a couple weeks. On the bright side, the plane will definitely be done before next winters indoor flying season. (An already crashed and rebuilt several times )
Hobbyking says the 2g servo has 200g of torque, which seems like it should be more than enough to handle both ailerons. Mounting it may be a little bit of a pain, but shouldn't be much different than a larger foamy.
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19352 Jun 16, 2016 01:08 PM
Discussion Inspired in the Delta Rig DiasDePlaya Sailboats 9 Oct 07, 2010 11:56 AM
Discussion Pond Racer inspired design Serever Foamies (Scratchbuilt) 2 Oct 03, 2010 07:47 PM
Video Yak 55-inspired GWS Formosa mexico Electric Plane Talk 1 May 13, 2006 10:58 PM
Gallery Hyperion Yak 55-inspired Formosa mexico Sport Planes 7 Apr 14, 2006 10:04 PM
