Old Feb 11, 2011, 12:20 AM
Aerobotix is offline
Find More Posts by Aerobotix
Cameron Park, CA
Joined Oct 2010
Originally Posted by MIT KID View Post
Here are some pics of my updated fuselage bracing. much easier than the full length foam brace.
-Adam
Is the bracing only on one side? I was thinking to do both sides as a mirror of each other. On this size model I guess one side may be more than adequate?
Always trying to be mindful of weight in the cost/benefit equation.
Aerobotix is offline Find More Posts by Aerobotix
Old Feb 11, 2011, 04:19 AM
AJWoods is online now
Find More Posts by AJWoods
Aircraft Designer Guy
AJWoods's Avatar
United States, CA, Santa Clara
Joined Jul 2005
Yup. Just one side, it's plenty stiff. I've actually found that this skeleton method (particularly with the drop cloth type covering) is very durable. The semi flexibly skin lets things move around more when you bump into things, keeping the foam from cracking.
-A
AJWoods is online now Find More Posts by AJWoods
Latest blog entry: A-10 + Nerf Blaster = Awesome
Old Feb 22, 2011, 12:55 PM
Cameron Park, CA
Joined Oct 2010
Quick clip of flying in the living room. More to come...
Micro YAK 55 - Trailer (0 min 45 sec)
Old Feb 22, 2011, 08:24 PM
BryanEW710 is online now
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
This is some pretty cool stuff!
BryanEW710 is online now Find More Posts by BryanEW710
Old Feb 22, 2011, 09:31 PM
Suicufnoc is offline
Find More Posts by Suicufnoc
Suicufnoc's Avatar
Joined Aug 2010
Hey how much does the airframe weight empty?
Suicufnoc is offline Find More Posts by Suicufnoc
Old Feb 22, 2011, 09:41 PM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Mine came out ~10 grams covered. My scale doesn't show tenths so I'd have to say +/- .5 grams. It's a blast and much less expensive than the E-Flite Extra.
I'm still tweaking the design to get it lighter. I feel the need to cut more weight! I'm still using "normal" 3mm depron...the depron aero is supposed to come in this week. They say it 20% lighter. That alone should shave off around 1.6-1.8 grams!
Brian
cpdude is offline Find More Posts by cpdude
Old Feb 22, 2011, 10:00 PM
0011000011001 is offline
Find More Posts by 0011000011001
byte me!
0011000011001's Avatar
Joined Aug 2008
Im busy building one right now..but im using 2mm depron.the vertical pieces and rudder with all bits cut out weigh 2.5g! I have yet to cut the wing and elevator pieces...
0011000011001 is offline Find More Posts by 0011000011001
Old Feb 22, 2011, 10:06 PM
Suicufnoc's Avatar
Joined Aug 2010
cpdude -
Cool. I'm considering doing one with alternate electronics. I don't want to go Spektrum, and I don't want a gearbox. My electronics should weight 18.5g. A 10g airframe leaves another 4g for linkages to reach a 32.5g goal. Electronics can probably be lightened a little bit if need be.
Plus prop weight... not planning on doing landing gear.
I'm planning on using Depron Aero also. Actually seems to be a little cheaper than regular depron
Old Feb 23, 2011, 08:58 PM
DGS is offline
DGS
Find More Posts by DGS
DGS
Joined Dec 2004
My Yak is ~11 grams covered with a touch of paint added. Hope to finish it up this weekend.
Dave S.
DGS is offline Find More Posts by DGS
Old Feb 23, 2011, 09:23 PM
cpdude is offline
Joined Jan 2004
@Dave - definitely post some pics when your done.
Brian
Old Feb 24, 2011, 05:11 PM
Suicufnoc's Avatar
Joined Aug 2010
What size carbon are you guys using for control rods?
Old Feb 24, 2011, 05:36 PM
Darth_Elevator is offline
Find More Posts by Darth_Elevator
How do I change this text?
Darth_Elevator's Avatar
The Beautiful Mountains of Utah
Joined Oct 2006
Pardon my ignorance, but what's the best way to produce a paper template from the dxf files posted above if I don't have a plotter? Take the dxf files down to a copyshop with a plotter and have them print them out? Use software that will convert the dxf files to a tileable pdf? Use some dxf viewer program that will produce a tiled printout? Any suggestions? Thanks
Also, do you guys recommend any good online sources for depron, especially somewhere with reasonable shipping so a small order won't break the bank? I bought some thin depron online about 3 years ago but I can't for the life of me remember where.
Darth_Elevator is offline Find More Posts by Darth_Elevator
Old Feb 24, 2011, 06:09 PM
3dflyboy1 is offline
Find More Posts by 3dflyboy1
USA, CA, San Juan Capistrano
Joined Dec 2010
For ordering depron, I would use rcfoam.com
I have no clue about the dxf conversion...I was trying to figure that out too.
3dflyboy1 is offline Find More Posts by 3dflyboy1
Old Feb 24, 2011, 06:12 PM
cpdude is offline
Joined Jan 2004
I believe that I ended up using .040" because that what the hobby guys had in stock. It seems to work fine. I think the stock 4-site uses .050".
Brian
Old Feb 24, 2011, 06:18 PM
Suicufnoc's Avatar
Joined Aug 2010
I'm converting the dxf to Pdf for my version. Gonna cut it out by hand. I'll put it up when its done.
Umm... What the wingspan supposed to be on this thing? I was guessing 16" but maybe 18" since it's so light?
cpdude - thanks
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19423 Aug 15, 2016 09:37 PM
Discussion Inspired in the Delta Rig DiasDePlaya Sailboats 9 Oct 07, 2010 11:56 AM
Discussion Pond Racer inspired design Serever Foamies (Scratchbuilt) 2 Oct 03, 2010 07:47 PM
Video Yak 55-inspired GWS Formosa mexico Electric Plane Talk 1 May 13, 2006 10:58 PM
Gallery Hyperion Yak 55-inspired Formosa mexico Sport Planes 7 Apr 14, 2006 10:04 PM
