Old Dec 16, 2012, 09:13 PM
AJWoods is offline
Find More Posts by AJWoods
Aircraft Designer Guy
AJWoods's Avatar
United States, CA, Santa Clara
Joined Jul 2005
Originally Posted by BryanEW710 View Post
You could just PM/email him instead of waiting for him to come to you...
Haha, please do. At any rate, the Sultimate was a one-of, I bought a set of plans of Donatas, and it's not my design to re-distribute/produce for people.
As far as the other stuff goes, I don't typically cut stuff for folks, unless I've already cut a bunch in the process of getting a design figured out. It's a big pain for me to keep foam on hand and mail stuff. Not really in it to be a kitter, I just want to provide people with plans to work from.
Cpdude has cut some for people in the past, he can probably hook you up.
-Adam
AJWoods is offline Find More Posts by AJWoods
Old Dec 19, 2012, 07:45 PM
Nooflyer is offline
Find More Posts by Nooflyer
Nooflyer's Avatar
United States, MO, KCMO
Joined Aug 2005
PM sent thanks
Nooflyer is offline Find More Posts by Nooflyer
Old Feb 16, 2013, 07:49 PM
peterdawolf is offline
Find More Posts by peterdawolf
It's the Crack
peterdawolf's Avatar
United States, CA, Ventura
Joined Feb 2013
Originally Posted by cpdude View Post
I've finally got my drawings in a state worth sharing. This version of the YAK 55 looks a lot like MIT KIDs because his design was the starting point! It's really just a very modified version of his design.
I've broken the drawing into three smaller pages simply because my laser is smaller than his.
This version will be harder to cut by hand since there are more interlocking parts. Let me know if you want one cut. However, you're welcome to have anyone cut it or cut it by hand.
Enjoy!
Brian
Brian, I would like actually two of these cut.. I have a pair of Stryker F27Q 180's that are probably not going to fly again.. well, one will, but by the time I build the first one, probably not
Planning to donate the gear from the Strykers to build two of these Yak's, I'm too new to send PM's, so please send me one?
Peter
peterdawolf is offline Find More Posts by peterdawolf
Old Feb 16, 2013, 08:01 PM
It's the Crack
Joined Feb 2013
Man. I can't wait to build one of these. Looks like exactly what I was looking for.
Last edited by peterdawolf; Feb 16, 2013 at 08:28 PM. Reason: What was there, was unnecessary.
Old Feb 16, 2013, 08:13 PM
It's the Crack
Joined Feb 2013
Revise that.. found the PM function. Can't tell if it worked, no sent messages in my PM box, but I will keep trying
Peter
Originally Posted by peterdawolf View Post
No doubt.. except I can't figure how on this forum Wasn't sure if it was because of post count or what..
Old Feb 16, 2013, 08:20 PM
BryanEW710 is online now
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Peter
You probably have your profile set up so that you don't save outgoing PM's in your Sent box. Just be patient.
BryanEW710 is online now Find More Posts by BryanEW710
Old Feb 23, 2013, 04:10 PM
It's the Crack
Joined Feb 2013
So, enough of the PM sillyness (very new here ;P), but I actually have a 120 version from CPDude *almost* RTF.
Using the guts of a Stryker F27Q 180, removed the Y on the rudder, using all 4 servos, 1 to each aileron, and 1 rudder, 1 elevator. Even using the program I have for the Stryker, minus the elevon mixing. Reversed the motor, soldering blue to the red wire, and vice-versa, prop now rotates clockwise from behind the plane.
Tested all the servo channels, everything moves when I expect it to, just waiting for servo tape and have to track down some tiny carbon rod, although I may have enough random parts to make it work.
Striker elevator servos / control horns are in place, waiting for servo tape, (I might run to the hw store later), and just finishing up the elevator, horn. I took the motor mount for the Stryker, cut the wings off it, and attached it to the Yak with CA after cleaning out the EPP and shoving it down over the horizontal depron at the front, appears straight to the naked eye
Final piece I'm trying to track down is a proper tractor prop for the 180 BL 3000kv from the Stryker. I want to say the prop shaft diameter is 3-4mm, not precisely sure, but assuming I can ream it if I have to (or have it done at the local hobby shop), I've been looking around, and the best thing I can find is ebay GWS or GWS clone 5030's.. I found an APC 5x3, and the one off the UMX Gee Bee is a potential candidate at 5.25x3.5 ... I'm really looking for someone I can order and get it relatively quickly, or pick it up local in Los Angeles..
Peter
Old Feb 24, 2013, 10:05 AM
Petefoss is online now
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
UM Beast prop?
Petefoss is online now Find More Posts by Petefoss
Old Feb 26, 2013, 05:31 PM
It's the Crack
Joined Feb 2013
Originally Posted by Petefoss View Post
UM Beast prop?
In fact, it want to yank itself out of my hand with the UMX beast prop.
Unfortunately, I face three issues at the moment.
1) I have with the control rods bending too much, need to keep working on the guides.
2) 2 out of 4 of the servo's I hot glued down decided they wanted to stick. Pulling apart all 4 to clean and test before I hot glue them back down.
3) Going to do a little reinforcement of the ailerons, they flex too much at the moment and recut/tape the hinges.
Flying weight should stay under 72g or so, will weigh in when it's flying.
First test flight found the sticking servo, so after recovering it from one of the local palm trees, it was remarkably intact.
Old Jul 28, 2013, 10:21 AM
anakinandamidala is offline
Find More Posts by anakinandamidala
Joined Jul 2013
The final PDF
The final pdf files when i try to print only appear to fit on a portrate a4 page makinging the plane very small or am i doing some thing wrong?
anakinandamidala is offline Find More Posts by anakinandamidala
Old Jul 28, 2013, 05:15 PM
potshot is offline
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
You have to make the settings for page size and tiling. In Adobe Reader X in the Page Size and Handing section, select Poster. Then you can set the scale and so on.
If you are using a different Adobe Reader version or another program, just look for a way to tell it to tile the pages or set the scale. Otherwise you'll get defaults, which sounds like what's happening to you now.
potshot is offline Find More Posts by potshot
Old Aug 16, 2013, 08:35 AM
vadersvette is online now
Find More Posts by vadersvette
vadersvette's Avatar
United States, UT, Sandy
Joined Feb 2013
Just ordered three laser cut kits from Brian...looking forward to the build. I need to review this thread again to check for any upgrades. I believe many of you have referred to a more powerful motor to be obtained from a fellow foamie addict, but I couldn't figure out how to contact him. Any help here would be appreciated.
Also, any additional hints and modifications are always welcome. With temps here in the high 90's and record temps all summer, it's hard to start planning for winter and indoor flying, but I'm sure it will be here sooner than I can be fully ready.
vadersvette is online now Find More Posts by vadersvette
Old Aug 16, 2013, 09:01 AM
BryanEW710's Avatar
Joined Sep 2010
Oh good...He's still making them!
I also mentioned the motor stuff in a post a while ago.
Old Aug 20, 2013, 07:58 AM
Joined Feb 2013
Bryan,
Thanks for the lead to RCBabbel...I contacted him and he has shipped me a new motor which should arrive about the same time the kits do.
Old Aug 20, 2013, 08:10 AM
BryanEW710's Avatar
Joined Sep 2010
Originally Posted by vadersvette View Post
Bryan,
A pleasure to be of service
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19361 Jul 13, 2016 07:43 AM
Discussion Inspired in the Delta Rig DiasDePlaya Sailboats 9 Oct 07, 2010 11:56 AM
Discussion Pond Racer inspired design Serever Foamies (Scratchbuilt) 2 Oct 03, 2010 07:47 PM
Video Yak 55-inspired GWS Formosa mexico Electric Plane Talk 1 May 13, 2006 10:58 PM
Gallery Hyperion Yak 55-inspired Formosa mexico Sport Planes 7 Apr 14, 2006 10:04 PM
