Old Nov 30, 2010, 04:25 PM
Scaleflyer121's Avatar
Central Massachusetts
Joined Nov 2010
Vapor trouble
Hey guys. I'm haveing a bit of trouble with my vapor. This weekend at the gym I was flying and I somehow without even crashing, demolished the thing. First the weels just fell clean off, and then the prop shaft snapped, AND I DIDN'T EVEN TOUTCH THE GROUND! So I was wondering, would it be better to just get the replacement parts, or just get the new night vapor? And How do i glue the weels back on? Please help.
Brody
Scaleflyer121 is offline Find More Posts by Scaleflyer121
Old Nov 30, 2010, 05:29 PM
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
i vote buy some foam and build a new one.
nemoskull is offline Find More Posts by nemoskull
Old Nov 30, 2010, 06:22 PM
Minneapolis, Minnesota
Joined Jul 2007
Didn't touch the GROUND.. How about the WALLS? Heh-heh. You can buy a new prop shaft for a couple bucks. New wheels are like, six. I don't know the shape your 'fallen off' landing gear might be in, but if it's still a once-piece unit you should be able to re-attach it with CA glue.
Jay
Faethor is offline Find More Posts by Faethor
Old Nov 30, 2010, 07:17 PM
Joined Nov 2010
well i've tried ca and sadly it didn't do any good. It worked until i put it down on a table. Any glue's that will bond to that type of plastic.
Old Nov 30, 2010, 07:21 PM
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
a little glue to hold it in place and then wrap in thread and ca the thread to make it stronger than it was before
derk is offline Find More Posts by derk
Old Nov 30, 2010, 07:56 PM
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
If your landing gear broke at the plastic mount that attaches to the frame like mine did you can use a thin spring steel wire and bend it to match the mount and then wrap it in thread and soak it with CA. That wire will make it tough as hell and probably never break again.
TODD
PS; Derk it might look like it but no I'm not stalking you
I R Irv is offline Find More Posts by I R Irv
Old Nov 30, 2010, 08:11 PM
devemaster's Avatar
Bangor Maine
Joined Nov 2010
new airframe
Uhu works great on plastic. So does Plumber's Goop. If all else fails you can buy a new airframe complete from Horizon for 50 bucks.
http://www.horizonhobby.com/Products...ProdID=PKZ3370
Of course, a whole new Night Vapor is only 100 bucks, but the old Vapor is lighter and just a bit different than the newer Night.
They had the original Vapor at amainhobbies.com until just recently. Maybe if you call them they might be have one.
devemaster is offline Find More Posts by devemaster
Old Nov 30, 2010, 08:22 PM
Joined Jul 2007
Hey! IR IRV, you've got two motors on that gearbox! Tell more!
Jay
Old Nov 30, 2010, 08:32 PM
I R Irv's Avatar
Joined Nov 2008
Jay
Theres a couple more pics in my blog, eventually I'll discribe in there how I did it. Right now I'm just to damn lazy to do it.
TODD
Old Dec 01, 2010, 06:14 AM
Joined Nov 2010
Thanks guys. And no it didn't toutch anything, the prop shaft just snapped somehow.
Brody
Old Dec 01, 2010, 02:59 PM
Joined Nov 2010
I've heard that the night vapor is easier to replace parts with. Is that true?
Brody
Old Dec 01, 2010, 05:33 PM
devemaster's Avatar
Bangor Maine
Joined Nov 2010
Yessuh-
Tings be modular on the Night Vapor, but ye gets 4 more grams o weight as a trade off.
Help! Parkzone Vapor and night Vapor Prop? bakon Indoor and Micro Models 10 Apr 15, 2011 05:45 PM
For Sale NIP Vapor Night Board and Vapor Airplane rcBluebird Aircraft - Electric - Micro & Indoor Airplanes 3 Feb 07, 2011 12:16 AM
Discussion trouble ordering at HK joliecoeur13 Hot Online Deals 4 Nov 07, 2010 09:16 AM
Discussion Mikrokopter & Hitec Aurora9 trouble? flymedia Multirotor Talk 1 Oct 29, 2010 06:38 PM
Wanted Vapor or Night Vapor, BnF maukabud Aircraft - Electric - Micro & Indoor Airplanes 1 Sep 13, 2010 04:30 PM
