Old Nov 30, 2010, 10:19 AM
jjmouris is offline
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
The Budget Drive Mk2
After the long thread about the 25 dollar motor it is time for a new one to put some new life into this project.
Old thread;
http://www.rcgroups.com/forums/showt...tronik&page=11
This time i used a Plettenberg 5:1 gearbox and smaller prop. Kindly supplied by Frank in the Netherlands and as soon as i have test flown, he will be getting this drive for the next flying season.
Setup;
RFM 16x17 slim
HM Spinner 32mm with 40mm yoke
Hobbycity KD36L 3000KV
CC P125 with full George mod
Turnigy 6S 3000mah 40C
Alternatively, 5S and big 17" props.
Teaser picture..... note the gearbox front fits where a Neu does.
jjmouris is offline Find More Posts by jjmouris
Old Nov 30, 2010, 10:25 AM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
The parts and how they go together.
In this case there where no bolts supplied to bolt the gearbox to the motor so i had to pull some M3 bolts out my drawer. Make sure they are not to long as this could damage the windings on the inside of the motor!
You need to use some high strength stuff to put the grub screw in the pinion. The other screws are fixed in place with some low strength loctite.
The gears are already pre lubricated.
All done in about 15 minutes.
Old Nov 30, 2010, 10:32 AM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
In this case i replaced the 3 glass fibre like sleeves on the motor wires with some 10mm heatschrink as they where just loose on the wire and the heatschrink gives a bit more support. Note, if you use to small diameter heatschrink it will split from the heat when you solder the ESC wires to the motor wires.
Also, when i solder the 6mm bullet connectors i put some kapton tape on the male connector to stop any accidental solder from flowing in there and i use an old wood clothes peg to hold the connector while soldering.
The CC P125 was modified as per; http://www.f5b.co.uk/?q=node/215
Finished.
Old Nov 30, 2010, 10:42 AM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
A little static run just for fun.
Incase you can't read it...... that's about 250A, 20V and 5KW peak static.
Joe
Old Nov 30, 2010, 12:38 PM
silva916 is offline
Find More Posts by silva916
Germany, 300 meters from the Netherlands
Joined Sep 2010
Thanks Joe, look`s good !!!
silva916 is offline Find More Posts by silva916
Old Dec 01, 2010, 03:41 AM
Mike Seale is online now
Find More Posts by Mike Seale
f5b-uk
Mike Seale's Avatar
United Kingdom, Dorset
Joined May 2002
I can see KD36L motors with KV of 2200, 2700, 3500 and 4000. Have you made a typo or is the 3000KV motor hidden away somewhere on the HK website?
And out of interest, how much did the gearbox cost after shipping. IOW, what is the total cost once attached to the $25 motor so we can compare it to a Kontronik/Plettenberg/Hacker/Neu alternative.
Regards
Mike Seale is online now Find More Posts by Mike Seale
Old Dec 01, 2010, 04:00 AM
Dzjaivnt is offline
Find More Posts by Dzjaivnt
Nederland, Gelderland, Ermelo
Joined Mar 2009
@Mike
http://www.hobbycity.com/hobbyking/s...idProduct=6674
This is the one.
Dzjaivnt is offline Find More Posts by Dzjaivnt
Old Dec 01, 2010, 04:42 AM
f5b-uk
Mike Seale's Avatar
Joined May 2002
Thank you. When I search for 'all inrunner motors' I see the 6L, 7L and 9L but no 8L. The 8L must be hiding on another page.
Old Dec 01, 2010, 05:44 AM
silva916 is offline
Joined Sep 2010
Regards
Aprox 35 HC Motor, Pletgear 115,90 al incl shipping.
Gr Frank
Old Dec 01, 2010, 05:45 AM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Mike, i do not advise this route over simply buying a Hacker motor with 6.7:1 gearing. It was just for fun and to take the mickey out of the much more expensive motors.
gearbox 109 euro
postage 6,90 euro
motor 28,95 usd
postage 6,99 usd
total 144 euro
More disturbing..... the total weight is 350 grams. This gearbox is a little more heavy compared to a Neu P32.
Some people asked me about the 5KW, well this is static and in flight you will see a bit less but still above 4KW. No different then the Mk1 budget drive to be found at the end of the thread i linked to in the first post. Hense i have no doubt the motor will be OK. The only question is the gearbox.
Old Dec 01, 2010, 06:43 AM
f5b-uk
Mike Seale's Avatar
Joined May 2002
And I'm not considering changing either, but it is interesting that you can get a good geared inrunner setup for under 150 euro.
Old Dec 01, 2010, 06:58 AM
Protocooler is offline
Find More Posts by Protocooler
sloping addict
Protocooler's Avatar
France
Joined Feb 2003
Thanks Joe, I have already 100% exact same setup (motor, cells, prop, P125!!!) - just lacking a gearbox. My motor is still in its box, and actually the cells are still on their way in.
Thus very interested in these tests .
I'll wait for your conclusions between a P32 and a Pletti gearbox, and wether 6.7 or 5:1 ratio is better (maybe a 17*17 or 18*21 would be better with a 6.7 then). By the way, when checking for a gearbox I could not find a place that had the Pletti in stock. Where did you get it from ?
The 40C Turnigy 3000 seem to fare pretty well under 220A+, I calculated 3 mOhms from your test, quite good, especially if they were not pre-heated (?).
I think I have 2 props you don't have, these are unmarked, If I recall well they were sold by Stratair about 2 years ago, 17*17 and 18*something, fit on straight yokes no need for the twisted & offset RFM special spinner (that's also why I got them initially). I think Stratair themselves built these props, but it seems they only carry a 16*16s now. You may want to ask them, in case you want to experiment straight yokes with these different 17" and 18"...
http://www.stratair.com/Shop/Produkt...aspx?ArtId=856
Protocooler is offline Find More Posts by Protocooler
Old Dec 01, 2010, 06:37 PM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
Yuri.
Dbox is offline Find More Posts by Dbox
Old Dec 01, 2010, 08:00 PM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Mike, we wait to see a good Chinese gearbox.
Proto, the Neu P32 6.7:1 will be best if you can get it. It's lighter, better construction and proven. Also the higher ratio is better, it allows bigger prop or higher KV motor.
Yuri, explain your self.
Old Dec 01, 2010, 09:44 PM
Dbox is offline
Dbox's Avatar
Joined Jun 2005
The Budget Drive of the Future.
Yuri.
Discussion Need advise on how to setup stinger drive to drive shaft Flying Barry Racing Boats - Electric 6 Mar 13, 2013 05:31 AM
Sold 2 mpjet ac 25/35-20 mk2 $45 SHIPPED! mcalliej Aircraft - Electric - Power Systems (FS/W) 0 Sep 08, 2010 09:54 PM
Sold Miracle Switch MK2 DbleX Aircraft - General - Miscellaneous (FS/W) 0 Aug 30, 2010 11:02 PM
GMD 'Ironic Mk2' direct drive graham_mca Sport Planes 6 May 25, 2004 11:43 PM
Elipsoid low budget drive checkenbach Electric Sailplanes 2 Apr 09, 2002 08:12 AM
